[GeoNode-users] [Geoserver-users] Priting endpoint problem : geoserver/rest/printng/render.png gives a 404
Olivier Dalang
olivier.dalang at gmail.com
Tue Mar 20 14:38:05 PDT 2018
Hi !
I'm bringing this back from Geoserver-users to Geonode-users since it's a
Geonode related issue.
When I click "set thumbnail", the thumbnails are broken (the defaults
thumbnails are correctly generated however).
First, I had an issue because I missed the geoserver-geonode-ext. I
installed it, but now I still get broken thumbnails. The generated png
contain this exception :
Handler dispatch failed; nested exception is java.lang.NoClassDefFoundError:
org/ccil/cowan/tagsoup/Parser
Any idea why that's the case ? Aren't plugins supposed to ship with their
dependencies ? (for other extensions, it seemed to be the case).
I'm using geoserver 2.12.2 and got the geoserver-geonode-ext from
http://build.geonode.org/geoserver/latest/geonode-geoserver-ext-2.12.x-geoserver-plugin.zip
Thanks !!
Olivier
On Wed, Mar 21, 2018 at 9:26 AM, Olivier Dalang <olivier.dalang at gmail.com>
wrote:
> Thank you Brad !
> Indeed I forgot to install the geonode extension...
> Kind regards,
> Olivier
> On Tue, Mar 20, 2018 at 11:42 PM, <bradh at frogmouth.net> wrote:
>> Indeed this comes from geonode:
>> https://github.com/GeoNode/geoserver-geonode-ext/tree/master
>> /geoserver/extensions/printng/src/main/java/org/geoserver/printng
>> So you probably would get more support on a geonode mailing list.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180321/0dbeb890/attachment.html>
More information about the geonode-users
