[GeoNode-users] Problem with GeoFence permissions
Daniel Victoria daniel.victoria at gmail.com
Thu Mar 8 06:49:15 PST 2018
OK, I gave up in trying to find why my GeoFence / GeoServer / GeoNode was
acting all crazy. Since I only needed WMS access to the layers, I fixed my
problem in the most embarrassingly (and ugly) way possible.
I wrote a python code that will get a list of layers using WMS
GetCapabilities and the list of GeoFence Rules (both authenticated as the
geoserver admin). I then look for layers that have no rules set and allow
both WMS and GWC for each.
Funny thins is that while creating the rules, all of a sudden it stops
working (response 500 from the GeoFence post request). I then restart
tomcat, create one rule manually and then my script will work again. Seems
like GeoFence is chocking...
For now it seems to be working. Just hope I don't break more things in the
process :)
Cheers
Daniel
On Wed, Mar 7, 2018 at 11:25 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> The risk is very high.
> Try to compare the one from 2.7.x branch with your one. Maybe they have
> diverged less.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054  Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax:     +39 0584 1660272 <+39%200584%20166%200272>
> mob:   +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> 2018-03-07 15:22 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>> I've seem that the geonode/security/models.py in the master branch is
>> quite different from what I got installed using the apt-sources. The file
>> from the 2.6.x branch also differs from what I've got. Can I pull the
>> security/models.py from the 2.6.x branch into my APT installation? Or do I
>> risk messing things up even more?
>> On Wed, Mar 7, 2018 at 10:55 AM Alessio Fabiani <
>>> Uhm that's strange, from what I see on the code it should be the same
>>> that updating permissions from the gui.
>>> print 'Synchronizing permissions for layer %s/%s: %s' % (count,
>>> layers_count, layer.alternate)
>>> perm_spec = json.loads(_perms_info_json(layer))
>>> layer.set_permissions(perm_spec)
>>> it's possible that the old geofence methods have some bugs. There were a
>>> lot or fixes since 2.6.3 version there also.
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> 55054  Massarosa
>>> (LU)
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> 2018-03-07 13:54 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>>> Thanks Alessio,
>>>> I had substituted "layer.alternate" to "layer.name" and sync_geofence
>>>> worked with no complains.  I also added a 5 second timeout between each
>>>> layer processing to try to bypass the problem mentioned by Paolo when
>>>> adding several rules to GeoFence.
>>>> However, each time I run sync_geofence I still get a different set of
>>>> data access rules in GeoFence. And I haven't figured out a pattern of which
>>>> layers are or not included in the rules.
>>>> Cheers
>>>> Daniel
>>>> On Wed, Mar 7, 2018 at 5:34 AM Alessio Fabiani <
>>>>> Dear all,
>>>>> "alternate" attribute has been introduced on GeoNode 2.7+ with the
>>>>> update of pycsw.
>>>>> In the older versions you must use "typename" instead.
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> 55054  Massarosa
>>>>> (LU)
>>>>> Italy
>>>>> 2018-03-06 17:26 GMT+01:00 Daniel Victoria <daniel.victoria at gmail.com>
>>>>>> Hi Paolo,
>>>>>> I removed the try block. The error happens in the first print
>>>>>> statement, when it tries to print layer.alternate.
>>>>>> It says:
>>>>>> AttributeError: 'Layer' object has no attribute 'alternate'
>>>>>> I then removed the layer.alternate from the print statement and the
>>>>>> sync_geofence command runs. But each time I run it, I get a different
>>>>>> number of geofence data rules.
>>>>>> I'll try to run the commands in a python interpreter and try to
>>>>>> identify what's going on.
>>>>>> Cheers
>>>>>> On Tue, Mar 6, 2018 at 11:37 AM Paolo Corti <pcorti at gmail.com> wrote:
>>>>>>> Daniel
>>>>>>> remove the try block, and paste here the error trace stack
>>>>>>> ps: to debug with the shell, you must use "django-admin shell"
>>>>>>> command
>>>>>>> (which is "geonode shell" if you are using the Ubuntu package, I
>>>>>>> believe)
>>>>>>> thanks
>>>>>>> Paolo
>>>>>>> On Tue, Mar 6, 2018 at 7:11 AM, Daniel Victoria
>>>>>>> <daniel.victoria at gmail.com> wrote:
>>>>>>> > Hi Paolo,
>>>>>>> > There are 2 print statements in the except block. The first prints
>>>>>>> the error
>>>>>>> > and the second is the one that complains about the variable
>>>>>>> 'perm_spec'
>>>>>>> > referenced before assignment.
