[GeoNode-users] GeoNode-Project Installation
Paolo Corti
pcorti at gmail.com
Wed Nov 21 12:18:17 PST 2018
502 status error means that there is something which caused your wsgi
process fail to start. You will find the reason checking the wsgi
logs.
hope this helps
best
Paolo
On Wed, Nov 21, 2018 at 1:23 PM Julierme Pinheiro
<juliermeopensourcedeveloper at gmail.com> wrote:
> Dear Paolo Corti,
> Thank you very much for your reply.
> Yes I can connect to database:
> psql -h 172.21.14.45 -U geonode -d geonode
> psql (10.6 (Ubuntu 10.6-0ubuntu0.18.04.1), server 9.5.14)
> Type "help" for help.
> geonode=> \q
> Now. I want to skip the remote database connection for GeoNode-Project installed via Docker as I am using the os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings") in wsgi.py file. By just using db4my_geonode and os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings"), GeoNode-Project at 2.8 installation goes fine until the end. Now, here is the issue: if I make local_settings.py available in my_geonode/my_geonode/ and set wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings"), I get the forever response:
> 502 Bad Gateway
> I appreciated your time
> Julierme
> On Wed, Nov 21, 2018 at 2:20 PM Paolo Corti <pcorti at gmail.com> wrote:
>> Hi
>> first thing to test: can you connect from the server with psql to the database?
>> best
>> Paolo
>> On Wed, Nov 21, 2018 at 11:16 AM Julierme Pinheiro
>> > ...and yes, in the case of using os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings"), I have local_settings.py in my /my_geonode/my_geonode/ path.
>> > Thank you for your time in advance.
>> > Julierme
>> > On Wed, Nov 21, 2018 at 1:55 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
>> >> Hi all,
>> >> Regarding the previous e-mail, I made a test here. Following the guide to install GeoNode-Project at 2.8, everything works fine if I set the settings in my_geonode/wsgi.py as os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.settings"). However, if I change to <local_settings> in my_geonode/wsgi.py to os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings"), I have the issues showed in the previous e-mail. Is there anything else that I must pay attention or may be missing configuration?
>> >> Any help on that would be appreciated.
>> >> Kind regards
>> >> Julierme
>> >> On Tue, Nov 20, 2018 at 1:18 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
>> >>> Hi GeoNode users,
>> >>> I have Geonode-Project installed via Docker in Centos7 Vm and all works fine after following the guide in here.
>> >>> Now, I am trying to repeat the task installing GeoNode-Project in a server in our network, and I am facing the issue bellow. It seems database connection issue:
>> >>> celery4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
>> >>> celery4my_geonode | Is the server running on host "localhost" (127.0.0.1) and accepting
>> >>> celery4my_geonode | TCP/IP connections on port 5432?
>> >>> celery4my_geonode | could not connect to server: Cannot assign requested address
>> >>> celery4my_geonode | Is the server running on host "localhost" (::1) and accepting
>> >>> I tried setting postgres/postgis database from a different server (host = 172.21.14.45) as shown bellow, but the problem remains
>> >>> DATABASES = {
>> >>> 'default': {
>> >>> 'ENGINE': 'django.db.backends.postgresql_psycopg2',
>> >>> 'NAME': 'geonode',
>> >>> 'USER': 'geonode',
>> >>> 'PASSWORD': 'geonode',
>> >>> 'HOST': 'localhost', --> 172.21.14.45
>> >>> 'PORT': '5432',
>> >>> 'CONN_TOUT': 900,
>> >>> # vector datastore for uploads
>> >>> 'datastore': {
>> >>> 'ENGINE': 'django.contrib.gis.db.backends.postgis',
>> >>> # 'ENGINE': '', # Empty ENGINE name disables
>> >>> 'NAME': 'geonode_data',
>> >>> 'USER': 'geonode',
>> >>> 'PORT': '5432',
>> >>> 'CONN_TOUT': 900,
>> >>> Geoserver is running smoothly, but Django and Celery are up, giving always a response of
>> >>> 502 Bad Gateway
>> >>> ________________________________
>> >>> nginx/1.15.0
>> >>> Any comment on that will be very appreciated.
>> >>> Thank you very much for your time in advance.
>> >>> Julierme
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users
