[GeoNode-users] GeoNode-Project Installation
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Wed Nov 21 10:23:41 PST 2018
Dear Paolo Corti,
Thank you very much for your reply.
Yes I can connect to database:
psql -h 172.21.14.45 -U geonode -d geonode
psql (10.6 (Ubuntu 10.6-0ubuntu0.18.04.1), server 9.5.14)
Type "help" for help.
geonode=> \q
Now. I want to skip the remote database connection for GeoNode-Project
installed via Docker as I am using the
os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings") in
wsgi.py file. By just using db4my_geonode and
os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings"),
GeoNode-Project at 2.8 installation goes fine until the end. Now, here is the
issue: if I make local_settings.py available in my_geonode/my_geonode/ and
set wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE",
"my_geonode.local_settings"), I get the forever response:
502 Bad Gateway
I appreciated your time
Julierme
On Wed, Nov 21, 2018 at 2:20 PM Paolo Corti <pcorti at gmail.com> wrote:
> Hi
> first thing to test: can you connect from the server with psql to the
> database?
> best
> Paolo
> On Wed, Nov 21, 2018 at 11:16 AM Julierme Pinheiro
> <juliermeopensourcedeveloper at gmail.com> wrote:
> > ...and yes, in the case of using
> "my_geonode.local_settings"), I have local_settings.py in my
> /my_geonode/my_geonode/ path.
> > Thank you for your time in advance.
> > Julierme
> > On Wed, Nov 21, 2018 at 1:55 PM Julierme Pinheiro <
> >> Hi all,
> >> Regarding the previous e-mail, I made a test here. Following the guide
> to install GeoNode-Project at 2.8, everything works fine if I set the
> settings in my_geonode/wsgi.py as
> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings").
> However, if I change to <local_settings> in my_geonode/wsgi.py to
> "my_geonode.local_settings"), I have the issues showed in the previous
> e-mail. Is there anything else that I must pay attention or may be missing
> configuration?
> >> Any help on that would be appreciated.
> >> Kind regards
> >> Julierme
> >> On Tue, Nov 20, 2018 at 1:18 PM Julierme Pinheiro <
> >>> Hi GeoNode users,
> >>> I have Geonode-Project installed via Docker in Centos7 Vm and all
> works fine after following the guide in here.
> >>> Now, I am trying to repeat the task installing GeoNode-Project in a
> server in our network, and I am facing the issue bellow.   It seems
> database connection issue:
> >>> celery4my_geonode | django.db.utils.OperationalError: could not
> connect to server: Connection refused
> >>> celery4my_geonode |     Is the server running on host "localhost"
> (127.0.0.1) and accepting
> >>> celery4my_geonode |     TCP/IP connections on port 5432?
> >>> celery4my_geonode | could not connect to server: Cannot assign
> requested address
> (::1) and accepting
> >>> I tried setting postgres/postgis database from a different server
> (host = 172.21.14.45) as shown bellow, but the problem remains
> >>> DATABASES = {
> >>>     'default': {
> >>>         'ENGINE': 'django.db.backends.postgresql_psycopg2',
> >>>         'NAME': 'geonode',
> >>>         'USER': 'geonode',
> >>>         'PASSWORD': 'geonode',
> >>>         'HOST': 'localhost', --> 172.21.14.45
> >>>         'PORT': '5432',
> >>>         'CONN_TOUT': 900,
> >>>     # vector datastore for uploads
> >>>     'datastore': {
> >>>         'ENGINE': 'django.contrib.gis.db.backends.postgis',
> >>>         # 'ENGINE': '', # Empty ENGINE name disables
> >>>         'NAME': 'geonode_data',
> >>>         'USER': 'geonode',
> >>>         'PORT': '5432',
> >>>         'CONN_TOUT': 900,
> >>> Geoserver is running smoothly, but Django and Celery are up,  giving
> always a response of
> >>> 502 Bad Gateway
> >>> ________________________________
> >>> nginx/1.15.0
> >>> Any comment on that will be very appreciated.
> >>> Thank you very much for your time in advance.
> >>> Julierme
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181121/62e25e7e/attachment.html>
More information about the geonode-users mailing list
