[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria
daniel.victoria at gmail.com
Mon Mar 5 06:19:04 PST 2018
Update: Apparently, if I update the layer permissions in the web interface
or if i run `geonode updatelayers -f <layer_name>`, the correct GeoFence
permissions are created. Thus, doing so a layer at a time works. But
several layers at once, no.
What should I look for in the GeoServer log to try to figure out where the
problem is occurring? I can attach the GeoServer log if that helps.
Cheers
Daniel
On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Hi list,
> I have GeoNode 2.6.3, installed from apt, in a Ubuntu machine. Right now i
> have 108 registered layers, some imported using the web interface, some
> using the `geonode importlayers` command.
> Last week I noticed that some of the layers I was importing using the
> management command had view permission problems. I realized that the cause
> was that the GeoFence rules were not being created correctly.
> Looking at the messages on the list, I saw that there were some
> discussions about this issue and that 1) there was a patch for
> geoserver/helper.py [1] and 2) a new `sync_geofence` management command.
> I applied the patch and downloaded the `sync_geofence` command.
> Now, every time I run `geonode updatelayers` I end up with a different set
> of rules in GeoFence. Some times with 106 rules, some times with 209 rules
> etc. And I can't run `geonode sync_geofence` since I'm getting an error:
> UnboundLocalError: local variable 'perm_spec' referenced before assignment
> Any idea how to fix this issue so I don't have to manually create the
> GeoFence rules? And also, not have `geonode updatelayers` mess up the rules
> already created?
> Cheers
> Daniel
> [1] -
> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180305/df4da90b/attachment.html>
More information about the geonode-users
