[GeoNode-users] Best way to install geonode
Annalisa Schiavon
annalisa.schiavon at gmail.com
Fri Nov 9 05:39:29 PST 2018
Hi Alessio,
the first time I chose a different password for DB's geonode user. Than I
change it to geonode in Postgres and run again the paver commands. But
something is still wrong.
local_settings seems correct now, maybe it's better if I start to install
from a clean server.
Can I follow
http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
to install Geonode 2.8 on Ubuntu 16.04 or is outdated/wrong ?
Because I could install a VM in my local VirtualBox (in ubuntu client
16.04) and than test it locally, before migrate the virtual machine in
VMWARE, it will more simple for me, but I can't with Ubuntu 18.04.
Moreover, I have some difficulties with Postgres 10, I'd prefer 9.5.
Thanks again,
Annalisa
Il giorno ven 9 nov 2018 alle ore 13:19 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hai Annalisa,
> it looks to me that you haven't correctly setup the local_settings.py
> environment variables before running the paver commands.
> Please double check you have a DB installed with the correct
> username/password and that the info on local_settings file are correct.
> Il giorno ven 9 nov 2018 alle ore 12:24 Annalisa Schiavon <
> annalisa.schiavon at gmail.com> ha scritto:
>> Hi Alessio,
>> I've tried to follow your document: "GeoNode 2.9.x -Deployment on Ubuntu
>> 18.04" (
>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
>> I've installed a brand new ubuntu 18.04 server on our WMWARE.
>> When I run the command
>> (geonode) system at gaia:~/geonode$ sudo WORKON_HOME=/home/system/Envs/geonode DJANGO_SETTINGS_MODULE=geonode.local_settings GEONODE_ETC=/home/system/geonode/geonode GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip -p 192.168.31.80
>> I have many errors like:
>> django.db.utils.ProgrammingError: relation "django_site" does not existLINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
>> and I see that my geonode DB is empty!
>> I tried to run again
>> DJANGO_SETTINGS_MODULE=geonode.local_settings paver reset; \
>> paver setup; \
>> paver sync; \
>> python manage.py collectstatic --noinput
>> I get an error on reset:
>> [Errno 3] No such process
>> ---> pavement.stop_qgis_server
>> but nothing else.
>> I've have no experience with Virtual Env, so I wonder if all command after
>> mkvirtualenv --no-site-packages geonode
>> are to run in virtual env or not.
>> I found another error after running " pip install -r requirements.txt
>> --upgrade--no-cache --no-cache-dir ":
>> Command "python setup.py egg_info" failed with error code 1 in
>> /tmp/pip-install-6qw4Pu/Twisted/
>> Any suggestions?
>> Annalisa
>> Il giorno ven 26 ott 2018 alle ore 16:38 Alessio Fabiani <
>>> Uhm... well, that command should install the GeoNode dependencies. Maybe
>>> this is the reason why you are not able to find some packages.
>>> Anyway, you must run paver reset from the "my_geonode" root folder,
>>> where the "pavement.py" file is located. If you already did that, then I
>>> guess your installation is a bit messed up.
>>> Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <pfrias82 at gmail.com>
>>> ha scritto:
>>>> Yes, but after that I had to downgrade some python packages.
>>>> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> From the link you sent to me, did you run also this one?
>>>>> pip install -e . --upgrade
>>>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <
>>>>> pfrias82 at gmail.com> ha scritto:
>>>>>> I've followed this instructions
>>>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>>>>> After "pip install Paver==1.2.4"
>>>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>>>>> reset
>>>>>> Build failed: Unknown task: reset
>>>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>>>> However, it seems to me that the issue is related to a missing
>>>>>>> dependency.
>>>>>>> Try maybe by typing
>>>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>>>>>> Hi Alessio,
>>>>>>>> The (pip install -r requirements.txt --upgrade) worked fine after
>>>>>>>> another try.
>>>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>>>> This is the error produced:
>>>>>>>> paver reset
>>>>>>>> Traceback (most recent call last):
>>>>>>>> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line
>>>>>>>> 7, in <module>
>>>>>>>> from paver.tasks import main
>>>>>>>> ImportError: No module named paver.tasks
>>>>>>>> Any idea how to solve this?
>>>>>>>> Thanks,
>>>>>>>> Paulo
>>>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>>>> Hi Paulo,
>>>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>>>> That command should just start downloading the Python
>>>>>>>>> dependencies. If it is stuck, most probably there's a problem reaching the
>>>>>>>>> PyPi repositories.
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial
>>>>>>>>>> you recommended (
>>>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>>>> Can you help me with some possible solution?
>>>>>>>>>> Thanks,
>>>>>>>>>> Paulo Frias
>>>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>>>> Hi Julierme,
>>>>>>>>>>> please see my responses below.
>>>>>>>>>>> "1 - can I make geonode-project my production environment? I
>>>>>>>>>>> meant run GeoNode-Project as my production instance on the web."
>>>>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>>>>> case though.
>>>>>>>>>>> "2 - do I need GeoNode Core to run together with
>>>>>>>>>>> GeoNode-Project?"
>>>>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until
>>>>>>>>>>> we do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>>>>>> Core?"
>>>>>>>>>>> geonode-project runs independently, but it still needs
>>>>>>>>>>> geonode as a dependency. However by using it, you won't touch the
>>>>>>>>>>> geonode-core. This will allow you to easily keep it up to date with the
>>>>>>>>>>> development version, without clashes.
>>>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>>>> The tutorial and the documentation in general is outdated. We
>>>>>>>>>>> are lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>>>> We will try to do it when we start officially the release
>>>>>>>>>>> process.
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>>>> look.
>>>>>>>>>>>> Now:
>>>>>>>>>>>> GeoNode-Project?
>>>>>>>>>>>> Core?
>>>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>>>> Kind regards
>>>>>>>>>>>> Julierme
>>>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>>>>>> buggy and unstable one.
>>>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way
>>>>>>>>>>>>>> to customize the interface, at least some part of it, without the need of
>>>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin
>>>>>>>>>>>>>> gui.
>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>>>> So you advise against the deb package installation, also if
>>>>>>>>>>>>>>> I don't think to develop on geonode, only to customize the look?
>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>>>>> Please someone may confirm that installation by deb
>>>>>>>>>>>>>>>>> packages, with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>>>>>>>>>>>>>>>>> now?)
>>>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon
>>>>>>>>>>>>>>>>> <annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04,
>>>>>>>>>>>>>>>>>> installed via apt-get, following these commands:
>>>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>>>> This email is intended only for the person or entity to
>>>>>>>>>>>>>>>> which it is addressed and may contain information that is privileged,
>>>>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> notizia.
>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/fa8eb75a/attachment-0001.html>
More information about the geonode-users
