[GeoNode-users] WMS GetCapabilities request takes too long to response on GeoExplorer
gpetrak
gkpetrak at gmail.com
Fri Nov 23 04:54:19 PST 2018
Τhank you for your response Francesco,
We 're planning to upgrade to the latest version of GeoNode in about
four months but until then we have to work with these version (GeoNode /
GeoServer). I'm searching for a less "time consuming" solution for the
near future and when I found that other GeoNode instances with older
GeoServer versions (e.g 2.5) works fine with WMS GetCapabilities
request, I supposed that there should be an easier solution.
Best regards,
George
On 23/11/18 14:34, Francesco Bartoli wrote:
> Hi George,
> even if there are cases which are still using such quite old version
> the suggestions here are still the same, I would strongly consider the
> upgrade. Neither GeoServer community nor GeoNode one still supports
> that version anymore.
> Best,
> Francesco
> Il 23 nov 2018, 13:01 +0100, George Petrakis <gkpetrak at gmail.com>, ha
> scritto:
>> Hello GeoNode community,
>> We are using a GeoNode 2.4 instance with about 300 vector and 30
>> raster layers. Everything works fine except the WMS GetCapabilities
>> response on GeoExplorer. It takes about 3 minutes to load WMS
>> GetCapabilities document. The version of GeoServer that is used by
>> GeoNode is 2.7.
>> I have limited the SRSs from WMS GeoServer admin page but the result
>> is the same.
>> I posted a question on GIS stackoverflow (
>> https://gis.stackexchange.com/questions/303652/geoservers-wms-getcapabilities-request-takes-too-long-to-respond?noredirect=1#comment489418_303652
>> ) for this issue and it is proposed to upgrade GeoServer to the
>> current version (2.13).
>> I think that it's not the only solution because I searched in other
>> GeoNode instances (from GeoNode Gallery) and there are many instances
>> with GeoServer 2.7 and many layers stored in which WMS
>> GetCapabilities is loaded very fast on GeoExplorer.
>> Any suggestions ?
>> Thank you in advance !
>> George
>> Πετράκης Γεώργιος
>> Αγρ & Τοπογράφος Μηχανικός ΕΜΠ
>> MSc Γεωτεχνολογία & Περιβάλλον
>> Πλ. Ελευθερίας 29Α (Μέγαρο Ντορέ)
>> Τηλ: 2810-288363
>> Κιν: 6984871889
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181123/adbd9b8f/attachment.html>
More information about the geonode-users
