[GeoNode-users] geonode-users Digest, Vol 46, Issue 31
Dejan Samardzic dejan.samardzic at cedis.me
Tue Nov 20 00:49:33 PST 2018
Dear Deb,
of course, my suggestion for developer action was addressed to GeoNode developer team not to you.
Thank you one more time for your effort and help.
regards,
Dejan.
On 11/20/2018 9:44 AM, geonode-users-request at lists.osgeo.org<mailto:geonode-users-request at lists.osgeo.org> wrote:
Send geonode-users mailing list submissions to
        geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.osgeo.org/mailman/listinfo/geonode-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        geonode-users-owner at lists.osgeo.org<mailto:geonode-users-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of geonode-users digest..."
Today's Topics:
   1. Re: geonode-users Digest, Vol 46, Issue 22 (Dev Gis)
Message: 1
Date: Tue, 20 Nov 2018 09:41:47 +0100
From: Dev Gis <deviirmr at gmail.com><mailto:deviirmr at gmail.com>
To: dejan.samardzic at cedis.me<mailto:dejan.samardzic at cedis.me>
Cc: alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>, Paulo Frias
        <pfrias82 at gmail.com><mailto:pfrias82 at gmail.com>,  geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] geonode-users Digest, Vol 46, Issue 22
Message-ID:
        <CAO84Oy4z1wTivcnTXTkkM=N5Yue=pec3mcjgPSq8TxTbXhemig at mail.gmail.com><mailto:CAO84Oy4z1wTivcnTXTkkM=N5Yue=pec3mcjgPSq8TxTbXhemig at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hi Dejan,
Happy to know that anyhow it's working, I wish I could provide a more
appropriate solution instant of just workaround of problem :).  Sorry about
that!
As I mentioned in my previous email the solution may not be a perfect one,
I hope the GeoNode team soon fix this issue in the next release.
well.. the docker-compose file always comes with a predefined/default port
which sometime user need to adjust based on the requirement and it is true
for the user managing multiple GeoNode in a single machine/Host as in my
case.
I do agree with you  host IP with port is not convenient for the user as
the user always expect default port 80 on the entry point to the
website/GeoNode but again Docker mode always need to play around port
numbers and I think that is the beauty of the Docker framework  and I
don't see any challenge for a developer to  convert the <Host IP>:<Port>
to clean URL  using approaches such as  "Masked Redirect" so that user
always see the clean URL without port.
I am a nither GeoNode developer nor from GeoNode team as a community member
I have just shared my experience while facing the similar issue as other
community members do in the group.
Good Luck!
Deb
On Mon, Nov 19, 2018 at 5:07 PM Dejan Samardzic <dejan.samardzic at cedis.me><mailto:dejan.samardzic at cedis.me>
wrote:
Dear Dev,
thanks for your effort....
Yes, by changing ports as you describe problem is solved....
But is not convenient for users who learn to used port 80 to add :85 into
link.
It is necessary to solve the problem not to use workaround.
regards,
Dejan.
On 11/19/2018 1:21 PM, Dev Gis wrote:
I also had a similar issue yesterday, which I fix by adjusting the port in
a script file and yml file.
could you plz try again by adjusting the file
1.  /home/osboxes/geonode -- edit  docker-compose.yml file
 add  a port differ then 80, I have used 85
2. .Again..  /home/osboxes/geonode -- edit  docker-compose.yml file
need to add a port for geoserver must use 80 here
3./home/osboxes/geonode/scripts/docker/env/production ---- edit django.env
add ip and  add port 85
edit geoserver.env
again add port 85
I am assuming port 85 is not taken.
Remember your website will be open at  <ip>:85
try with host/ docker ip first instant of using "razvojgis.cedis.me".
Dokcer-compose must be down while editing the files and once done up the
docker-compose
I am suspect the issue is because of conflict between the ports and
inter-container communication
The above is work for me which may not be a perfect solution.
Regards
Deb
On Mon, Nov 19, 2018 at 12:27 PM Dejan Samardzic <dejan.samardzic at cedis.me><mailto:dejan.samardzic at cedis.me>
wrote:
Dears,
please find printscreen from Chrome Developement Tools (Console) during
Upload Layers in attachment (upload.JPG). Also, find my
/home/geonode/geonode/scripts/docker/env/production/django.env in
attachment (django.env).
regards,
Dejan.
 On 11/19/2018 12:01 PM, Alessio Fabiani wrote:
can you please open up che debug window on your browser and check for any
Javascript issue?
