[GeoNode-users] Resilient hosting of GeoNode
Paolo Pasquali
paolo.pasquali at ithaca.polito.it
Fri May 25 06:01:55 PDT 2018
Hi Alessio,
As I understand the backup/restore procedure works fine in some conditions:
good bandwidth, one-way sync, limited amount of data to transfer.
My scenario is similar to Jac's. Due to the poor bandwidth is more
efficient to work on a local network GeoNode and then sometimes update the
public instance in the cloud (probably on demand).
The public instance can be updated as well by users external to the
organization so a one way sync could not be enough.
While we can avoid transferring every time huge raster files (e.g. aerial
images, DSM, old scanned maps), pyramids and cache, a mechanism for a
two-way sync should be put in place.
What about adopting different workspaces for users internal and external to
the organization and by this select the data to transfer. So, I mean always
uploading data for a workspace, always downloading for another and syncing
the GeoNode db with same criteria.
Do you think it can be feasible?
Or, is working on data differences an option?
Thanks for your help.
Ciao
P.
On Fri, May 25, 2018 at 2:00 PM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> I'd suggest the backup and restore procedure of GeoNode, which dumps
> almost everything you need and restores it also. (it is worth to do tests
> first with a dev version, mostly on the restore procedure)
> You can use a bash script like this to perform the backups
> https://bpaste.net/show/9e3e7b57995d
> And a script like this to perform the restore
> https://bpaste.net/show/683be2d8c3c8
> The settings must be customized for both prod and dev. On the above
> example I put them into a backup folder, and they look more or less like
> this
> https://bpaste.net/show/2e81d6292274
> Things to notice on the settings are:
> 1. GeoServer Data Dir must be accessible and writable by the Tomcat user
> daemon and the user running the script. Also you need to provide correct
> path in both cases, prod and dev
> 2. apps and dumps must be aligned (dumps are just the names of the dump
> files); you can customize the apps modules as you need, accordingly on what
> you want to backup/restore
> 2018-05-25 13:47 GMT+02:00 Carol Kraemer <ckraemer at itos.uga.edu>:
>> Nifty idea, Jac. Thank you for sharing here and I’d be interested to hear
>> the solution as well.
>> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
>> Behalf Of *Jac Steiner
>> *Sent:* Thursday, May 24, 2018 5:54 PM
>> *To:* geonode-users <geonode-users at lists.osgeo.org>
>> *Subject:* [GeoNode-users] Resilient hosting of GeoNode
>> I'm working with a government that presently has a GeoNode instance
>> installed locally and accessible publicly from the internet. This is
>> fragile due to infrastructure weaknesses on premises (e.g. unreliable
>> power). I'm considering recommending they move to an instance of GeoNode
>> installed in the cloud (perhaps AWS, but a managed solution would be
>> ideal). This instance would be locally mirrored on site using their current
>> hardware. The local mirror is essential redundancy to accommodate scenarios
>> where the internet may go down (e.g. emergency management). The local
>> mirror should remain relatively in-sync with the cloud master, but
>> infrequent synching, perhaps once a day, should sufficiently cover the
>> anticipated usage patterns.
>> I figure the devil is in the details here, as in a genuine emergency, if
>> the internet is down and changes are being made locally directly on the
>> mirror, once internet is back, the synching strategy with the master
>> suddenly gets complicated.
>> I'm not able to find examples of this type of setup in the docs or
>> otherwise. As I'm not a sys admin, I may be using the wrong search terms.
>> Can someone point me toward resources that provide further details on
>> implementing this type of strategy and best practices? If anyone has
>> additional relevant insights they can share, I'd greatly appreciate it.
>> Appreciate your help.
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180525/2485a82b/attachment-0001.html>
More information about the geonode-users
