[GeoNode-users] Zoom to layer extend does not work (Paulo Frias)
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Oct 1 07:10:13 PDT 2018
Uhm,
I'm not aware of an "official" documentation page to do that. If you are
not in a hurry, I can devote some time creating one.
Il giorno lun 1 ott 2018 alle ore 16:01 Matteo Conte <matteo.conte at abitat.it>
ha scritto:
> Hi Alessio,
> yes I used apt-get to install geonode. Where I can find informations
> about these ways?
> Kind regards
> Matteo
> *Da: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> *A: *"matteo.conte" <matteo.conte at abitat.it>
> *Cc: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>,
> "geonode-users" <geonode-users at lists.osgeo.org>
> *Inviato: *Lunedì, 1 ottobre 2018 14:18:35
> *Oggetto: *Re: [GeoNode-users] Zoom to layer extend does not work (Paulo
> Frias)
> Do you mean by using "apt-get" package?
> If so, yes, there are ways to update it manually, but it won't be straight
> not easy to achieve unfortunately.
> Il giorno lun 1 ott 2018 alle ore 12:27 Matteo Conte <
> matteo.conte at abitat.it> ha scritto:
>> Hi Alessio,
>> I've installed geonode from quick install. Is possible to keep update
>> this type of installation?
>> Kind regards,
>> Matteo
>> *Cc: *"geonode-users" <geonode-users at lists.osgeo.org>
>> *Inviato: *Venerdì, 28 settembre 2018 10:40:53
>> Frias)
>> Dear all,
>> this issue has been already fixed on the latest versions. You should try
>> to update your instance to the latest ones.
>> If you want to give it a try, you can try this very easy setup and test
>> it locally:
>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project
>> There are also ways to deploy this on a public instance:
>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#start-your-server
>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#if-you-want-to-run-the-instance-on-a-public-site
>> quite straightforward.
>> The advantages of those approaches are that:
>> 1. You will have up-to-date GeoNode and GeoServer versions
>> 2. You will be able to keep GeoNode updates in the future
>> Il giorno ven 28 set 2018 alle ore 10:07 Matteo Conte <
>>> Hi,
>>> I have same issue. Geoserver layer preview work fine.
>>> Kind regards
>>> Matteo
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181001/b27674d4/attachment-0001.html>
More information about the geonode-users
