[GeoNode-users] WMS GetCapabilities request takes too long to response on GeoExplorer
Francesco Bartoli xbartolone at gmail.com
Fri Nov 23 04:57:07 PST 2018
There could be but it’s likely you have
Il 23 nov 2018, 13:54 +0100, gpetrak <gkpetrak at gmail.com>, ha scritto:
> Τhank you for your response Francesco,
> We 're planning to upgrade to the latest version of GeoNode in about four months but until then we have to work with these version (GeoNode / GeoServer). I'm searching for a less "time consuming" solution for the near future and when I found that other GeoNode instances with older GeoServer versions (e.g 2.5) works fine with WMS GetCapabilities request, I supposed that there should be an easier solution.
> Best regards,
> George
> On 23/11/18 14:34, Francesco Bartoli wrote:
> > Hi George,
> > even if there are cases which are still using such quite old version the suggestions here are still the same, I would strongly consider the upgrade. Neither GeoServer community nor GeoNode one still supports that version anymore.
> > Best,
> > Francesco
> > Il 23 nov 2018, 13:01 +0100, George Petrakis <gkpetrak at gmail.com>, ha scritto:
> > > Hello GeoNode community,
> > > We are using a GeoNode 2.4 instance with about 300 vector and 30 raster layers. Everything works fine except the WMS GetCapabilities response on GeoExplorer. It takes about 3 minutes to load WMS GetCapabilities document. The version of GeoServer that is used by GeoNode is 2.7.
> > > I have limited the SRSs from WMS  GeoServer admin page but the result is the same.
> > > I posted a question on GIS stackoverflow ( https://gis.stackexchange.com/questions/303652/geoservers-wms-getcapabilities-request-takes-too-long-to-respond?noredirect=1#comment489418_303652 ) for this issue and it is proposed to upgrade GeoServer to the current version (2.13).
> > > I think that it's not the only solution because I searched in other GeoNode instances (from GeoNode Gallery) and there are many instances with GeoServer 2.7 and many layers stored in which WMS GetCapabilities is loaded very fast on GeoExplorer.
> > > Any suggestions ?
> > > Thank you in advance !
> > > George
> > > Πετράκης Γεώργιος
> > > Αγρ & Τοπογράφος Μηχανικός ΕΜΠ
> > > MSc Γεωτεχνολογία & Περιβάλλον
> > > Πλ. Ελευθερίας 29Α (Μέγαρο Ντορέ)
> > > Τηλ: 2810-288363
> > > Κιν: 6984871889
> > > _______________________________________________
> > > geonode-users mailing list
> > > geonode-users at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181123/ca6dc085/attachment.html>
More information about the geonode-users mailing list
