[GeoNode-users] No JSON object could be decoded
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Mar 21 08:30:44 PDT 2018
Federico, geonode logs the upload sessions in the database, you can look
there to see what the error trace is. You can also intercept the non json
response in the client dev tools to see what happens.
ciao
2018-03-21 13:35 GMT+01:00 Federico Gianoli <alpacagis at gmail.com>:
> Thanks Jonathan,
> unfortunately the attribute table of the shp is valid.
> I have rebuilt the attribute table but I still have the same error
> message No JSON object could be decoded
> Federico
> 2018-03-21 5:11 GMT+01:00 Jonathan Doig <j.doig at unsw.edu.au>:
>> Ciao Federico
>> Have you checked the filename and column names? These must start with a
>> letter and include only letters, digits, dash - and underscore _ (maybe a
>> few other characters) but no spaces. Column names over 10 chars will be
>> truncated, so best to do that manually first.
>> Jonathan
>> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
>> Behalf Of *Federico Gianoli
>> *Sent:* Wednesday, 21 March 2018 3:33 AM
>> *To:* geonode-users <geonode-users at lists.osgeo.org>
>> *Subject:* [GeoNode-users] No JSON object could be decoded
>> Dear list,
>> I am trying to upload a shapefile (EPSG 4326) on GeoNode 2.6.
>> During the uploading, GeoNode returns this error: No JSON object could be
>> decoded.
>> I am able to open the shp without any problem in ArcGIS or QGIS. I have
>> also tried to use the tool "repair geometry" and I have re-exported the
>> shp, but the error persist.
>> Has anyone had the same issue?
>> Regards
>> Federico
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180321/55141607/attachment.html>
More information about the geonode-users
