[GeoNode-users] Customizing Geonode (Installed via apt-get) from Geonode-project Dev
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu May 3 13:10:10 PDT 2018
HI Dave Kennewell,
Thank you very much for your help and advices. I was told before that
having both geonode and geonode-project dev/ my_geonode in the same
virtualenv directory would be the best way to go. So, I am installing
geonode 2.8.0 in a fresh Ubuntu 16.04 Virtual Machine following the guide
in here (
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html)
according to Toni Schonbuchner directions and next, I will install
geonode-project dev in the same virtualenv directory, the location of
geonode long-term production.
Thank you all for your help, time and patience.
I appreciated it
Julierme
2018-04-26 1:50 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
> Hi Julierme,
> Well, I learned now just how many Django apps use a sqlite database for
> the backend... sorry about all the noise from that command. The answer was
> actually already there, in the settings.DATABASES variable - "
> /etc/julierme_virtualenv/my_geonode/local/lib/python2.7/site
> -packages/geonode/development.db"
> It seems you're still hitting the geonode development database, your
> settings file is not being picked up by django.
> This is likely some combination of your virtualenv, your wsgi & apache
> setup and your geonode-project template. Honestly this is hard to resolve
> over email, sorry.
> You can either share your code, get someone local who is experienced with
> Django to help, or, if you're on a cloud or virtualised server, rebuild and
> check things step-by-step to see where they go wrong.
> If you are on a virtualised server, and geonode is the only application
> being served from that Operating System, you might want to keep things
> simple and skip the usage of a virtual environment.
> Let us know how you get on
> Dave
> On 23 April 2018 at 18:26, Julierme Pinheiro <juliermeopensourcedeveloper@
> gmail.com> wrote:
>> Hi Dave Kennewell,
>> greetings from Brazil.
>> The grep just finished. The response is many settings. py files.
>> My first attempt, I chose one that is in /etc/julierme_virtualenv/my_ge
>> onode/lib/python2.7/site-packages/pinax/projects/basic_project/
>> I commented out the configuration:
>> #DATABASES = {
>> # "default": {
>> # "ENGINE": "django.db.backends.sqlite3", # Add
>> "postgresql_psycopg2", "postgresql", "mysql", "sqlite3" or "oracle".
>> # "NAME": "dev.db", # Or path to database
>> file if using sqlite3.
>> # "USER": "", # Not used with sqlite3.
>> # "PASSWORD": "", # Not used with sqlite3.
>> # "HOST": "", # Set to empty string
>> for localhost. Not used with sqlite3.
>> # "PORT": "", # Set to empty string
>> for default. Not used with sqlite3.
>> RESPONSE to settings.DATABASES
>> {'default': {'ENGINE': 'django.db.backends.sqlite3', 'ATOMIC_REQUESTS':
>> False, 'CONN_MAX_AGE': 600, 'HOST': '', 'USER': '', 'PASSWORD': '',
>> 'OPTIONS': {}, 'AUTOCOMMIT': True, 'NAME': '/etc/julierme_virtualenv/my_g
>> eonode/local/lib/python2.7/site-packages/geonode/development.db',
>> 'TIME_ZONE': 'UTC', 'PORT': '', 'TEST': {'COLLATION': None, 'CHARSET':
>> None, 'NAME': None, 'MIRROR': None}}}
>> Second attempt:
>> DATABASES = {
>> "default": {
>> "ENGINE": "django.db.backends.postgresql_psycopg2",
>> # Add "postgresql_psycopg2", "postgresql", "mysql", "sqlite3" or "oracle".
>> "NAME": "geonode",
>> # Or path to database file if using sqlite3.
>> "USER": "geonode",
>> "PASSWORD": "DBImAITC",
>> "HOST": "localhost",
>> # Set to empty string for localhost. Not used with
>> sqlite3.
>> "PORT": "5432",
>> # Set to empty
>> string for default. Not used with sqlite3.
