[GeoNode-users] Geonode 2.10 rc4 and problems with Geoserver hatch
Matteo Conte
matteo.conte at abitat.it
Fri Nov 9 08:57:17 PST 2018
Hi Alessio,
how I can update my geoserver from war on Geonode docker installation?
Best regards,
Matteo
Da: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
A: "matteo.conte" <matteo.conte at abitat.it>
Cc: "Francesco Bartoli" <xbartolone at gmail.com>, "geonode-users" <geonode-users at lists.osgeo.org>
Inviato: Venerdì, 9 novembre 2018 10:34:23
Oggetto: Re: [GeoNode-users] Geonode 2.10 rc4 and problems with Geoserver hatch
Dear Matteo,
I tested your SLD on GeoServer 2.14.x from GeoNode and it works seamlessly (see screenshot).
I kindly suggest downloading the updated WAR from
[ https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.14.x.war | https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.14.x.war ]
We just updated it hence there were some dependency issues and bug-fixes from GeoServer main stream preventing it to work as expected in some particular cases.
Il giorno ven 9 nov 2018 alle ore 10:29 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
Hi Francesco,
I tested the hatch style on a fresh Geoserver 2.14 installation on ubuntu 16. The style work fine. I installed my geonode (2.10 RC4) following the GeoNode on docker instructions ( [ http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html | http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html ] )
Anyone can help me to solve the problem?
Kind regards,
Matteo
Da: "Francesco Bartoli" < [ mailto:xbartolone at gmail.com | xbartolone at gmail.com ] >
A: "matteo.conte" < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] >
Cc: "geonode-users" < [ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ] >
Inviato: Giovedì, 8 novembre 2018 18:04:10
Matteo,
did you already tried with a vanilla GeoServer? It's likely that error has nothing to do with GeoNode itself. In this case I think it would be better to ask on the GeoServer list or open an issue on their tracker.
Cheers,
Francesco
Il giorno gio 8 nov 2018 alle ore 15:33 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
BQ_BEGIN
Hi Jorge,
I have installed libbatik-java but nothing is change. I get the same error (I rebooted my server too).
Kind Regards
Matteo
geonode-users mailing list
[ https://lists.osgeo.org/mailman/listinfo/geonode-users | https://lists.osgeo.org/mailman/listinfo/geonode-users ]
BQ_END
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/40594e73/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/40594e73/attachment-0001.png>
More information about the geonode-users
