[GeoNode-users] ➜ Two ansible playbooks
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Sat Nov 3 12:02:42 PDT 2018
Hi Ana,
> Before installing Geonode 2.8 with ansible playsbooks, let me ask you is Geonode importer fixed in Geonode 2.8 installed with ansible?
The ansible playbook installs GeoNode in its standard configuration.
Unfortunately I cannot say if this issue still exist. But as with the viewer hooksets
you could just change the setup for your needs after installation. For example
integrate osgeo-importer as alternative.
https://github.com/GeoNode/django-osgeo-importer <https://github.com/GeoNode/django-osgeo-importer>
> Another question is should I install ansible on separate VM or could it be on the same machine with Geonode ?
You would install ansible on your local computer.
Define your target server(s) in the host file (valid user and ssh key needed.)
Then ansible logs into your server and installs everything.
I highly recommend to visit the official ansible documentation.
Normally its used to orchestrate a whole bunch of instances.
For example you could check for updates, change user permissions
or whatever your needs on your whole server infrastructure
In one shot.
https://www.ansible.com/resources/videos/quick-start-video
https://docs.ansible.com/ansible/latest/index.html <https://docs.ansible.com/ansible/latest/index.html>
> I don't see in your guide how to choose Branch: 2.8 or Master ?
It´s just the other branch.
For master: git clone https://github.com/csgis/geonode_ansible <https://github.com/csgis/geonode_ansible>
For 2.8: git clone https://github.com/csgis/geonode_ansible <https://github.com/csgis/geonode_ansible> -b 2.8
Somewhere in issues I’ve read that master (2.10 rc4) can be seen as
stable means its worth to give the master branch a try.
Cheers,
Toni
> Am 03.11.2018 um 19:29 schrieb Ana Boljevic <ana.boljevic at cedis.me>:
> Dear Toni,
> Before installing Geonode 2.8 with ansible playsbooks, let me ask you is Geonode importer fixed in Geonode 2.8 installed with ansible? Because I think that this issue (importing of kml files) still remains on regular Geonode 2.8 stable:
> https://lists.osgeo.org/pipermail/geonode-users/2018-April/004230.html <https://lists.osgeo.org/pipermail/geonode-users/2018-April/004230.html>
> Regards,
> Ana
> -------- Original message --------
> From: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> Date: 11/3/18 10:26 (GMT+01:00)
> To: Ana Boljevic <ana.boljevic at cedis.me>
> Cc: geonode-users <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] ➜ Two ansible playbooks
> Hi Ana,
>> So do you suggest to install/try first: 2.8 or master?
> For production I personally stick with 2.8 as master is to volatile.
> But for a test run I would currently suggest the master branch.
> (Reason: https://github.com/GeoNode/geonode-project/issues/49 <https://github.com/GeoNode/geonode-project/issues/49>)
>> Another question: do you have guide for installing Mapstore2/Leaflet into your appliance ?
> The ansible Playbook just automates all required steps from the official
> Ubuntu Install-Documentation:
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>
> Hence you end up with a server instance which you can adjust to
> your needs just SSH into it. By default the playbook installs geonode in the users home dir:
> https://github.com/csgis/geonode_ansible/blob/master/group_vars/all#L17 <https://github.com/csgis/geonode_ansible/blob/master/group_vars/all#L17>
> Then adding MapStore is quite simple:
> https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango <https://github.com/geosolutions-it/geonode-mapstore-client#integrating-into-geonodedjango>
> Leaflet as well, just enable the leaflet_hookset (comment the others)
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L1223 <https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L1223>
> Of course both steps could be automated with ansible as well.
> One would change the local_settings template, which is copied on build
> and in case of MapStore extend the pip install step.
> Cheers,
> Toni
>> Am 02.11.2018 um 22:17 schrieb Ana Boljevic <ana.boljevic at cedis.me <mailto:ana.boljevic at cedis.me>>:
>> Dear Toni,
>> Congratulations!
>> Kind regards,
>> Ana :)
>> From: Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>>
>> Date: 11/2/18 08:24 (GMT+01:00)
>> To: geonode-users <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>, geonode-devel <geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>>
>> Cc: "Lian Feng (lfeng)" <lfeng at memphis.edu <mailto:lfeng at memphis.edu>>
>> Subject: [GeoNode-users] ➜ Two ansible playbooks
>> Dear Community,
>> find here two new Ansible playbooks: https://github.com/csgis/geonode_ansible <https://github.com/csgis/geonode_ansible>
>> which will install/configure geonode 2.8 or master (different branches) on an Ubuntu
>> instance. The Setup uses geonode_project, plus the full Tomcat, Apache … stack.
>> These Tasks-only playbooks can be used for a quick hit and run
>> and do not offer any code reuse opportunities by definition of roles or best practices
>> like Ansible directory layout ...
>> On the other hand they stay close to the official documentation. Hence it should
>> be easy for you to understand what’s happening why and when.
>> To get in running (check README)
>> 1) install Ansible [1]
>> 2) clone the repository
>> 3) check that your instance can be reached by use of ssh key auth and that python Is installed.
>> 4) setup your instance in the host file
>> 5) adjust the vars like Geoserver password etc. to your needs
>> 6) get a cup of coffee and let Ansible do the hard work.
>> 7) Ansible will fail fast if something goes wrong if not log in with admin/admin and test.
>> I´ve tested the playbooks locally and at some AWS Instances
>> feedback, problems etc. very welcome !
>> Cheers,
>> – Toni
>> [1] If you never heard about it, ansible is an orchestration software for servers.
>> The software runs defined tasks against one or many instances, Installation:
>> https://docs.ansible.com/ansible/latest/installation_guide/intro_installation.html <https://docs.ansible.com/ansible/latest/installation_guide/intro_installation.html>
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198
>> Tel +49/ (0) 341 24 04 738
>> Fax +49/ (0) 341 24 04 73
>> Web http://csgis.de <http://csgis.de/>
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181103/32174906/attachment.html>
More information about the geonode-users
