[GeoNode-users] Customizing Mapfish Printing
Jorge Gustavo Rocha
jgr at geomaster.pt
Sat Nov 10 02:12:52 PST 2018
Hi Aditya,
1) Make sure you are changing the right config.yaml.
2) The config.yaml should be in your GEOSERVER_DATA DIR, under
printing/config.yaml.
Go to the Geoserver interface, Server Status and check the Data
directory path. The right config.yaml should be:
$GEOSERVER_DATA_DIR/printing/config.yaml
3) After changing your config.yaml, you can check the print capabilities
document by requesting:
your.node.instance.com[:port]/geoserver/pdf/info.json
You should see the layouts you have in your config.yaml
Good luck,
Jorge
Às 06:42 de 10/11/18, aditya fikri ghozali escreveu:
> Hi, anyone here experienced in customizing config.yaml, a mapfish
> printing configuration on geonode? I try to customizing (print header,
> print output file, etc) on config.yaml file (geonode 2.10rc4,
> Geoserver2.14), but then nothing is change in printing result. Is
> there any other procedure in addition to editing config.yaml file and
> restarting the server?
> Thanks in advance
> Best Regards,
> *Aditya Fikri Ghozali*
> Bachelor of Geodesy and Geomatics Engineering
> Bandung Institute of Technology
> e-mail: adityafikrighozali at gmail.com <mailto:adityafikrighozali at gmail.com>
> | www.adityafikrighozali.com <http://www.adityafikrighozali.com>
> <https://www.facebook.com/welcomemybest> <https://www.linkedin.com/in/fikriaditya/> <https://www.youtube.com/user/adityafikri/> <https://medium.com/@adityafikrighozali>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Logo* Geomaster, LDA*
*VENHA DESCOBRIR O CAMINHO DO OPEN SOURCE CONNOSC**O
Avenida Barros e Soares
N.º 423, 4715-214 Braga
VAT/NIF510 906 109
Phone +351 253 680 323
Site geomaster.pt <http://geomaster.pt>
GPS 41.53322, -8.41929
Jorge Gustavo Rocha
CTO
Mobile +351 910 333 888
Email jgr at geomaster.pt
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181110/2aac4f99/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181110/2aac4f99/attachment-0001.png>
More information about the geonode-users
