[GeoNode-users] Best way to install geonode
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Nov 9 04:19:39 PST 2018
Hai Annalisa,
it looks to me that you haven't correctly setup the local_settings.py
environment variables before running the paver commands.
Please double check you have a DB installed with the correct
username/password and that the info on local_settings file are correct.
Il giorno ven 9 nov 2018 alle ore 12:24 Annalisa Schiavon <
annalisa.schiavon at gmail.com> ha scritto:
> Hi Alessio,
> I've tried to follow your document: "GeoNode 2.9.x -Deployment on Ubuntu
> 18.04" (
> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
> I've installed a brand new ubuntu 18.04 server on our WMWARE.
> When I run the command
> (geonode) system at gaia:~/geonode$ sudo WORKON_HOME=/home/system/Envs/geonode DJANGO_SETTINGS_MODULE=geonode.local_settings GEONODE_ETC=/home/system/geonode/geonode GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data geonode_updateip -p 192.168.31.80
> I have many errors like:
> django.db.utils.ProgrammingError: relation "django_site" does not existLINE 1: ..."django_site"."domain", "django_site"."name" FROM "django_si...
> and I see that my geonode DB is empty!
> I tried to run again
> DJANGO_SETTINGS_MODULE=geonode.local_settings paver reset; \
>  paver setup; \
>  paver sync; \
>  python manage.py collectstatic --noinput
> I get an error on reset:
> [Errno 3] No such process
> ---> pavement.stop_qgis_server
> but nothing else.
> I've have no experience with Virtual Env, so I wonder if all command after
>    mkvirtualenv --no-site-packages geonode
> are to run in virtual env or not.
> I found another error after running "  pip install -r requirements.txt
> --upgrade--no-cache --no-cache-dir ":
> Command "python setup.py egg_info" failed with error code 1 in
> /tmp/pip-install-6qw4Pu/Twisted/
> Any suggestions?
> Annalisa
> Il giorno ven 26 ott 2018 alle ore 16:38 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Uhm... well, that command should install the GeoNode dependencies. Maybe
>> this is the reason why you are not able to find some packages.
>> Anyway, you must run paver reset from the "my_geonode" root folder, where
>> the "pavement.py" file is located. If you already did that, then I guess
>> your installation is a bit messed up.
>> Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <pfrias82 at gmail.com>
>> ha scritto:
>>> Yes, but after that I had to downgrade some python packages.
>>> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> From the link you sent to me, did you run also this one?
>>>> pip install -e . --upgrade
>>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <
>>>> pfrias82 at gmail.com> ha scritto:
>>>>> I've followed this instructions
>>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>>>> After "pip install Paver==1.2.4"
>>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>>>> reset
>>>>> Build failed: Unknown task: reset
>>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>>> However, it seems to me that the issue is related to a missing
>>>>>> dependency.
>>>>>> Try maybe by typing
>>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>>>>> Hi Alessio,
>>>>>>> The  (pip install -r requirements.txt --upgrade) worked fine after
>>>>>>> another try.
>>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>>> This is the error produced:
>>>>>>> reset
>>>>>>> Traceback (most recent call last):
>>>>>>>   File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7,
>>>>>>> in <module>
>>>>>>>     from paver.tasks import main
>>>>>>> ImportError: No module named paver.tasks
>>>>>>> Any idea how to solve this?
>>>>>>> Thanks,
>>>>>>> Paulo
>>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>>> Hi Paulo,
>>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>>> That command should just start downloading the Python dependencies.
>>>>>>>> If it is stuck, most probably there's a problem reaching the PyPi
>>>>>>>> repositories.
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>>>> Hi Alessio,
>>>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial
>>>>>>>>> you recommended (
>>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>>> Can you help me with some possible solution?
>>>>>>>>> Thanks,
>>>>>>>>> Paulo Frias
>>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>>> Hi Julierme,
>>>>>>>>>> please see my responses below.
>>>>>>>>>> "1 - can I make geonode-project my production environment? I
>>>>>>>>>> meant run GeoNode-Project as my production instance on the web."
>>>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>>>> case though.
>>>>>>>>>> "2 -  do I need GeoNode Core to run together with
>>>>>>>>>> GeoNode-Project?"
>>>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until
>>>>>>>>>> we do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>>>>> Core?"
>>>>>>>>>> geonode-project runs independently, but it still needs geonode as
>>>>>>>>>> a dependency. However by using it, you won't touch the geonode-core. This
>>>>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>>>>> without clashes.
>>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>>> We will try to do it when we start officially the release process.
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>>>> Hi Alessio,
>>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>>> look.
>>>>>>>>>>> Now:
>>>>>>>>>>> 2 -  do I need GeoNode Core to run together with GeoNode-Project?
>>>>>>>>>>> Core?
>>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>>> Kind regards
>>>>>>>>>>> Julierme
>>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>>> Annalisa
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>>>>> buggy and unstable one.
>>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin
>>>>>>>>>>>>> gui.
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>>>>> don't think to develop on geonode,  only to customize the look?
>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>>>> Please someone may confirm that installation by deb
>>>>>>>>>>>>>>>> packages, with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>>>>>>>>>>>>>>>> now?)
>>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed
>>>>>>>>>>>>>>>>> via apt-get, following these commands:
>>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>>>  -epy,rst
>>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>>> This email is intended only for the person or entity to
>>>>>>>>>>>>>>> which it is addressed and may contain information that is privileged,
>>>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>> @alfa7691
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/99a09492/attachment-0001.html>
More information about the geonode-users mailing list
