[GeoNode-users] Geonode 2.10 rc4 and problems with Geoserver hatch
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Nov 9 01:34:23 PST 2018
Dear Matteo,
I tested your SLD on GeoServer 2.14.x from GeoNode and it works seamlessly
(see screenshot).
I kindly suggest downloading the updated WAR from
https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.14.x.war
We just updated it hence there were some dependency issues and bug-fixes
from GeoServer main stream preventing it to work as expected in some
particular cases.
[image: image.png]
Il giorno ven 9 nov 2018 alle ore 10:29 Matteo Conte <matteo.conte at abitat.it>
ha scritto:
> Hi Francesco,
>    I tested the hatch style on a fresh Geoserver 2.14 installation on
> ubuntu 16. The style work fine.  I installed my geonode (2.10 RC4)
> following the GeoNode on docker instructions (
> http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html
> Anyone can help me to solve the problem?
> Kind regards,
> Matteo
> *Da: *"Francesco Bartoli" <xbartolone at gmail.com>
> *A: *"matteo.conte" <matteo.conte at abitat.it>
> *Cc: *"geonode-users" <geonode-users at lists.osgeo.org>
> *Inviato: *Giovedì, 8 novembre 2018 18:04:10
> *Oggetto: *Re: [GeoNode-users] Geonode 2.10 rc4 and problems with
> Geoserver hatch
> Matteo,
> did you already tried with a vanilla GeoServer? It's likely that error has
> nothing to do with GeoNode itself. In this case I think it would be better
> to ask on the GeoServer list or open an issue on their tracker.
> Cheers,
> Francesco
> Il giorno gio 8 nov 2018 alle ore 15:33 Matteo Conte <
> matteo.conte at abitat.it> ha scritto:
>> Hi Jorge,
>>   I have installed libbatik-java but nothing is change. I get the same
>> error (I rebooted my server too).
>> Kind Regards
>> Matteo
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/d2b4809e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181109/d2b4809e/attachment-0001.png>
More information about the geonode-users mailing list
