[GeoNode-users] Google Earth (Satellite) doesn't work anymore on Geonode 2.6.3
Ana Boljevic ana.boljevic at cedis.me
Mon Oct 8 04:23:58 PDT 2018
Dear Paolo,
Please see attachment again (apikeys.JPG). We believe that our browser receive google apikey and that not in category keyless users.
Much more we believe that in GeoNode 2.6.3 baselayer Google Earth stop working because of:
"If you are loading Maps JavaScript API from the deprecated v2 path with an old v2 key, you will get the NoApiKeys warning, even if you specified the key parameter. Please check the v2 to v3 upgrade guide<https://developers.google.com/maps/documentation/javascript/v2tov3> and migrate your application to Maps JavaScript API v3."
Please see apikeys2.JPG in attachment.
One more time, does GeoNode v2.6.3 can overcome this issue?
Regards,
Ana Boljević
Direkcija za razvoj, pristup mreži i ICT
Sektor za ICT
Služba za GIS i tehničku bazu podataka
[cid:a7a9ffbf-8afe-4c41-995a-14b7d46f40a0]
DOO „Crnogorski elektrodistributivni sistem“ Podgorica
Ivana Milutinovića br.12, Podgorica
Tel: +382 20 408 473
www.cedis.me<http://www.cedis.me/>
[cid:6e247109-0ad6-444e-8b9d-41f53d2a3d14]Please do not print this e-mail unless you really need to
Sent: Friday, October 5, 2018 11:43:48 PM
To: Ana Boljevic
Cc: geonode-users-bounces at lists.osgeo.org; geonode-users; Bart van den Eijnden
Subject: Re: [GeoNode-users] Google Earth (Satellite) doesn't work anymore on Geonode 2.6.3
Today I have received the following information from Google support:
We are in the process of completely disallowing keyless usage, but currently, it will work intermittently.  It will break again.  Please keep in mind that keyless usage was deprecated about a year ago, but it was only with changes starting June 11th that we started to cause it to break [1].
The code from that Github page is 1) not passing a key, 2) using a really obsolete method of loading the API and 3) redundantly trying to load the API after it was already loaded.  The Github code is outside of our scope of support, but you may want to reach out to the issues section there [2].  I do note that that code hasn't been updated in 3 years, so you may need to investigate a more modern solution to do what you are trying to do.
[1] https://developers.google.com/maps/billing/important-updates#starting_june_11th
[2] https://github.com/boundlessgeo/gxp/issues
hope it clarifies things
On Fri, Oct 5, 2018 at 9:45 AM Paolo Corti <pcorti at gmail.com<mailto:pcorti at gmail.com>> wrote:
Dear Ana
I am not sure about Google Earth.
But about the API error: we started experiencing the same error yesterday. Google base layers were not working. But this morning they are back.
In our case we also get this error: "You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors."
Let's monitor the situation...
ps Thanks to Bart who helped us to debug the issue with the second error message.
Paolo
On Thu, Oct 4, 2018 at 2:52 AM Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear Paolo,
Yes, I can find GOOGLE_API_KEY in html source of the page (see paolo.JPG).
Please answer does Geonode 2.6.3 work with Google Earth anymore?
If Yes, how can we fix this issue? What to change in what file?
Regards,
Ana Boljević
Sektor za ICT
[CEDIS]
[jelkica]Please do not print this e-mail unless you really need to
From: Paolo Corti [mailto:pcorti at gmail.com<mailto:pcorti at gmail.com>]
Sent: Wednesday, October 3, 2018 4:12 PM
To: Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>
Cc: geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
Hello Ana
if you look at the html source of the page, can you see if the Google API is called using your GOOGLE_API_KEY?
By the way it is not a good practice to manually change the main GeoNode settings file. The recommended approach is setting the variable (in your case GOOGLE_API_KEY) as an environment variable of your wsgi processor of your web server (for example uwsgi).
best
Paolo
On Wed, Oct 3, 2018 at 3:50 AM Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear Geonode Community,
We have one issue, if someone can help.
We have put into file:
 /usr/local/lib/python2.7/dist-packages/geonode/settings.py
   GOOGLE_API_KEY = '***************************'
Inside MAP_BASELAYERS code lines, insert and save the following:
    "source": {"ptype": "gxp_googlesource",
    "apiKey": GOOGLE_API_KEY},
    "group":"background",
    "name":"SATELLITE",
    "visibility": False,
    "fixed": True},
When we try to reach google satellite Baselayer from Chrome (Developer tools) we receive the following message (attachment google_satellite.JPG):
Google Maps JavaScript API warning: NoApiKeys https://developers.google.com/maps/documentation/javascript/error-messages
If you can give us any help or idea how to resolve this problem we would be very thankful.
Best regards,
Ana Boljević
Sektor za ICT
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181008/6f86da05/attachment-0001.html>
Type: image/jpeg
Desc: apikeys2.JPG
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181008/6f86da05/attachment-0002.jpe>
Type: image/jpeg
Desc: apikeys.JPG
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181008/6f86da05/attachment-0003.jpe>
More information about the geonode-users mailing list
