[GeoNode-users] Google Earth (Satellite) doesn't work anymore on Geonode 2.6.3
Paolo Corti pcorti at gmail.com
Fri Oct 5 14:43:48 PDT 2018
Today I have received the following information from Google support:
*We are in the process of completely disallowing keyless usage, but
currently, it will work intermittently.  It will break again.  Please keep
in mind that keyless usage was deprecated about a year ago, but it was only
with changes starting June 11th that we started to cause it to break
[1].  The code from that Github page is 1) not passing a key, 2) using a
really obsolete method of loading the API and 3) redundantly trying to load
the API after it was already loaded.  The Github code is outside of our
scope of support, but you may want to reach out to the issues section there
[2].  I do note that that code hasn't been updated in 3 years, so you may
need to investigate a more modern solution to do what you are trying to
do.[1] https://developers.google.com/maps/billing/important-updates#starting_june_11th
<https://developers.google.com/maps/billing/important-updates#starting_june_11th>[2]
https://github.com/boundlessgeo/gxp/issues
<https://github.com/boundlessgeo/gxp/issues>*
hope it clarifies things
On Fri, Oct 5, 2018 at 9:45 AM Paolo Corti <pcorti at gmail.com> wrote:
> Dear Ana
> I am not sure about Google Earth.
> But about the API error: we started experiencing the same error yesterday.
> Google base layers were not working. But this morning they are back.
> In our case we also get this error: "You have included the Google Maps
> JavaScript API multiple times on this page. This may cause unexpected
> errors."
> Let's monitor the situation...
> ps Thanks to Bart who helped us to debug the issue with the second error
> message.
> Paolo
> On Thu, Oct 4, 2018 at 2:52 AM Ana Boljevic <ana.boljevic at cedis.me> wrote:
>> Dear Paolo,
>> Yes, I can find GOOGLE_API_KEY in html source of the page (see paolo.JPG).
>> Please answer does Geonode 2.6.3 work with Google Earth anymore?
>> If Yes, how can we fix this issue? What to change in what file?
>> Regards,
>> *Ana Boljević*
>> Direkcija za razvoj, pristup mreži i ICT
>> Sektor za ICT
>> Služba za GIS i tehničku bazu podataka
>> *[image: CEDIS]*
>> *DOO „Crnogorski elektrodistributivni sistem“ Podgorica*
>> Ivana Milutinovića br.12, Podgorica
>> Tel: +382 20 408 473
>> *www.cedis.me <http://www.cedis.me/>*
>> [image: jelkica]Please do not print this e-mail unless you really need to
>> *From:* Paolo Corti [mailto:pcorti at gmail.com]
>> *Sent:* Wednesday, October 3, 2018 4:12 PM
>> *To:* Ana Boljevic <ana.boljevic at cedis.me>
>> *Cc:* geonode-users-bounces at lists.osgeo.org; geonode-users <
>> geonode-users at lists.osgeo.org>
>> *Subject:* Re: [GeoNode-users] Google Earth (Satellite) doesn't work
>> Hello Ana
>> if you look at the html source of the page, can you see if the Google API
>> is called using your GOOGLE_API_KEY?
>> By the way it is not a good practice to manually change the main GeoNode
>> settings file. The recommended approach is setting the variable (in your
>> case GOOGLE_API_KEY) as an environment variable of your wsgi processor of
>> your web server (for example uwsgi).
>> best
>> Paolo
>> On Wed, Oct 3, 2018 at 3:50 AM Ana Boljevic <ana.boljevic at cedis.me>
>> wrote:
>> Dear Geonode Community,
>> We have one issue, if someone can help.
>> We have put into file:
>>  /usr/local/lib/python2.7/dist-packages/geonode/settings.py
>>    GOOGLE_API_KEY = '***************************'
>> Inside MAP_BASELAYERS code lines, insert and save the following:
>>     "source": {"ptype": "gxp_googlesource",
>>     "apiKey": GOOGLE_API_KEY},
>>     "group":"background",
>>     "name":"SATELLITE",
>>     "visibility": False,
>>     "fixed": True},
>> When we try to reach google satellite Baselayer from Chrome (Developer
>> tools) we receive the following message (attachment google_satellite.JPG):
>> Google Maps JavaScript API warning: NoApiKeys
>> https://developers.google.com/maps/documentation/javascript/error-messages
>> If you can give us any help or idea how to resolve this problem we would
>> be very thankful.
>> Best regards,
>> *Ana Boljević*
>> Sektor za ICT
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181005/c5b270c2/attachment.html>
More information about the geonode-users mailing list
