[GeoNode-users] upload doesn't work without any logs (Eugenio Trumpy)
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jun 12 08:32:03 PDT 2018
Uhm, that's weird. And I guess no layer has been created on GeoServer also,
right?
Could you maybe try to create the layer on GeoServer first and than run
*python manage.py updatelayers --skip-geonode-registered
--skip-unadvertised*
Il giorno mar 12 giu 2018 alle ore 17:27 Eugenio Trumpy <
frippe12573 at hotmail.com> ha scritto:
> Hi Alessio,
> that's really strange! It happens only with some recent SHP files created
> by QGIS from csv file.
> I tried with a SHP created today as polygon and it works properly.
> Following your suggestion I set:
> log4j.category.org.geoserver=DEBUG
> then I tried to upload the SHP file that was not uploaded, the same in the
> log
> I cannot find any new lines.
> Eugenio
> *Da:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Inviato:* martedì 12 giugno 2018 17:09
> *A:* Eugenio Trumpy
> *Cc:* Toni Schönbuchner; geonode-users
> *Oggetto:* Re: [GeoNode-users] upload doesn't work without any logs
> (Eugenio Trumpy)
> Hi Eugenio,
> try maybe to rise up the GeoServer log level and check the logs (of
> GeoServer) after the upload.
> Maybe the SHP cannot be read from GeoServer for some reason.
> Also, is this happening with every dataset or just with one SHP?
> Il giorno mar 12 giu 2018 alle ore 17:00 Eugenio Trumpy <
> Dear Toni,
> I set:
> DEBUG=True
> in local_setting.py configuration file. Since I have a geosites
> installation the local_setting I meant before was the general one (not
> inside the sites folder).
> Once I try to upload a shp file nothing is written in apache2 access.log
> The shape file is very very small! Deleted even the cookies, but nothing
> change.
> Eugenio
> *Da:* Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> *Inviato:* martedì 12 giugno 2018 16:09
> *A:* Eugenio Trumpy
> *Cc:* geonode-users
> *Oggetto:* Re: upload doesn't work without any logs (Eugenio Trumpy)
> Dear Eugenio,
> have you tried to set DEBUG to true in local_settings? Further do you see
> the request in apaches access log?
> An upload which exeeds the allowed filesize limit can cause a 400 as well.
> Is your file of tremendous size?
> Next can you check your cookies in developer tools? It could be worth to
> delete all of them and retry with a
> fresh session.
> cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> CSGIS <http://csgis.de/>
> csgis.de
> OneCause is premium, responsive theme built with Bootstrap for Joomla CMS.
> With a clean and minimal design, this multi-purpose template is perfect for
> anything you can imagine.
> Hinweis gemäß § 33 BDSG
> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
> ausschließlich für den
> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
> diese E-Mail versehentlich
> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
> löschen Sie diese Nachricht
> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
> Vervielfältigung, Veränderung,
> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 12.06.2018 um 14:42 schrieb Eugenio Trumpy <frippe12573 at hotmail.com>:
> No IP or domain changed.
> That's weird...
> E.
> *Inviato:* martedì 12 giugno 2018 14:17
> *A:* frippe12573 at hotmail.com
> *Cc:* geonode-users
> Dear Eugenio,
> did you change anything on your ip or domain setup which could cause the
> error 400?
> Cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Web http://csgis.de
> csgis.de
> Message: 4
> Date: Tue, 12 Jun 2018 11:55:43 +0000
> From: Eugenio Trumpy <frippe12573 at hotmail.com>
> To: Simone Dalmasso <simone.dalmasso at gmail.com>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] upload doesn't work without any logs
> Message-ID:
> AM5P190MB0420AB6A1C678D9CEFBF67D4E57F0 at AM5P190MB0420.EURP190.PROD.OUTLOOK.COM
> Content-Type: text/plain; charset="iso-8859-1"
> Hi Simone,
> here is the issue:
> POST http://gemex.igg.cnr.it/layers/upload 400 (BAD REQUEST)
> any hints?
> Eugenio
> ________________________________
> Da: Simone Dalmasso <simone.dalmasso at gmail.com>
> Inviato: martedì 12 giugno 2018 13:41
> A: Eugenio Trumpy
> Cc: geonode-users
> Oggetto: Re: [GeoNode-users] upload doesn't work without any logs
> Hi Eugenio,
> the browser developers console is for sure the first place where to look.
> Best
> Il giorno mar 12 giu 2018 alle ore 11:25 Eugenio Trumpy <
> frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com
> <frippe12573 at hotmail.com>>> ha scritto:
> Hi all,
> I have problem with geonode 2.4 dev20160525015826.
> It worked properly, but currently I have problems uploading shp file.
> The strange thing is that nothing is written on the logs (apache2
> error.log and geoserver.log).
> Could you suggest me how to investigate on this problem?
> Thanks,
> Eugenio
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180612/90c66655/attachment-0001.html>
More information about the geonode-users