>> Bellow find the response to the whole < grep -r
>> "django.db.backends.sqlite3" "/" > command. Do you suggest a change for any
>> of the settings.py listed in the grep?
>> /etc/... is related to my_geonode (Geonode-Project Dev) and /usr/... is
>> related to my Geonode (Apt-get) long-term project.
>> Binary file /etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_database_url.pyc
>> matches
>> ges/oauth2_provider/tests/settings.pyc matches
>> ges/oauth2_provider/tests/settings.py: 'ENGINE':
>> ges/rest_framework_nested/runtests/settings.pyc matches
>> ges/rest_framework_nested/runtests/settings.py: 'ENGINE':
>> 'django.db.backends.sqlite3', # 'postgresql_psycopg2', 'postgresql',
>> 'mysql', 'sqlite3', 'oracle'.
>> ges/Django-1.8.19.dist-info/RECORD:django/db/backends/
>> sqlite3/__init__.py,sha256=47DEQpj8HBSa-_TImW-5JCeuQeRkm5NMpJWZG3hSuFU,0
>> sqlite3/base.py,sha256=Pe0K8CP7vI_7ZvzdqfIxlYESjVGU-TAU5LUhX2rDtk0,17462
>> sqlite3/client.py,sha256=Rg8Bwfj68kI78bjH2bEDQfAL008rCegtk7gIqg3NpFU,305
>> sqlite3/creation.py,sha256=7byYbLiaJKs7yvTLkMa36J2eD7kPlHBOV
>> a8mvpBRq7U,3297
>> sqlite3/features.py,sha256=G9NPPhgpknJBUrj0-pn8tHgBO5Thge
>> W6HEJ1KwdXshw,2631
>> sqlite3/introspection.py,sha256=ROCqblFqWMBo4AhqHTKNZq5
>> BRFy_2LguFd9AEmSwn20,11019
>> sqlite3/operations.py,sha256=Ov8yrILHFrmWiNU3E3PHmDjny2QgL16
>> ujUk9OWazEi0,8655
>> sqlite3/schema.py,sha256=uvPssUfC8DxEzhgNkwgOBcMFmsTdw69hyxa
>> p_GvGpJg,11377
>> sqlite3/utils.py,sha256=x1hTKZrG2MkU5f7HUGnVXE3tJWXT4J6C528QzSAB03Q,389
>> ges/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/base.pyc,,
>> sqlite3/operations.pyc,,
>> sqlite3/introspection.pyc,,
>> sqlite3/schema.pyc,,
>> sqlite3/client.pyc,,
>> sqlite3/features.pyc,,
>> sqlite3/__init__.pyc,,
>> ges/Django-1.8.19.dist-info/RECORD:django/db/backends/sqlite3/utils.pyc,,
>> sqlite3/creation.pyc,,
>> ges/treebeard/tests/settings.pyc matches
>> ges/treebeard/tests/settings.py: 'ENGINE':
>> Binary file /etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/testproject/settings.pyc
>> matches
>> ges/testproject/settings.py: 'ENGINE':
>> ges/geonode/contrib/geosites/README.md: 'ENGINE':
>> ges/geonode/contrib/geosites/site_template/local_settings_template.py:
>> ges/geonode/geoserver/tests.pyc matches
>> ges/geonode/geoserver/tests.py: 'ENGINE':
>> ges/geonode/tests/bdd/conftest.py: 'ENGINE':
>> ges/geonode/tests/bdd/conftest.pyc matches
>> /etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/dj_database_url.py:
>> 'sqlite': 'django.db.backends.sqlite3',
>> ges/dj_pagination/tests/settings.pyc matches
>> ges/dj_pagination/tests/settings.py: 'ENGINE':
>> ges/pinax/projects/static_project/settings.pyc matches
>> ges/pinax/projects/static_project/settings.py: "ENGINE":
>> "django.db.backends.sqlite3", # Add "postgresql_psycopg2", "postgresql",
>> ges/pinax/projects/zero_project/settings.pyc matches
>> ges/pinax/projects/zero_project/settings.py: "ENGINE":
>> ges/pinax/projects/account_project/settings.pyc matches
>> ges/pinax/projects/account_project/settings.py: "ENGINE":
>> ges/pinax/projects/basic_project/settings.pyc matches
>> ges/pinax/projects/basic_project/settings.py: "ENGINE":
>> Binary file /etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/db_reuse.pyc
>> matches
>> ges/pytest_django/live_server_helper.pyc matches
>> ges/pytest_django/db_reuse.py: if connection.settings_dict['ENGINE']
>> == 'django.db.backends.sqlite3':
>> ges/pytest_django/live_server_helper.py: if
>> (conn.settings_dict['ENGINE'] == 'django.db.backends.sqlite3' and
>> ges/pytest_django/fixtures.py: if db_settings['ENGINE'] ==
