[GeoNode-users] GeoNode-Project Installation
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Nov 22 10:47:49 PST 2018
Hi Toni,
Thank you very much for the hints. I see in
https://github.com/GeoNode/geonode/commits/master/geonode/local_settings.py.geoserver.sample
that there is a lot of work and contributions behind the whole project. You
all deserve many rounds of beer in the next Summit. I hope to be there to
celebrate with you all.
I noticed those differences I mentioned before, mainly settings.py at 2.7 has
more configuration than settings.py at 2.8. And I am not sure about whether
SITEURL can be declared before SITE_HOST_NAME and SITE_HOST_PORT (I can do
a test changing SITEURL location in the file) in local_settings.py. My
first guess is not because python interprets the file from top to the
bottom.
One thing to consider is: If we follow the guide
<https://github.com/GeoNode/geonode-project/tree/2.8> the way it is, using
local_settings in wsgi.py. The GeoNode-Project at 2.8 docker installation will
fail.
I appreciated your time, Toni.
Kind regards
Julierme
On Thu, Nov 22, 2018 at 4:09 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hi Julierme,
> as a little hint. With github you can view the history of each file.
> For example local_settings:
> The commit message often explains why the file was updated.
> When you click the button on the right hand side showing a specific commit
> hash
> you get a nice diff view what has changed. With this it should be easy to
> see what changed form 2.7 to 2.8 etc.
> Do you notice something?
> – Exactly! Most of the time it´s Allesio who changed the file.
> That´s why we should spend him not only one round of beer
> at the next summit :))
> Hope this makes your work a bit easier
> Cheers,
> Toni
> Am 22.11.2018 um 18:10 schrieb geonode-users-request at lists.osgeo.org:
> Message: 2
> Date: Thu, 22 Nov 2018 15:10:40 -0200
> From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
> To: handy at galerigis.com
> Cc: geonode-users <geonode-users at lists.osgeo.org>, Paolo Corti
> <pcorti at gmail.com>
> Subject: Re: [GeoNode-users] GeoNode-Project Installation
> Message-ID:
> <CAKTKyJKinYoxwh4KV4VvqB2CaVGP407h8_y-cRDc1WLQVRm7+A at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Dear all,
> Ok. After many tests, I finally got GeoNode-Project installed using
> "local_settings" in my_geonode/wsgi.py -->
> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> "my_geonode.local_settings").
> I have an old instance of GeoNode-Project at 2.7 running in a VM. I compared
> settings and local_settings files of GeoNode-Project at 2.7 and
> GeoNode-Project at 2.8. Here are some differences found:
> Regarding local_settings.py
> In GeoNode-Project at 2.8 SITEURL is declared before SITE_HOST_NAME and
> SITE_HOST_PORT. But SITEURL depends on both variables.
> In contrast, GeoNode-Project at 2.7, its local_settings.py sets SITEURL right
> after SITE_HOST_PORT and SITE_HOST_NAME. It seems the correct settings.
> Regarding settings.py
> What I realized is that settings.py for GeoNode-Project at 2.8 is smaller
> than
> GeoNode-Project at 2.7. For instance I can find configuration for # prevent
> signing up by default # in Geonode-Project at 2.7 settings.py , but I can not
> find the same config in GeoNode-Project at 2.8 settings.p.
> What I did: I cloned geonode-project and my_geonode folders for
> GeoNode-Project at 2.8 and I used settings.py at 2.7 and local_settings.py at 2.7
> instead of
> settings.py at 2.8 and local_settings.py at 2.8. The response is:
> GeoNode-Project at 2.8 is up and running via Docker installation.
> Find the files settings.py and local_settings.py for GeoNode-Project at 2.7
> and GeoNode-Project at 2.8 in attached.
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181122/25b83364/attachment-0001.html>
More information about the geonode-users
