[GeoNode-users] GeoNode-Project Installation
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Wed Nov 21 08:15:50 PST 2018
...and yes, in the case of using
os.environ.setdefault("DJANGO_SETTINGS_MODULE",
"my_geonode.local_settings"), I have local_settings.py in my
/my_geonode/my_geonode/ path.
Thank you for your time in advance.
Julierme
On Wed, Nov 21, 2018 at 1:55 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi all,
> Regarding the previous e-mail, I made a test here. Following the guide
> <https://github.com/GeoNode/geonode-project/tree/2.8> to install
> GeoNode-Project at 2.8, everything works fine if I set the settings in
> my_geonode/wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> "my_geonode.settings"). However, if I change to <local_settings> in
> my_geonode/wsgi.py to os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> "my_geonode.local_settings"), I have the issues showed in the previous
> e-mail. Is there anything else that I must pay attention or may be missing
> configuration?
> Any help on that would be appreciated.
> Kind regards
> Julierme
> On Tue, Nov 20, 2018 at 1:18 PM Julierme Pinheiro <
>> Hi GeoNode users,
>> I have Geonode-Project installed via Docker in Centos7 Vm and all works
>> fine after following the guide in here
>> <https://github.com/GeoNode/geonode-project/tree/2.8>.
>> Now, I am trying to repeat the task installing GeoNode-Project in a
>> server in our network, and I am facing the issue bellow. It seems
>> database connection issue:
>> celery4my_geonode | django.db.utils.OperationalError: could not connect
>> to server: Connection refused
>> celery4my_geonode | Is the server running on host "localhost"
>> (127.0.0.1) and accepting
>> celery4my_geonode | TCP/IP connections on port 5432?
>> celery4my_geonode | could not connect to server: Cannot assign requested
>> address
>> celery4my_geonode | Is the server running on host "localhost" (::1)
>> and accepting
>> I tried setting postgres/postgis database from a different server (host =
>> 172.21.14.45) as shown bellow, but the problem remains
>> DATABASES = {
>> 'default': {
>> 'ENGINE': 'django.db.backends.postgresql_psycopg2',
>> 'NAME': 'geonode',
>> 'USER': 'geonode',
>> 'PASSWORD': 'geonode',
>> 'HOST': 'localhost', --> 172.21.14.45
>> 'PORT': '5432',
>> 'CONN_TOUT': 900,
>> # vector datastore for uploads
>> 'datastore': {
>> 'ENGINE': 'django.contrib.gis.db.backends.postgis',
>> # 'ENGINE': '', # Empty ENGINE name disables
>> 'NAME': 'geonode_data',
>> 'USER': 'geonode',
>> 'PORT': '5432',
>> 'CONN_TOUT': 900,
>> Geoserver is running smoothly, but Django and Celery are up, giving
>> always a response of
>> 502 Bad Gateway
>> nginx/1.15.0
>> Any comment on that will be very appreciated.
>> Thank you very much for your time in advance.
>> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181121/d94f68bc/attachment.html>
More information about the geonode-users