>>>>>>> > If I comment out just the second print statement I the following
>>>>>>> message
>>>>>>> > printed to the screen, one for each layer registered in GeoServer
>>>>>>> > ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>>>>>> > I tried to run the commands in a python interpreter to debug this.
>>>>>>> But I
>>>>>>> > could not get the environment set. When I import the
>>>>>>> geonode.layers.models
>>>>>>> > in the interpreter, it complains about django_settings_module.
>>>>>>> > Cheers
>>>>>>> > Daniel
>>>>>>> > On Mon, Mar 5, 2018 at 10:08 PM Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>> >> Hi Daniel
>>>>>>> >> can you try to remove the line with the print statement and see
>>>>>>> what
>>>>>>> >> kind of error is raising?
>>>>>>> >> Paolo
>>>>>>> >> On Mon, Mar 5, 2018 at 12:26 PM, Daniel Victoria
>>>>>>> >> > Hi Paolo,
>>>>>>> >> > Thanks for the tip. However, I installed GeoNode from the APT
>>>>>>> repository
>>>>>>> >> > and
>>>>>>> >> > I have no idea how to upgrade GeoNode or change GeoFence store
>>>>>>> from H2
>>>>>>> >> > to
>>>>>>> >> > PostgreSQL.
>>>>>>> >> > I also added time.sleep(5) in sync_geofence.py, right before
>>>>>>> the try
>>>>>>> >> > block
>>>>>>> >> > but I'm still getting an error: It fails with the message:
>>>>>>> >> > Traceback (most recent call last):
>>>>>>> >> >   File "/usr/bin/django-admin", line 21, in <module>
>>>>>>> >> >     management.execute_from_command_line()
>>>>>>> >> >   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>>>>> >> > line
>>>>>>> >> > 354, in execute_from_command_line
>>>>>>> >> >     utility.execute()
>>>>>>> >> >   File
>>>>>>> >> > line
>>>>>>> >> > 346, in execute
>>>>>>> >> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>> >> >   File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>>>>> >> > line 394, in run_from_argv
>>>>>>> >> >     self.execute(*args, **cmd_options)
>>>>>>> >> >   File
>>>>>>> >> > line 445, in execute
>>>>>>> >> >     output = self.handle(*args, **options)
>>>>>>> >> >   File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/sync_geofence.py",
>>>>>>> >> > line 60, in handle
>>>>>>> >> >     print 'perm_spec is %s' % perm_spec
>>>>>>> >> > UnboundLocalError: local variable 'perm_spec' referenced before
>>>>>>> >> > assignment
>>>>>>> >> > Any other tips on how to fix this permission mess-up?
>>>>>>> >> > Thanks
>>>>>>> >> > Daniel
>>>>>>> >> > On Mon, Mar 5, 2018 at 12:13 PM Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>> >> >> Another option could be to run a time.sleep for some seconds
>>>>>>> after
>>>>>>> >> >> each layer iteration in sync_geofence command
>>>>>>> >> >> cheers
>>>>>>> >> >> Paolo
>>>>>>> >> >> On Mon, Mar 5, 2018 at 10:04 AM, Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>> >> >> > Hi Daniel
>>>>>>> >> >> > You seem to have hit this bug which I reported to GeoFence
>>>>>>> team in
>>>>>>> >> >> > the
>>>>>>> >> >> > past:
>>>>>>> >> >> > https://github.com/geoserver/geofence/issues/98
>>>>>>> >> >> > I didn't notice this happening in latest GeoFence version, so
>>>>>>> >> >> > upgrading to latest GeoNode could be an option.
>>>>>>> >> >> > Or you could try to use PostgreSQL instead than H2 as a
>>>>>>> GeoFence
>>>>>>> >> >> > store
>>>>>>> >> >> > hope this helps
>>>>>>> >> >> > cheers
>>>>>>> >> >> > Paolo
>>>>>>> >> >> > On Mon, Mar 5, 2018 at 9:19 AM, Daniel Victoria
>>>>>>> >> >> >> Update: Apparently, if I update the layer permissions in
>>>>>>> the web
>>>>>>> >> >> >> interface
>>>>>>> >> >> >> or if i run `geonode updatelayers -f <layer_name>`, the
>>>>>>> correct
>>>>>>> >> >> >> GeoFence
>>>>>>> >> >> >> permissions are created. Thus, doing so a layer at a time
>>>>>>> works. But
>>>>>>> >> >> >> several
>>>>>>> >> >> >> layers at once, no.
