[GeoNode-users] Best way to install geonode
Annalisa Schiavon
annalisa.schiavon at gmail.com
Fri Nov 9 03:24:09 PST 2018
Hi Alessio,
I've tried to follow your document: "GeoNode 2.9.x -Deployment on Ubuntu
18.04" (
https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
I've installed a brand new ubuntu 18.04 server on our WMWARE.
When I run the command
(geonode) system at gaia:~/geonode$ sudo
WORKON_HOME=/home/system/Envs/geonode
DJANGO_SETTINGS_MODULE=geonode.local_settings
GEONODE_ETC=/home/system/geonode/geonode
GEOSERVER_DATA_DIR=/var/lib/tomcat8/webapps/geoserver/data
geonode_updateip -p 192.168.31.80
I have many errors like:
django.db.utils.ProgrammingError: relation "django_site" does not
existLINE 1: ..."django_site"."domain", "django_site"."name" FROM
"django_si...
and I see that my geonode DB is empty!
I tried to run again
DJANGO_SETTINGS_MODULE=geonode.local_settings paver reset; \
paver setup; \
paver sync; \
python manage.py collectstatic --noinput
I get an error on reset:
[Errno 3] No such process
---> pavement.stop_qgis_server
but nothing else.
I've have no experience with Virtual Env, so I wonder if all command after
mkvirtualenv --no-site-packages geonode
are to run in virtual env or not.
I found another error after running " pip install -r requirements.txt
--upgrade--no-cache --no-cache-dir ":
Command "python setup.py egg_info" failed with error code 1 in
/tmp/pip-install-6qw4Pu/Twisted/
Any suggestions?
Annalisa
Il giorno ven 26 ott 2018 alle ore 16:38 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Uhm... well, that command should install the GeoNode dependencies. Maybe
> this is the reason why you are not able to find some packages.
> Anyway, you must run paver reset from the "my_geonode" root folder, where
> the "pavement.py" file is located. If you already did that, then I guess
> your installation is a bit messed up.
> Il giorno ven 26 ott 2018 alle ore 16:24 Paulo Frias <pfrias82 at gmail.com>
> ha scritto:
>> Yes, but after that I had to downgrade some python packages.
>> On Fri, 26 Oct 2018 at 15:21, Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> From the link you sent to me, did you run also this one?
>>> pip install -e . --upgrade
>>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com>
>>> ha scritto:
>>>> I've followed this instructions
>>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>>>> After "pip install Paver==1.2.4"
>>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver
>>>> reset
>>>> Build failed: Unknown task: reset
>>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>>> However, it seems to me that the issue is related to a missing
>>>>> dependency.
>>>>> Try maybe by typing
>>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <
>>>>> pfrias82 at gmail.com> ha scritto:
>>>>>> Hi Alessio,
>>>>>> The (pip install -r requirements.txt --upgrade) worked fine after
>>>>>> another try.
>>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>>> This is the error produced:
>>>>>> reset
>>>>>> Traceback (most recent call last):
>>>>>> File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7,
>>>>>> in <module>
>>>>>> from paver.tasks import main
>>>>>> ImportError: No module named paver.tasks
>>>>>> Any idea how to solve this?
>>>>>> Thanks,
>>>>>> Paulo
>>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>>> Hi Paulo,
>>>>>>> can you describe what's happening with a bit more detail?
>>>>>>> That command should just start downloading the Python dependencies.
>>>>>>> If it is stuck, most probably there's a problem reaching the PyPi
>>>>>>> repositories.
>>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>>>> Hi Alessio,
>>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial
>>>>>>>> you recommended (
>>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project).
>>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>>> Can you help me with some possible solution?
>>>>>>>> Thanks,
>>>>>>>> Paulo Frias
>>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>>> Hi Julierme,
>>>>>>>>> please see my responses below.
>>>>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>>>>> Sure, but you will need to tweak a bit security options and
>>>>>>>>> settings in order to secure and optimize your instance. Especially
>>>>>>>>> important are the admin passwords and openid keys. This is valid in any
>>>>>>>>> case though.
>>>>>>>>> "2 - do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until
>>>>>>>>> we do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode
>>>>>>>>> Core?"
>>>>>>>>> geonode-project runs independently, but it still needs geonode as
>>>>>>>>> a dependency. However by using it, you won't touch the geonode-core. This
>>>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>>>> without clashes.
>>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>
>>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8
>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>>> We will try to do it when we start officially the release process.
>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>>>>>>>>> Hi Alessio,
>>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>>> look.
>>>>>>>>>> Now:
>>>>>>>>>> Core?
>>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>>> Kind regards
>>>>>>>>>> Julierme
>>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>>> annalisa.schiavon at gmail.com> wrote:
>>>>>>>>>>> Thanks for the tip!
>>>>>>>>>>> Annalisa
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most
>>>>>>>>>>>> buggy and unstable one.
>>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin
>>>>>>>>>>>> gui.
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>>> annalisa.schiavon at gmail.com> ha scritto:
>>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>>>> don't think to develop on geonode, only to customize the look?
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>>> If you want to install geonode for development, I would
>>>>>>>>>>>>>> suggest following the procedure here
>>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing
>>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>>> Please someone may confirm that installation by deb
>>>>>>>>>>>>>>> packages, with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at
>>>>>>>>>>>>>>> now?)
>>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox
>>>>>>>>>>>>>>> installation (
>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html)?
>>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html
>>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it
>>>>>>>>>>>>>>> recommended install geonode-project and create a template, in similar way
>>>>>>>>>>>>>>> than once? Because in
>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project I find
>>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed
>>>>>>>>>>>>>>>> via apt-get, following these commands:
>>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip
>>>>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>>> http://goo.gl/it488V for more information.
>>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>>> This email is intended only for the person or entity to which
>>>>>>>>>>>>>> it is addressed and may contain information that is privileged,
>>>>>>>>>>>>>> confidential or otherwise protected from disclosure. We remind that - as
>>>>>>>>>>>>>> provided by European Regulation 2016/679 “GDPR” - copying, dissemination or
>>>>>>>>>>>>>> use of this e-mail or the information herein by anyone other than the
>>>>>>>>>>>>>> intended recipient is prohibited. If you have received this email by
>>>>>>>>>>>>>> mistake, please notify us immediately by telephone or e-mail.
>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>> notizia.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/0e1be991/attachment-0001.html>
More information about the geonode-users
