[GeoNode-users] geonode-users Digest, Vol 46, Issue 31
francesco bartoli xbartolone at gmail.com
Tue Nov 20 04:08:43 PST 2018
Hi Dejan,
can you elaborate your suggestions a little bit more and file an issue for
them? This would help somebody who wants to eventually implement it at some
point.
Thanks,
Francesco
Il giorno mar 20 nov 2018 alle ore 09:49 Dejan Samardzic <
dejan.samardzic at cedis.me> ha scritto:
> Dear Deb,
> of course, my suggestion for developer action was addressed to GeoNode
> developer team not to you.
> Thank you one more time for your effort and help.
> regards,
> Dejan.
> On 11/20/2018 9:44 AM, geonode-users-request at lists.osgeo.org wrote:
> Send geonode-users mailing list submissions to
> 	geonode-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/geonode-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	geonode-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-users digest..."
> Today's Topics:
>    1. Re: geonode-users Digest, Vol 46, Issue 22 (Dev Gis)
> Message: 1
> Date: Tue, 20 Nov 2018 09:41:47 +0100
> From: Dev Gis <deviirmr at gmail.com> <deviirmr at gmail.com>
> To: dejan.samardzic at cedis.me
> Cc: alessio.fabiani at geo-solutions.it, Paulo Frias
> 	<pfrias82 at gmail.com> <pfrias82 at gmail.com>,  geonode-users at lists.osgeo.org
> Subject: Re: [GeoNode-users] geonode-users Digest, Vol 46, Issue 22
> Message-ID:
> 	<CAO84Oy4z1wTivcnTXTkkM=N5Yue=pec3mcjgPSq8TxTbXhemig at mail.gmail.com> <CAO84Oy4z1wTivcnTXTkkM=N5Yue=pec3mcjgPSq8TxTbXhemig at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Dejan,
> Happy to know that anyhow it's working, I wish I could provide a more
> appropriate solution instant of just workaround of problem :).  Sorry about
> that!
> As I mentioned in my previous email the solution may not be a perfect one,
> I hope the GeoNode team soon fix this issue in the next release.
> well.. the docker-compose file always comes with a predefined/default port
> which sometime user need to adjust based on the requirement and it is true
> for the user managing multiple GeoNode in a single machine/Host as in my
> case.
> I do agree with you  host IP with port is not convenient for the user as
> the user always expect default port 80 on the entry point to the
> website/GeoNode but again Docker mode always need to play around port
> numbers and I think that is the beauty of the Docker framework  and I
> don't see any challenge for a developer to  convert the <Host IP>:<Port>
> to clean URL  using approaches such as  "Masked Redirect" so that user
> always see the clean URL without port.
> I am a nither GeoNode developer nor from GeoNode team as a community member
> I have just shared my experience while facing the similar issue as other
> community members do in the group.
> Good Luck!
> Deb
> On Mon, Nov 19, 2018 at 5:07 PM Dejan Samardzic <dejan.samardzic at cedis.me> <dejan.samardzic at cedis.me>
> wrote:
> Dear Dev,
> thanks for your effort....
> Yes, by changing ports as you describe problem is solved....
> But is not convenient for users who learn to used port 80 to add :85 into
> link.
> It is necessary to solve the problem not to use workaround.
> regards,
> Dejan.
> On 11/19/2018 1:21 PM, Dev Gis wrote:
> Hi,
> I also had a similar issue yesterday, which I fix by adjusting the port in
> a script file and yml file.
> could you plz try again by adjusting the file
> 1.  /home/osboxes/geonode -- edit  docker-compose.yml file
>  add  a port differ then 80, I have used 85
> 2. .Again..  /home/osboxes/geonode -- edit  docker-compose.yml file
> need to add a port for geoserver must use 80 here
> 3./home/osboxes/geonode/scripts/docker/env/production ---- edit django.env
> add ip and  add port 85
> edit geoserver.env
> again add port 85
> I am assuming port 85 is not taken.
> Remember your website will be open at  <ip>:85
> try with host/ docker ip first instant of using "razvojgis.cedis.me".
> Dokcer-compose must be down while editing the files and once done up the
> docker-compose
> I am suspect the issue is because of conflict between the ports and
> inter-container communication
> The above is work for me which may not be a perfect solution.
> Regards
> Deb
> On Mon, Nov 19, 2018 at 12:27 PM Dejan Samardzic <dejan.samardzic at cedis.me> <dejan.samardzic at cedis.me>
> wrote:
> Dears,
> please find printscreen from Chrome Developement Tools (Console) during
> Upload Layers in attachment (upload.JPG). Also, find my
> /home/geonode/geonode/scripts/docker/env/production/django.env in
> attachment (django.env).
> regards,
> Dejan.
>  On 11/19/2018 12:01 PM, Alessio Fabiani wrote:
> Hi,
> can you please open up che debug window on your browser and check for any
> Javascript issue?
