[GeoNode-users] basic authentication with GeoNode 2.8, GeoServer 2.14 and GeoFence
Paolo Corti
pcorti at gmail.com
Tue Oct 2 16:02:36 PDT 2018
Hi Alessio
all of the layers in our instance are published and advertised on GeoServer.
For example try this layer in our staging instance.
Layer details page in GeoNode:
http://128.31.22.103/layers/geonode:Neighborhoods_BRA_1
Layer GetCapabilities:
http://128.31.22.103/geoserver/geonode/Neighborhoods_BRA_1/wms?service=WMS&request=GetCapabilities
The layer GetCapabilities is correctly returned when I am logged as
GeoServer admin, but it returns a 404 when I am not.
Thanks for your help!
Paolo
On Tue, Oct 2, 2018 at 4:28 PM Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Hi Paolo,
> it is working here. Remember that the Layer must be published too, which means "Advertised" on GeoServer.
> Il giorno mar 2 ott 2018 alle ore 22:13 Paolo Corti <pcorti at gmail.com> ha scritto:
>> Hi Alessio
>> the url I am using it is correct. If I open it in an authenticated
>> browser (logged in as GeoServer admin), it returns the correct
>> GetCapabilities document.
>> Unfortunately it is not working from a not authenticated sessions. I
>> believe GeoFence is not giving access to the layer.
>> I realized that in my previous email I didn't include the correct link
>> to the log file https://paste.ofcode.org/3aBryGaRK7Xz3j3ySqXxfkN
>> hope this helps you to suggest a solution to this problem
>> thanks!
>> Paolo
>> On Tue, Oct 2, 2018 at 3:45 PM Alessio Fabiani
>> > As an instance
>> > http://dev.geonode.geo-solutions.it/geoserver/geonode/states/wms?request=GetCapabilities
>> > Il giorno mar 2 ott 2018 alle ore 21:16 Paolo Corti <pcorti at gmail.com> ha scritto:
>> >> Dear list
>> >> This is most likely for Alessio, but maybe someone else in the list can help.
>> >> I am experiencing this in GeoNode 2.8 and GeoServer 2.14.
>> >> I would need to access GeoServer OGC endpoints with curl or owslib
>> >> using basic authentication. Unfortunately this doesn't look to work
>> >> anymore - while it was working on previous versions GeoNode/GeoServer.
>> >> This is a sample request I do:
>> >> curl -v -u user:password -XGET -H "Accept: text/xml"
>> >> http://myip/geoserver/geonode/layername/wms
>> >> I receive a 404.
>> >> Here is what I see in GeoServer log file: https://paste.ofcode.org/
>> >> When opening the same url in a web browser authenticated with GeoNode
>> >> I don't get the 404.
>> >> Any hint here? Thanks in advance!
>> >> Paolo
>> >> Paolo Corti
>> >> Geospatial software developer
>> >> web: http://www.paolocorti.net
>> >> twitter: @capooti
>> >> skype: capooti
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> > GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
>> > Ing. Alessio Fabiani
>> > @alfa7691
>> > Founder/Technical Lead
>> > GeoSolutions S.A.S.
>> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> > phone: +39 0584 962313
>> > fax: +39 0584 1660272
>> > mob: +39 331 6233686
>> > http://www.geo-solutions.it
>> > http://twitter.com/geosolutions_it
>> > Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> > This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> @alfa7691
> GeoSolutions S.A.S.
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users
