[GeoNode-users] WMS GetCapabilities request takes too long to response on GeoExplorer
Francesco Bartoli xbartolone at gmail.com
Fri Nov 23 04:34:32 PST 2018
Hi George,
even if there are cases which are still using such quite old version the suggestions here are still the same, I would strongly consider the upgrade. Neither GeoServer community nor GeoNode one still supports that version anymore.
Best,
Francesco
Il 23 nov 2018, 13:01 +0100, George Petrakis <gkpetrak at gmail.com>, ha scritto:
> Hello GeoNode community,
> We are using a GeoNode 2.4 instance with about 300 vector and 30 raster layers. Everything works fine except the WMS GetCapabilities response on GeoExplorer. It takes about 3 minutes to load WMS GetCapabilities document. The version of GeoServer that is used by GeoNode is 2.7.
> I have limited the SRSs from WMS  GeoServer admin page but the result is the same.
> I posted a question on GIS stackoverflow ( https://gis.stackexchange.com/questions/303652/geoservers-wms-getcapabilities-request-takes-too-long-to-respond?noredirect=1#comment489418_303652 ) for this issue and it is proposed to upgrade GeoServer to the current version (2.13).
> I think that it's not the only solution because I searched in other GeoNode instances (from GeoNode Gallery) and there are many instances with GeoServer 2.7 and many layers stored in which WMS GetCapabilities is loaded very fast on GeoExplorer.
> Any suggestions ?
> Thank you in advance !
> George
> Πετράκης Γεώργιος
> Αγρ & Τοπογράφος Μηχανικός ΕΜΠ
> MSc Γεωτεχνολογία & Περιβάλλον
> Πλ. Ελευθερίας 29Α (Μέγαρο Ντορέ)
> Τηλ: 2810-288363
> Κιν: 6984871889
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181123/4121749f/attachment-0001.html>
More information about the geonode-users mailing list
