[GeoNode-users] [GeoNode-devel] GeoNode WorldMap client to be part of GeoNode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu May 31 00:59:52 PDT 2018
I have taken a look at the PR and it looks good to me.
The module is a contrib module not enabled by default and therefore not
affecting the core functionalities at all.
Also there are not schema changes on the GeoNode core. Moreover there are a
lot of improvements on translations.
That said, if no other objection. I am +1 on merging the PR and start the
release process ASAP.
Let's wait for other feedbacks.
Thanks Paolo!
2018-05-31 9:03 GMT+02:00 Dimitris Kar <dkarakostis at gmail.com>:
> Thanks Paolo,
> Great contribution.
> On Thu, May 31, 2018 at 8:08 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Great! Thanks Paolo
>> 2018-05-30 21:20 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>> I forgot to mention that this client extends the GeoNode serialization
>>> format. Therefore maps whic are created using the WorldMap client will
>>> not
>>> be compatible with the default GeoNode client. It should be simple anyway
>>> to write a Django command which converts maps back and forth
>>> best
>>> Paolo
>>> On Wed, May 30, 2018 at 3:14 PM Paolo Corti <pcorti at gmail.com> wrote:
>>> > Dear GeoNode users and developers
>>> > Earlier today I sent a pull request [1] vs the 2.7.x GeoNode branch (to
>>> > become GeoNode 2.8.1), which implements this GNIP [2]. This pull
>>> request
>>> > introduce the Harvard WorldMap contribute application in GeoNode.
>>> > You can have a full list of the features introduced from the
>>> application
>>> at
>>> > [2]. In brief this application introduce a new client, based on an
>>> improved
>>> > version of the GeoExplorer default client, with additional features
>>> such
>>> as:
>>> > * layer categories in table of contents
>>> > * layer graduated style editor
>>> > * a find place widget and layers gazetteer
>>> > * feature search
>>> > * map revisions
>>> > * URL permalink for maps
>>> > * layer search with Hypermap Registry (optional)
>>> > The application is optional and does not introduce any change in
>>> existing
>>> > GeoNode tables. If enabled, it will create a few new tables in GeoNode
>>> > database, which are needed in order for the application to work. You
>>> must
>>> > use PostgreSQL to use this application, and PostgreSQL will require the
>>> > PostGIS and dblink extensions.
>>> > The GNIP implementation is based on current GeoNode WorldMap source
>>> code
>>> > [3], and contains code committed by a number of GeoNode developers:
>>> > * Matt Bertrand
>>> > * Paolo Corti
>>> > * Wayner Barrios
>>> > * Jorge Martínez Gómez
>>> > * Lennin Suescun
>>> > * 刘尧 aka Lanni
>>> > If there is consensus, this application will be merged in GeoNode
>>> source
>>> > code as a contribute module.
>>> > Thanks
>>> > Paolo
>>> > [1] https://github.com/GeoNode/geonode/pull/3817
>>> > [2] https://github.com/GeoNode/geonode/issues/3718
>>> > [3] https://github.com/cga-harvard/geonode/tree/worldmap-2.7.x
>>> > Paolo Corti
>>> > Geospatial software developer
>>> > web: http://www.paolocorti.net
>>> > twitter: @capooti
>>> > skype: capooti
>>> Paolo Corti
>>> twitter: @capooti
>>> skype: capooti
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180531/dfdd54d7/attachment.html>
More information about the geonode-users mailing list
