[GeoNode-users] Customizing GeoNode 2.8.0 with geonode-project
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed May 2 08:40:23 PDT 2018
HI Seno,
I tried to work on a similar project. It seems that the best thing to do is
to have both geonone (long-term) and geonode-project dev/my_geonode
installed in the same virtualenv. I worked hard trying to customize
geonode installed via apt-get using the configuration in geonode-project
dev. So, I changed my approach, and I just installed geonode following the
tutorial in here
<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
and now, I am going to install geonode-project dev as in here
<https://github.com/GeoNode/geonode-project>, both in the same virtualenv.
I hope it helps.
Best regards
Julierme
2018-05-02 3:35 GMT-03:00 Seno Adiwicaksono <senoadiw at gmail.com>:
> Dear list,
> I am trying to extend GeoNode 2.8.0 on a clean Ubuntu 16.04.4 VM with the
> latest geonode-project branch from https://github.com/GeoNode/
> geonode-project/tree/2.8.0.
> GeoNode 2.8.0 installs fine with the following commands:
> sudo apt-get install -y build-essential python-pip python-dev
> software-properties-common
> sudo add-apt-repository -y ppa:geonode/stable
> sudo apt-get update
> sudo apt-get install -y geonode
> geonode createsuperuser
> IP_ADDRESS=$(ip route get 8.8.8.8 | awk '{print $NF; exit}')
> sudo geonode-updateip $IP_ADDRESS
> sudo nano /etc/geonode/local_settings.py
> DEFAULT_MAP_CRS = "EPSG:3857"
> DEFAULT_LAYER_FORMAT = "image/png8"
> sudo service apache2 restart
> sudo service tomcat8 restart
> Now I try to install geonode-project per the usual method that I've used
> before since GeoNode 2.6.x, the only difference is the URL to the latest
> GeoNode Django project template (previously it was
> https://github.com/GeoNode/geonode-project/archive/2.6.zip):
> cd ~
> django-admin.py startproject --template=https://github.com/
> GeoNode/geonode-project/archive/2.8.0.zip -e py,rst,json,yml my_geonode
> sudo pip install -e my_geonode
> cp /etc/geonode/local_settings.py my_geonode/my_geonode
> nano my_geonode/my_geonode/local_settings.py
> # edit local settings as required like: SITENAME = "My GeoNode"
> sudo nano /etc/apache2/sites-available/geonode.conf
> # comment default geonode wsgi and add new entries
> #WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
> WSGIScriptAlias / /home/user/my_geonode/my_geonode/wsgi.py
> <Directory "/home/user/my_geonode/my_geonode/">
> Order allow,deny
> Options Indexes FollowSymLinks
> Allow from all
> Require all granted
> IndexOptions FancyIndexing
> </Directory>
> cd my_geonode
> # Update new site name (import error here)
> sudo python manage.py fixsitename
> Traceback (most recent call last):
> File "manage.py", line 31, in <module>
> execute_from_command_line(sys.argv)
> File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
> utility.execute()
> line 328, in execute
> django.setup()
> File "/usr/lib/python2.7/dist-packages/django/__init__.py", line
> 18, in setup
> apps.populate(settings.INSTALLED_APPS)
> File "/usr/lib/python2.7/dist-packages/django/apps/registry.py",
> line 85, in populate
> app_config = AppConfig.create(entry)
> File "/usr/lib/python2.7/dist-packages/django/apps/config.py", line
> 119, in create
> import_module(entry)
> File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
> import_module
> __import__(name)
> File "/usr/local/lib/python2.7/dist-packages/geonode/people/__init__.py",
> line 21, in <module>
> from geonode.notifications_helper import NotificationsAppConfigBase
> File "/usr/local/lib/python2.7/dist-packages/geonode/notifications_helper.py",
> line 37, in <module>
> notifications = import_module(M)
> import_module
> __import__(name)
> ImportError: No module named notifications
> sudo pip list shows that pinax-notifications is already installed:
> amqp (2.2.2)
> anyjson (0.3.3)
> arrow (0.12.1)
> attrs (17.4.0)
> autoflake (0.7)
> awesome-slugify (1.6.5)
> backports.functools-lru-cache (1.5)
> beautifulsoup4 (4.4.1)
> billiard (3.5.0.3)
> boto (2.38.0)
> celery (4.1.0)
> certifi (2018.1.18)
> chardet (3.0.4)
> click (6.7)