>>>>>>> >> >> >> What should I look for in the GeoServer log to try to
>>>>>>> figure out
>>>>>>> >> >> >> where
>>>>>>> >> >> >> the
>>>>>>> >> >> >> problem is occurring? I can attach the GeoServer log if
>>>>>>> that helps.
>>>>>>> >> >> >> Cheers
>>>>>>> >> >> >> Daniel
>>>>>>> >> >> >> On Mon, Mar 5, 2018 at 9:52 AM Daniel Victoria
>>>>>>> >> >> >> wrote:
>>>>>>> >> >> >>> Hi list,
>>>>>>> >> >> >>> I have GeoNode 2.6.3, installed from apt, in a Ubuntu
>>>>>>> machine.
>>>>>>> >> >> >>> Right
>>>>>>> >> >> >>> now i
>>>>>>> >> >> >>> have 108 registered layers, some imported using the web
>>>>>>> interface,
>>>>>>> >> >> >>> some
>>>>>>> >> >> >>> using the `geonode importlayers` command.
>>>>>>> >> >> >>> Last week I noticed that some of the layers I was
>>>>>>> importing using
>>>>>>> >> >> >>> the
>>>>>>> >> >> >>> management command had view permission problems. I
>>>>>>> realized that
>>>>>>> >> >> >>> the
>>>>>>> >> >> >>> cause
>>>>>>> >> >> >>> was that the GeoFence rules were not being created
>>>>>>> correctly.
>>>>>>> >> >> >>> Looking at the messages on the list, I saw that there were
>>>>>>> some
>>>>>>> >> >> >>> discussions about this issue and that 1) there was a patch
>>>>>>> for
>>>>>>> >> >> >>> geoserver/helper.py [1] and 2) a new `sync_geofence`
>>>>>>> management
>>>>>>> >> >> >>> command.
>>>>>>> >> >> >>> I applied the patch and downloaded the `sync_geofence`
>>>>>>> command.
>>>>>>> >> >> >>> Now, every time I run `geonode updatelayers` I end up with
>>>>>>> a
>>>>>>> >> >> >>> different
>>>>>>> >> >> >>> set
>>>>>>> >> >> >>> of rules in GeoFence. Some times with 106 rules, some
>>>>>>> times with
>>>>>>> >> >> >>> 209
>>>>>>> >> >> >>> rules
>>>>>>> >> >> >>> etc. And I can't run `geonode sync_geofence` since I'm
>>>>>>> getting an
>>>>>>> >> >> >>> error:
>>>>>>> before
>>>>>>> >> >> >>> assignment
>>>>>>> >> >> >>> Any idea how to fix this issue so I don't have to manually
>>>>>>> create
>>>>>>> >> >> >>> the
>>>>>>> >> >> >>> GeoFence rules? And also, not have `geonode updatelayers`
>>>>>>> mess up
>>>>>>> >> >> >>> the
>>>>>>> >> >> >>> rules
>>>>>>> >> >> >>> already created?
>>>>>>> >> >> >>> Cheers
>>>>>>> >> >> >>> Daniel
>>>>>>> >> >> >>> [1] -
>>>>>>> https://github.com/GeoNode/geonode/commit/94b3b6abfd1bc856be94eb58f5bf13
>>>>>>> >> >> >> _______________________________________________
>>>>>>> >> >> >> geonode-users mailing list
>>>>>>> >> >> >> geonode-users at lists.osgeo.org
>>>>>>> >> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> >> >> > Paolo Corti
>>>>>>> >> >> > Geospatial software developer
>>>>>>> >> >> > web: http://www.paolocorti.net
>>>>>>> >> >> > twitter: @capooti
>>>>>>> >> >> > skype: capooti
>>>>>>> >> >> Paolo Corti
>>>>>>> >> >> twitter: @capooti
>>>>>>> >> >> skype: capooti
>>>>>>> >> Paolo Corti
>>>>>>> >> twitter: @capooti
>>>>>>> >> skype: capooti
>>>>>>> Paolo Corti
>>>>>>> twitter: @capooti
>>>>>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180308/e400593b/attachment-0001.html>
More information about the geonode-users mailing list