>> Binary file /etc/julierme_virtualenv/my_geonode/lib/python2.7/site-packages/pytest_django/fixtures.pyc
>> matches
>> ges/actstream/runtests/settings.pyc matches
>> ges/actstream/runtests/manage.pyc matches
>> ges/actstream/runtests/settings.py:ENGINE =
>> os.environ.get('DATABASE_ENGINE', 'django.db.backends.sqlite3')
>> ges/actstream/runtests/manage.py:engine = os.environ.get('DATABASE_ENGINE',
>> ges/actstream/runtests/manage.py: engine =
>> ges/django/db/backends/sqlite3/__init__.pyc matches
>> ges/django/db/backends/sqlite3/schema.pyc matches
>> ges/django/db/backends/sqlite3/base.pyc matches
>> ges/django/db/backends/sqlite3/features.pyc matches
>> ges/django/db/backends/sqlite3/client.pyc matches
>> ges/django/db/backends/sqlite3/introspection.pyc matches
>> ges/django/db/backends/sqlite3/operations.pyc matches
>> ges/django/db/backends/sqlite3/utils.pyc matches
>> ges/django/db/backends/sqlite3/creation.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/features.py:from
>> django.db.backends.sqlite3.features import \
>> ges/django/contrib/gis/db/backends/spatialite/base.py:from
>> django.db.backends.sqlite3.base import (
>> ges/django/contrib/gis/db/backends/spatialite/introspection.py:from
>> django.db.backends.sqlite3.introspection import (
>> ges/django/contrib/gis/db/backends/spatialite/client.py:from
>> django.db.backends.sqlite3.client import DatabaseClient
>> ges/django/contrib/gis/db/backends/spatialite/operations.py:from
>> django.db.backends.sqlite3.operations import DatabaseOperations
>> ges/django/contrib/gis/db/backends/spatialite/schema.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/base.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/adapter.py:from
>> django.db.backends.sqlite3.base import Database
>> ges/django/contrib/gis/db/backends/spatialite/adapter.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/schema.py:from
>> django.db.backends.sqlite3.schema import DatabaseSchemaEditor
>> ges/django/contrib/gis/db/backends/spatialite/features.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/client.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/introspection.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/operations.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/creation.pyc matches
>> ges/django/contrib/gis/db/backends/spatialite/creation.py:from
>> django.db.backends.sqlite3.creation import DatabaseCreation
>> ges/django/conf/project_template/project_name/settings.pyc matches
>> ges/django/conf/project_template/project_name/settings.py:
>> grep: /run/user/1000/gvfs: Permission denied
>> Binary file /run/log/journal/18ac8792d324491caeaf131039b9cd97/system.journal
>> matches
>> /usr/local/lib/python2.7/dist-packages/geonode/contrib/geosites/README.md:
>> tes/site_template/local_settings_template.py: 'ENGINE':
>> Binary file /usr/local/lib/python2.7/dist-packages/geonode/geoserver/tests.pyc
>> matches
>> /usr/local/lib/python2.7/dist-packages/geonode/geoserver/tests.py:
>> /usr/local/lib/python2.7/dist-packages/geonode/tests/bdd/conftest.py:
>> Binary file /usr/local/lib/python2.7/dist-packages/geonode/tests/bdd/conftest.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/dj_database_url.pyc matches
>> Binary file /usr/lib/python2.7/dist-packages/oauth2_provider/tests/settings.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/oauth2_provider/tests/settings.py:
>> Binary file /usr/lib/python2.7/dist-packages/rest_framework_nested/runtests/settings.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/rest_framework_nested/runtests/settings.py:
>> 'ENGINE': 'django.db.backends.sqlite3', # 'postgresql_psycopg2',
>> 'postgresql', 'mysql', 'sqlite3', 'oracle'.
