[GeoNode-users] [GeoNode-devel] GeoNode Demo instance up and running
Paolo Corti
pcorti at gmail.com
Fri Jun 22 08:20:56 PDT 2018
Fantastic!
Thanks Giovanni and Geosolutions guys
Cheers
P
On Fri, Jun 22, 2018, 07:07 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Example embed map generated on demo instance
> http://master.demo.geonode.org/maps/6/embed
> Il giorno ven 22 giu 2018 alle ore 10:46 Simone Dalmasso <
> simone.dalmasso at gmail.com> ha scritto:
>> Great news! Thanks a lot to all!
>> Il giorno ven 22 giu 2018 alle ore 10:05 G. Allegri <
>> giovanni.allegri at geo-solutions.it> ha scritto:
>>> Dear devs,
>>> we're pleased to announce that an instance of the master GeoNode branch
>>> has been published on our servers. It will serve as a demo of the latest
>>> (development) version of GeoNode.
>>> The instance is running on Docker. Every night the containers are
>>> restarted from scratch. Data uploaded from users, maps and any other
>>> configuration will be reset. Only users accounts are retained between
>>> restarts.
>>> For the moment the GeoNode image is built manually every two weeks. We
>>> did some tests with automatic pull / build but master code is too much
>>> "volatile" to guarantee CI. This is a topic by itself that we suggest to
>>> discuss in a dedicated thread.
>>> We invite everybody to test it and give us feedbacks.
>>> In a week since now we will publish the link on the demo landing page (
>>> http://demo.geonode.org).
>>> *Master GeoNode Demo URL: http://master.demo.geonode.org
>>> <http://master.demo.geonode.org/>*
>>> All the best,
>>> Giovanni
>>> Giovanni Allegri
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>>> 55054 Massarosa
>>> (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> mob: +39 331 6233686
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180622/cf4c6f8d/attachment.html>
More information about the geonode-users