(see "console -> errors")
Il giorno lun 19 nov 2018 alle ore 11:32 Paulo Frias <pfrias82 at gmail.com><mailto:pfrias82 at gmail.com>
ha scritto:
I have the same issue.
On Sat, 17 Nov 2018 at 20:41, Dejan Samardzic <dejan.samardzic at cedis.me><mailto:dejan.samardzic at cedis.me>
wrote:
Dear Geonode community,
I have also installed Geonode ver 2.10RC4 Master branch on docker.
Upload of any files doesn't work at all.
When I go to Data -> Upload Layers -> Choose Files.....nothing happen
(I'm not able to choose file). Look for yourself.
https://www.youtube.com/watch?v=XFxC5tyQiLo
regards,
Dejan Samardžić
On 11/17/2018 9:00 PM, geonode-users-request at lists.osgeo.org<mailto:geonode-users-request at lists.osgeo.org> wrote:
Today's Topics:
   1. Geonode 2.10RC4 Layer Upload Method (aditya fikri ghozali)
Message: 1
Date: Sat, 17 Nov 2018 16:15:16 +0700
From: aditya fikri ghozali <adityafikrighozali at gmail.com><mailto:adityafikrighozali at gmail.com> <adityafikrighozali at gmail.com><mailto:adityafikrighozali at gmail.com>
To: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Subject: [GeoNode-users] Geonode 2.10RC4 Layer Upload Method
Message-ID:
        <CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com><mailto:CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com> <CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com><mailto:CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com>
Dear all,
I have a problem with geonode uploads method on Geonode 2.10RC4. The
default layer upload was geonode directly sent the file to geoserver as a
new vector layer datastore. I try to make the layer upload to store it in
geonode_data database which is defined as a datastore in geoserver. I've
done the following configuration but not working.
- migrate the dtb to postgresql (succeeded, the default dtb are now use
postgresql.)
- use either geoserver.sample or psql_test local_settings.
- use either geonode.rest or geonode.importer as UPLOADER BACKEND.
any hints? or Is there any workaround to this?
Thanks  in Advance
Best Regards,
*Aditya Fikri Ghozali*
Geodesy and Geomatics Engineering
e-mail: adityafikrighozali at gmail.com<mailto:adityafikrighozali at gmail.com>
 | www.adityafikrighozali.com<http://www.adityafikrighozali.com> <http://www.adityafikrighozali.com><http://www.adityafikrighozali.com> <http://www.adityafikrighozali.com><http://www.adityafikrighozali.com>
        <https://www.facebook.com/welcomemybest><https://www.facebook.com/welcomemybest> <https://www.facebook.com/welcomemybest><https://www.facebook.com/welcomemybest><https://www.linkedin.com/in/fikriaditya/><https://www.linkedin.com/in/fikriaditya/> <https://www.linkedin.com/in/fikriaditya/><https://www.linkedin.com/in/fikriaditya/><https://www.youtube.com/user/adityafikri/><https://www.youtube.com/user/adityafikri/> <https://www.youtube.com/user/adityafikri/><https://www.youtube.com/user/adityafikri/><https://medium.com/@adityafikrighozali><https://medium.com/@adityafikrighozali> <https://medium.com/@adityafikrighozali><https://medium.com/@adityafikrighozali>
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail><https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail><https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Virus-free.www.avast.com<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail><https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail><https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html><http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html><http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html>
Subject: Digest Footer
geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users<mailto:listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users>
End of geonode-users Digest, Vol 46, Issue 22
* Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
CEDIS d.o.o.
Ivana Milutinovića 12, 81000 Podgorica
gsm: +382 67 220 971
tel: +382 20 408 453
email: dejan.samardzic at cedis.me<mailto:dejan.samardzic at cedis.me>
web: www.cedis.me<http://www.cedis.me>
http://goo.gl/it488V for more information. == Ing. Alessio Fabiani
@alfa7691 Founder/Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A - 55054  Massarosa (LU) - Italy phone:
+39 0584 962313 fax:     +39 0584 1660272 mob:   +39 331 6233686
http://www.geo-solutions.it http://twitter.com/geosolutions_it
Con riferimento alla normativa sul trattamento dei dati personali (Reg.
UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
CEDIS d.o.o.
CEDIS d.o.o.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.html><http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.jpg><http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment-0001.jpg><http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment-0001.jpg>
End of geonode-users Digest, Vol 46, Issue 31
 Dejan Samardžić        Rukovodilac Sektora za ICT / IT Manager
[cid:part1.E3BA9269.74A8F0B8 at cedis.me]
CEDIS d.o.o.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/04af3752/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/04af3752/attachment-0001.jpg>
More information about the geonode-users mailing list