>> Binary file /usr/lib/python2.7/dist-packages/treebeard/tests/settings.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/treebeard/tests/settings.py:
>> Binary file /usr/lib/python2.7/dist-packages/testproject/settings.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/testproject/settings.py:
>> /usr/lib/python2.7/dist-packages/dj_database_url.py: 'sqlite':
>> Binary file /usr/lib/python2.7/dist-packages/dj_pagination/tests/settings.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/dj_pagination/tests/settings.py:
>> Binary file /usr/lib/python2.7/dist-packages/actstream/runtests/settings.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/actstream/runtests/manage.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/actstream/runtests/settings.py:ENGINE =
>> /usr/lib/python2.7/dist-packages/actstream/runtests/manage.py:engine =
>> /usr/lib/python2.7/dist-packages/actstream/runtests/manage.py: engine
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/__init__.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/schema.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/features.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/client.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/introspection.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/operations.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/utils.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/db/backends/sqlite3/creation.pyc
>> matches
>> /usr/lib/python2.7/dist-packages/django/contrib/gis/db/
>> backends/spatialite/features.py:from django.db.backends.sqlite3.features
>> import \
>> backends/spatialite/base.py:from django.db.backends.sqlite3.base import (
>> backends/spatialite/introspection.py:from django.db.backends.sqlite3.introspection
>> import (
>> backends/spatialite/client.py:from django.db.backends.sqlite3.client
>> backends/spatialite/operations.py:from django.db.backends.sqlite3.operations
>> Binary file /usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/schema.pyc
>> matches
>> Binary file /usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/base.pyc
>> matches
>> backends/spatialite/adapter.py:from django.db.backends.sqlite3.base
>> import Database
>> backends/spatialite/schema.py:from django.db.backends.sqlite3.schema
>> Binary file /usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/spatialite/client.pyc
>> matches
>> backends/spatialite/creation.py:from django.db.backends.sqlite3.creation
>> Binary file /usr/lib/python2.7/dist-packages/django/conf/project_template/project_name/settings.pyc
>> matches
>> e/project_name/settings.py: 'ENGINE':
>> Thank you for your time and help.
>> Best regards
>> Julierme
>> 2018-04-19 12:03 GMT-03:00 Dave Kennewell <davekennewell at gmail.com>:
>>> OK, great Julierme, we're getting there!
>>> I'm guessing you want to run Django & geonode from this virtualenv, so
>>> let's figure that out.
>>> You need to find in which settings file sets the
>>> "django.db.backends.sqlite3" in your code, and then comment this section
>>> out.
>>> If you can't find it, try something like:
>>> grep -r "django.db.backends.sqlite3" "/"
>>> which will search all files under your root directory "/" for this text.
>>> You might need a coffee while you wait, and might need to use sudo to avoid
>>> getting a bunch of "permission denied" messages.
>>> On 19 April 2018 at 18:42, Julierme Pinheiro <
>>> juliermeopensourcedeveloper at gmail.com> wrote:
>>>> Looking at the ALLOWED_HOSTS and PROXY_ALLOWED_HOSTS in the settings.py
>>>> in my_geonode (Geonode-project DEV)
>>>> ALLOWED_HOSTS = ['localhost', 'django', '172.21.14.45'] if
>>>> os.getenv('ALLOWED_HOSTS') is None \
>>>> else re.split(r' *[,|:|;] *', os.getenv('ALLOWED_HOSTS'))
>>>> PROXY_ALLOWED_HOSTS += ('nominatim.openstreetmap.org', '172.21.14.45',)
>>>> I am not sure if that configuration is missing something.
