[GeoNode-users] Zoom to layer extend does not work (Paulo Frias)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Oct 1 05:18:35 PDT 2018
Do you mean by using "apt-get" package?
If so, yes, there are ways to update it manually, but it won't be straight
not easy to achieve unfortunately.
Il giorno lun 1 ott 2018 alle ore 12:27 Matteo Conte <matteo.conte at abitat.it>
ha scritto:
> Hi Alessio,
>    I've installed geonode from quick install. Is possible to keep update
> this type of installation?
> Kind regards,
> Matteo
> *Da: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> *A: *"matteo.conte" <matteo.conte at abitat.it>
> *Cc: *"geonode-users" <geonode-users at lists.osgeo.org>
> *Inviato: *Venerdì, 28 settembre 2018 10:40:53
> *Oggetto: *Re: [GeoNode-users] Zoom to layer extend does not work (Paulo
> Frias)
> Dear all,
> this issue has been already fixed on the latest versions. You should try
> to update your instance to the latest ones.
> If you want to give it a try, you can try this very easy setup and test it
> locally:
> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
> There are also ways to deploy this on a public instance:
> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#start-your-server
> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#if-you-want-to-run-the-instance-on-a-public-site
> quite straightforward.
> The advantages of those approaches are that:
> 1. You will have up-to-date GeoNode and GeoServer versions
> 2. You will be able to keep GeoNode updates in the future
> Il giorno ven 28 set 2018 alle ore 10:07 Matteo Conte <
> matteo.conte at abitat.it> ha scritto:
>> Hi,
>>    I have same issue. Geoserver layer preview work fine.
>> Kind regards
>> Matteo
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181001/5d73191d/attachment-0001.html>
More information about the geonode-users mailing list
