[GeoNode-users] ➜ Two ansible playbooks
Ana Boljevic ana.boljevic at cedis.me
Fri Nov 2 14:17:47 PDT 2018
Dear Toni,
Congratulations!
So do you suggest to install/try first: 2.8 or master?
Another question: do you have guide for installing Mapstore2/Leaflet into your appliance ?
Kind regards,
Ana :)
-------- Original message --------
From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
Date: 11/2/18 08:24 (GMT+01:00)
To: geonode-users <geonode-users at lists.osgeo.org>, geonode-devel <geonode-devel at lists.osgeo.org>
Cc: "Lian Feng (lfeng)" <lfeng at memphis.edu>
Subject: [GeoNode-users] ➜ Two ansible playbooks
Dear Community,
find here two new Ansible playbooks: https://github.com/csgis/geonode_ansible
which will install/configure geonode 2.8 or master (different branches) on an Ubuntu
instance. The Setup uses geonode_project, plus the full Tomcat, Apache … stack.
These Tasks-only playbooks can be used for a quick hit and run
and do not offer any code reuse opportunities by definition of roles or best practices
like Ansible directory layout ...
On the other hand they stay close to the official documentation. Hence it should
be easy for you to understand what’s happening why and when.
To get in running (check README)
1) install Ansible [1]
2) clone the repository
3) check that your instance can be reached by use of ssh key auth and that python Is installed.
4) setup your instance in the host file
5) adjust the vars like Geoserver password etc. to your needs
6) get a cup of coffee and let Ansible do the hard work.
7) Ansible will fail fast if something goes wrong if not log in with admin/admin and test.
I´ve tested the playbooks locally and at some AWS Instances
feedback, problems etc. very welcome !
Cheers,
– Toni
[1] If you never heard about it, ansible is an orchestration software for servers.
The software runs defined tasks against one or many instances, Installation:
https://docs.ansible.com/ansible/latest/installation_guide/intro_installation.html
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil +49/ (0) 176 6680 3198
Tel  +49/ (0) 341 24 04 738
Fax  +49/ (0) 341 24 04 73
Web http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181102/b5d74641/attachment.html>
More information about the geonode-users mailing list
