[GeoNode-users] GeoNode-Project Installation
Paolo Corti
pcorti at gmail.com
Wed Nov 21 08:19:33 PST 2018
Hi
first thing to test: can you connect from the server with psql to the database?
best
Paolo
On Wed, Nov 21, 2018 at 11:16 AM Julierme Pinheiro
<juliermeopensourcedeveloper at gmail.com> wrote:
> ...and yes, in the case of using os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings"), I have local_settings.py in my /my_geonode/my_geonode/ path.
> Thank you for your time in advance.
> Julierme
> On Wed, Nov 21, 2018 at 1:55 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
>> Hi all,
>> Regarding the previous e-mail, I made a test here. Following the guide to install GeoNode-Project at 2.8, everything works fine if I set the settings in my_geonode/wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings"). However, if I change to <local_settings> in my_geonode/wsgi.py to os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings"), I have the issues showed in the previous e-mail. Is there anything else that I must pay attention or may be missing configuration?
>> Any help on that would be appreciated.
>> Kind regards
>> Julierme
>> On Tue, Nov 20, 2018 at 1:18 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
>>> Hi GeoNode users,
>>> I have Geonode-Project installed via Docker in Centos7 Vm and all works fine after following the guide in here.
>>> Now, I am trying to repeat the task installing GeoNode-Project in a server in our network, and I am facing the issue bellow. It seems database connection issue:
>>> celery4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
>>> celery4my_geonode | Is the server running on host "localhost" (127.0.0.1) and accepting
>>> celery4my_geonode | TCP/IP connections on port 5432?
>>> celery4my_geonode | could not connect to server: Cannot assign requested address
>>> celery4my_geonode | Is the server running on host "localhost" (::1) and accepting
>>> I tried setting postgres/postgis database from a different server (host = 172.21.14.45) as shown bellow, but the problem remains
>>> DATABASES = {
>>> 'default': {
>>> 'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>> 'NAME': 'geonode',
>>> 'USER': 'geonode',
>>> 'PASSWORD': 'geonode',
>>> 'HOST': 'localhost', --> 172.21.14.45
>>> 'PORT': '5432',
>>> 'CONN_TOUT': 900,
>>> # vector datastore for uploads
>>> 'datastore': {
>>> 'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>> # 'ENGINE': '', # Empty ENGINE name disables
>>> 'NAME': 'geonode_data',
>>> 'USER': 'geonode',
>>> 'PORT': '5432',
>>> 'CONN_TOUT': 900,
>>> Geoserver is running smoothly, but Django and Celery are up, giving always a response of
>>> 502 Bad Gateway
>>> ________________________________
>>> nginx/1.15.0
>>> Any comment on that will be very appreciated.
>>> Thank you very much for your time in advance.
>>> Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