>>>> Kind regards
>>>> Julierme
>>>> 2018-04-19 11:17 GMT-03:00 Julierme Pinheiro <
>>>> juliermeopensourcedeveloper at gmail.com>:
>>>>> Dear Toni Schonbuchner and Dave Kennewell,
>>>>> Thank you very much for your reply.
>>>>> First if I did not misunderstand Toni suggestion, I tried the
>>>>> following:
>>>>> *1 - Commenting out <# ENGINE': '', # Empty ENGINE name disables> from
>>>>> local_settings.py in my_geonode (Geonode-Project Dev virtualenv)*
>>>>> Result: the problem remains
>>>>> *2 - Uncommenting out < ENGINE': '', # Empty ENGINE name disables>
>>>>> from local_settings.py in my_geonode (Geonode-Project Dev virtualenv) and
>>>>> inserting the line < ENGINE': '', # Empty ENGINE name disables> in
>>>>> local_settings.py from Geonode (Geonode apt-get)*.
>>>>> However, I got a new response to Dave Kennewell suggestion after
>>>>> activating my_geonode virtualenv:
>>>>> *settings.DATABASES*
>>>>> 'ATOMIC_REQUESTS': False, 'CONN_MAX_AGE': 600, 'HOST': '', 'USER': '',
>>>>> 'PASSWORD': '', 'OPTIONS': {}, 'AUTOCOMMIT': True, 'NAME':
>>>>> '/etc/julierme_virtualenv/my_geonode/local/lib/python2.7/sit
>>>>> e-packages/geonode/development.db', 'TIME_ZONE': 'UTC', 'PORT': '',
>>>>> 'TEST': {'COLLATION': None, 'CHARSET': None, 'NAME': None, 'MIRROR': None}}}
>>>>> I think there is no database being used.
>>>>> I also have to make some few notes:
>>>>> *1 - ALLOWED_HOSTS, PROXY_ALLOWED_HOSTS and POSTGIS_VERSION are
>>>>> commented out in local_settings.py in my_geonode (Geonode-Project Dev)*
>>>>> *2 - Geoserver Port is 8080 in Geonode(apt-get) and 6060 in
>>>>> my_geonode(Geonode-Project Dev), but both are running fine.*
>>>>> Thank you very much for your time and patience.
>>>>> I appreciated it.
>>>>> Julierme
>>>>> 2018-04-19 4:29 GMT-03:00 Toni Schönbuchner <
>>>>> toni.schoenbuchner at csgis.de>:
>>>>>> Dear Julierme,
>>>>>> I haven´t followed the whole thread but have a look at this comment:
>>>>>> 'ENGINE': '', # Empty ENGINE name disables
>>>>>> See if things change if you set ENGINE to geonode in your project.
>>>>>> Best regards,
>>>>>> Toni
>>>>>> CSGIS
>>>>>> Kolonnadenstraße 1
>>>>>> <https://maps.google.com/?q=Kolonnadenstra%C3%9Fe+1+04109+Leipzig&entry=gmail&source=g>
>>>>>> 04109 Leipzig
>>>>>> Mobil +49/ (0) 176 6680 3198
>>>>>> Tel +49/ (0) 341 24 04 738
>>>>>> Fax +49/ (0) 341 24 04 73
>>>>>> Web http://csgis.de
>>>>>> Hinweis gemäß § 33 BDSG
>>>>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument
>>>>>> ist ausschließlich für den
>>>>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>>>>> diese E-Mail versehentlich
>>>>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>>>>> löschen Sie diese Nachricht
>>>>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>>>>> Vervielfältigung, Veränderung,
>>>>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>>>>> Am 18.04.2018 um 21:13 schrieb geonode-users-request at lists.osgeo.org:
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180503/29d6970d/attachment-0001.html>
More information about the geonode-users