> coreapi (2.3.3)
> coreschema (0.0.4)
> coverage (4.4.1)
> cryptography (1.2.3)
> decorator (4.1.2)
> defusedxml (0.4.1)
> diff-match-patch (20121119)
> dj-database-url (0.4.1)
> dj-pagination (2.3.2)
> Django (1.8.19)
> django-activity-stream (0.6.5)
> django-allauth (0.34.0)
> django-appconf (1.0.2)
> django-apptemplates (1.4)
> django-autocomplete-light (2.3.3)
> django-autofixture (0.12.1)
> django-autoslug (1.9.3)
> django-basic-authentication-decorator (0.9)
> django-bootstrap-form (3.3)
> django-bootstrap3-datetimepicker-2 (2.5.0)
> django-braces (1.12.0)
> django-celery-beat (1.1.1)
> django-celery-results (1.0.1)
> django-cors-headers (2.2.0)
> django-cuser (2017.3.16)
> django-downloadview (1.9)
> django-extensions (2.0.3)
> django-filter (1.1.0)
> django-floppyforms (1.7.0)
> django-forms-bootstrap (3.1.0)
> django-friendly-tag-loader (1.2.1)
> django-geoexplorer (4.0.39)
> django-geonode-client (1.0.0)
> django-guardian (1.4.1)
> django-haystack (2.4.1)
> django-import-export (1.0.0)
> django-invitations (1.9.2)
> django-js-asset (1.0.0)
> django-jsonfield (1.0.1)
> django-jsonfield-compat (0.4.4)
> django-leaflet (0.23.0)
> django-model-utils (3.1.1)
> django-modeltranslation (0.12)
> django-mptt (0.9.0)
> django-multi-email-field (0.5.1)
> django-nose (1.4.3)
> django-oauth-toolkit (0.12.0)
> django-polymorphic (1.3)
> django-rest-swagger (2.1.2)
> django-reversion (1.10.0)
> django-simple-history (1.9.0)
> django-storages (1.6.5)
> django-suit (0.2.26)
> django-taggit (0.22.2)
> django-tastypie (0.14.0)
> django-treebeard (4.2.1)
> django-utils (0.0.2)
> djangorestframework (3.8.2)
> djangorestframework-gis (0.12)
> drf-nested-routers (0.90.0)
> drf-openapi (1.3.0)
> elasticsearch (2.4.0)
> enum34 (1.1.2)
> et-xmlfile (1.0.1)
> factory-boy (2.9.2)
> Faker (0.8.4)
> flake8 (2.5.4)
> funcsigs (1.0.2)
> GDAL (1.11.3)
> geolinks (0.2.0)
> GeoNode (2.8)
> geonode-agon-ratings (0.3.8)
> geonode-announcements (1.0.13)
> geonode-arcrest (10.2)
> geonode-avatar (2.1.7)
> geonode-dialogos (0.9)
> geonode-notification (1.1.1)
> geonode-user-messages (0.1.13)
> gisdata (0.5.4)
> glob2 (0.6)
> gn-gsimporter (1.0.2)
> gsconfig (1.0.8)
> html5lib (0.999)
> httplib2 (0.10.3)
> idna (2.6)
> inflection (0.3.1)
> ipaddress (1.0.18)
> itypes (1.1.0)
> jdcal (1.3)
> Jinja2 (2.8)
> kombu (4.1.0)
> lxml (3.5.0)
> Mako (1.0.7)
> Markdown (2.6.6)
> MarkupSafe (0.23)
> mccabe (0.4.0)
> mock (2.0.0)
> more-itertools (4.1.0)
> MultipartPostHandler (0.1.0)
> my-geonode (0.1, /home/user/my_geonode)
> ndg-httpsclient (0.4.0)
> nose (1.3.7)
> numpy (1.11.0)
> oauthlib (2.0.1)
> odfpy (1.3.6)
> openapi-codec (1.3.2)
> openpyxl (2.5.0)
> OWSLib (0.15.0)
> parse (1.8.2)
> parse-type (0.4.1)
> Paver (1.2.1)
> pbr (3.1.1)
> pep8 (1.7.1)
> Pillow (3.1.2)
> Pinax (0.9a2)
> pinax-notifications (4.1.0)
> pinax-theme-bootstrap (8.0.1)
> pip (9.0.3)
> pluggy (0.6.0)
> poster (0.8.1)
> proj (0.1.0)
> psutil (3.4.2)
> psycopg2 (2.7.3.1)
> py (1.5.3)
> pyasn1 (0.1.9)
> pycsw (2.0.3)
> pyelasticsearch (0.6.1)
> pyflakes (1.6.0)
> Pygments (2.1)
> pyOpenSSL (0.15.1)
> pyproj (1.9.5.1)
> pyshp (1.2.12)
> pytest (3.5.0)
> pytest-bdd (2.20.0)
> pytest-django (3.1.2)
> pytest-splinter (1.8.5)
> python-dateutil (2.6.1)
> python-gnupg (0.4.1)
> python-memcached (1.59)
> python-mimeparse (0.1.4)
> python-openid (2.2.5)
> pytz (2014.10)
> PyYAML (3.11)
> regex (2016.1.10)
> requests (2.9.1)
> requests-oauthlib (0.8.0)
> selenium (3.11.0)
> setuptools (20.7.0)
> Shapely (1.5.13)
> simplejson (3.13.2)
> six (1.10.0)
> splinter (0.7.7)
> SQLAlchemy (1.1.14)
> tablib (0.12.1)
> transifex-client (0.11)
> typing (3.6.4)
> ua-parser (0.7.2)
> unicodecsv (0.14.1)
> Unidecode (0.4.19)
> uritemplate (3.0.0)
> urllib3 (1.13.1)
> user-agents (1.1.0)
> vine (1.1.4)
> virtualenv (15.0.1)
> wheel (0.29.0)
> xlrd (1.1.0)
> xlwt (1.3.0)
> xmljson (0.1.9)
> xmltodict (0.9.2)
> Much appreciated for any guidance to work with the latest geonode-project.
> Best regards,
> Seno
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180502/06dedbba/attachment-0001.html>
More information about the geonode-users