> (see "console -> errors")
> Il giorno lun 19 nov 2018 alle ore 11:32 Paulo Frias <pfrias82 at gmail.com> <pfrias82 at gmail.com>
> ha scritto:
> I have the same issue.
> On Sat, 17 Nov 2018 at 20:41, Dejan Samardzic <dejan.samardzic at cedis.me> <dejan.samardzic at cedis.me>
> wrote:
> Dear Geonode community,
> I have also installed Geonode ver 2.10RC4 Master branch on docker.
> Upload of any files doesn't work at all.
> When I go to Data -> Upload Layers -> Choose Files.....nothing happen
> (I'm not able to choose file). Look for yourself.https://www.youtube.com/watch?v=XFxC5tyQiLo
> regards,
> Dejan Samardžić
> Today's Topics:
>    1. Geonode 2.10RC4 Layer Upload Method (aditya fikri ghozali)
> Message: 1
> Date: Sat, 17 Nov 2018 16:15:16 +0700
> From: aditya fikri ghozali <adityafikrighozali at gmail.com> <adityafikrighozali at gmail.com> <adityafikrighozali at gmail.com> <adityafikrighozali at gmail.com>
> To: geonode-users at lists.osgeo.org
> Subject: [GeoNode-users] Geonode 2.10RC4 Layer Upload Method
> Message-ID:
> 	<CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com> <CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com> <CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com> <CABSG5bZCXna+eRUu=Y+aOVUkqLmofhDR0d0aLKVkdom4Z3DdMg at mail.gmail.com>
> Dear all,
> I have a problem with geonode uploads method on Geonode 2.10RC4. The
> default layer upload was geonode directly sent the file to geoserver as a
> new vector layer datastore. I try to make the layer upload to store it in
> geonode_data database which is defined as a datastore in geoserver. I've
> done the following configuration but not working.
> - migrate the dtb to postgresql (succeeded, the default dtb are now use
> postgresql.)
> - use either geoserver.sample or psql_test local_settings.
> - use either geonode.rest or geonode.importer as UPLOADER BACKEND.
> any hints? or Is there any workaround to this?
> Thanks  in Advance
> Best Regards,
> *Aditya Fikri Ghozali*
> Geodesy and Geomatics Engineering
> e-mail: adityafikrighozali at gmail.com
>  | www.adityafikrighozali.com <http://www.adityafikrighozali.com> <http://www.adityafikrighozali.com> <http://www.adityafikrighozali.com> <http://www.adityafikrighozali.com>
>         <https://www.facebook.com/welcomemybest> <https://www.facebook.com/welcomemybest> <https://www.facebook.com/welcomemybest> <https://www.facebook.com/welcomemybest><https://www.linkedin.com/in/fikriaditya/> <https://www.linkedin.com/in/fikriaditya/> <https://www.linkedin.com/in/fikriaditya/> <https://www.linkedin.com/in/fikriaditya/><https://www.youtube.com/user/adityafikri/> <https://www.youtube.com/user/adityafikri/> <https://www.youtube.com/user/adityafikri/> <https://www.youtube.com/user/adityafikri/><https://medium.com/@adityafikrighozali> <https://medium.com/@adityafikrighozali> <https://medium.com/@adityafikrighozali> <https://medium.com/@adityafikrighozali>
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>Virus-free.www.avast.com<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181117/746e4bbc/attachment-0001.html>
> Subject: Digest Footer
> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users
> End of geonode-users Digest, Vol 46, Issue 22
> * Dejan Samardžić* Rukovodilac Sektora za ICT / IT Manager
> CEDIS d.o.o.
> Ivana Milutinovića 12, 81000 Podgorica
> gsm: +382 67 220 971
> tel: +382 20 408 453
> email: dejan.samardzic at cedis.me
> web: www.cedis.me
> GeoServer Professional Services from the experts! Visithttp://goo.gl/it488V for more information. == Ing. Alessio Fabiani
> @alfa7691 Founder/Technical Lead
> GeoSolutions S.A.S. Via di Montramito 3/A - 55054  Massarosa (LU) - Italy phone:
> +39 0584 962313 fax:     +39 0584 1660272 mob:   +39 331 6233686
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> CEDIS d.o.o.
> web: www.cedis.me
> CEDIS d.o.o.
> web: www.cedis.me
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.html> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.html>
> A non-text attachment was scrubbed...
> Type: image/jpeg
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.jpg> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment.jpg>
> Type: image/jpeg
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment-0001.jpg> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/3cfeafe7/attachment-0001.jpg>
> End of geonode-users Digest, Vol 46, Issue 31
> CEDIS d.o.o.
> web: www.cedis.me
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/c7424ef2/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/c7424ef2/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181120/c7424ef2/attachment-0003.jpg>
More information about the geonode-users mailing list
