[GeoNode-users] How do I install Geonode 2.6.3 on Ubuntu 16.04 or 18.04?
Elton Davis Turin Espinoza eturine at uni.pe
Thu Oct 11 14:01:12 PDT 2018
Hi all,
I also want to use Geonode 2.6 again and I can not install from ppa apt-get.
Please, if you can re-enable the installation of Geonode 2.6, I would be
very grateful.
King regards
Elton
El jue., 11 oct. 2018 a las 12:28, Julierme Pinheiro (<
juliermeopensourcedeveloper at gmail.com>) escribió:
> Dear Simon Lee,
> If you are looking for GeoNode at 2.6.x. I will strongly recommend you to
> take a look in this project <https://github.com/olivierdalang/SPCgeonode>.
> Following the Docker Installation procedure, I think you may not face any
> issue in respect to Ubuntu version.
> I hope it helps. I will be glad to help, if you need further assistance.
> Kind Regards
> Julierme
> On Thu, Oct 11, 2018 at 1:58 PM Simon Lee <simon.lee at null.net> wrote:
>> I tried to use the manual install method, cloning the 2.6.x branch from
>> GitHub, but when I run paver setup it outputs an error. I tried both "paver
>> setup" and "sudo paver setup" with the same effect.
>> I guess that's because http://build.geonode.org/geoserver/latest/ is not
>> reachable. I downloaded the official geoserver.war but it doesn't work
>> because of auth. Any help? :)
>> Here's the output:
>> simon at ubuntu:~/geonode$ sudo paver setup
>> ---> pavement.setup
>> ---> pavement.setup_geoserver
>> Downloading geoserver binary
>> Captured Task Output:
>> ---> pavement.setup
>> Traceback (most recent call last):
>>   File "/home/simon/.local/lib/python2.7/site-packages/paver/tasks.py",
>> line 201, in _run_task
>>     return do_task()
>> line 197, in do_task
>>     task()
>> line 333, in __call__
>>     retval = environment._run_task(self.name, self.needs, self.func)
>> line 219, in _run_task
>>     return do_task()
>> line 198, in do_task
>>     return func(**kw)
>>   File "pavement.py", line 106, in setup_geoserver
>>     "geoserver binary")
>>   File "pavement.py", line 74, in grab
>>     urllib.urlretrieve(str(src), str(dest))
>>   File "/usr/lib/python2.7/urllib.py", line 98, in urlretrieve
>>     return opener.retrieve(url, filename, reporthook, data)
>>   File "/usr/lib/python2.7/urllib.py", line 245, in retrieve
>>     fp = self.open(url, data)
>>   File "/usr/lib/python2.7/urllib.py", line 213, in open
>>     return getattr(self, name)(url)
>>   File "/usr/lib/python2.7/urllib.py", line 350, in open_http
>>     h.endheaders(data)
>>   File "/usr/lib/python2.7/httplib.py", line 1038, in endheaders
>>     self._send_output(message_body)
>>   File "/usr/lib/python2.7/httplib.py", line 882, in _send_output
>>     self.send(msg)
>>   File "/usr/lib/python2.7/httplib.py", line 844, in send
>>     self.connect()
>>   File "/usr/lib/python2.7/httplib.py", line 821, in connect
>>     self.timeout, self.source_address)
>>   File "/usr/lib/python2.7/socket.py", line 575, in create_connection
>>     raise err
>> IOError: [Errno socket error] [Errno 110] Connection timed out
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
"Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
entidad que se muestra como destinatario/s y pueden contener datos
personales y/o información confidencial, sometida a secreto profesional o
cuya divulgación esté prohibida en la legislación
 vigente. Que
<http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación, reproducción u
otra acción
al respecto por parte de personas o entidades  distintas al
destinatario/s. Si ha recibido este mensaje por error, por favor,
contáctenos a la siguiente dirección de correo electrónico
 lpdp at uni.edu.pe
<mailto:lpdp at uni.edu.pe> y proceda a su eliminación.
En cumplimiento a
lo establecido en la Ley de Protección de Datos
Personales - Ley N° 29733,
le informamos que sus datos personales
obtenidos son almacenados bajo la
confidencialidad y las medidas de
seguridad legalmente establecidas y no
serán cedidos ni
 compartidos con empresas ni entidades ajenas a la
Universidad Nacional
de Ingeniería. Si lo desea, usted podrá ejercitar los
derechos de
actualización, inclusión, rectificación, supresión u
oposición, enviando
 un mensaje al correo electrónico anteriormente
señalado e indicando en el "Asunto" el derecho que desea ejercer"
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181011/995a8d43/attachment.html>
More information about the geonode-users mailing list
