[GeoNode-users] basic authentication with GeoNode 2.8, GeoServer 2.14 and GeoFence
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Oct 3 01:16:29 PDT 2018
Hi Paolo,
yeps, it is quite strange indeed.
It really looks to me that it is due to GeoFence rules somehow. Sometimes
the rules of GeoFence could be a bit tricky.
Any chance to send here all the rules associated to one of those layers?
Il giorno mer 3 ott 2018 alle ore 01:03 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio
> all of the layers in our instance are published and advertised on
> GeoServer.
> For example try this layer in our staging instance.
> Layer details page in GeoNode:
> http://128.31.22.103/layers/geonode:Neighborhoods_BRA_1
> Layer GetCapabilities:
> http://128.31.22.103/geoserver/geonode/Neighborhoods_BRA_1/wms?service=WMS&request=GetCapabilities
> The layer GetCapabilities is correctly returned when I am logged as
> GeoServer admin, but it returns a 404 when I am not.
> Thanks for your help!
> Paolo
> On Tue, Oct 2, 2018 at 4:28 PM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Hi Paolo,
> > it is working here. Remember that the Layer must be published too, which
> means "Advertised" on GeoServer.
> > Il giorno mar 2 ott 2018 alle ore 22:13 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> Hi Alessio
> >> the url I am using it is correct. If I open it in an authenticated
> >> browser (logged in as GeoServer admin), it returns the correct
> >> GetCapabilities document.
> >> Unfortunately it is not working from a not authenticated sessions. I
> >> believe GeoFence is not giving access to the layer.
> >> I realized that in my previous email I didn't include the correct link
> >> to the log file https://paste.ofcode.org/3aBryGaRK7Xz3j3ySqXxfkN
> >> hope this helps you to suggest a solution to this problem
> >> thanks!
> >> Paolo
> >> On Tue, Oct 2, 2018 at 3:45 PM Alessio Fabiani
> >> > As an instance
> http://dev.geonode.geo-solutions.it/geoserver/geonode/states/wms?request=GetCapabilities
> >> > Il giorno mar 2 ott 2018 alle ore 21:16 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> >> Dear list
> >> >> This is most likely for Alessio, but maybe someone else in the list
> can help.
> >> >> I am experiencing this in GeoNode 2.8 and GeoServer 2.14.
> >> >> I would need to access GeoServer OGC endpoints with curl or owslib
> >> >> using basic authentication. Unfortunately this doesn't look to work
> >> >> anymore - while it was working on previous versions
> GeoNode/GeoServer.
> >> >> This is a sample request I do:
> >> >> curl -v -u user:password -XGET -H "Accept: text/xml"
> >> >> http://myip/geoserver/geonode/layername/wms
> >> >> I receive a 404.
> >> >> Here is what I see in GeoServer log file: https://paste.ofcode.org/
> >> >> When opening the same url in a web browser authenticated with GeoNode
> >> >> I don't get the 404.
> >> >> Any hint here? Thanks in advance!
> >> >> Paolo
> >> >> Paolo Corti
> >> >> Geospatial software developer
> >> >> web: http://www.paolocorti.net
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> >> _______________________________________________
> >> >> geonode-users mailing list
> >> >> geonode-users at lists.osgeo.org
> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> >> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >> > Ing. Alessio Fabiani
> >> > @alfa7691
> >> > Founder/Technical Lead
> >> > GeoSolutions S.A.S.
> >> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> > phone: +39 0584 962313
> >> > fax: +39 0584 1660272
> >> > mob: +39 331 6233686
> >> > http://www.geo-solutions.it
> >> > http://twitter.com/geosolutions_it
> >> > Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
> si precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> > @alfa7691
> > GeoSolutions S.A.S.
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> Paolo Corti
> twitter: @capooti
> skype: capooti
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181003/2b643ee9/attachment-0001.html>
More information about the geonode-users
