[GeoNode-users] How do I install Geonode 2.6.3 on Ubuntu 16.04 or 18.04?
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Thu Oct 11 14:22:38 PDT 2018
Hi Elton,
You can get a GeoNode at 2.6.3 instance using Docker Installation. Take a look
in this project:
https://github.com/olivierdalang/SPCgeonode
I do not know why you are facing this issue via apt-get installation.
Looking at https://github.com/GeoNode/geonode/tree/2.6.x. the site
recommends Ubuntu at 14.04. Are you following that?
If you just want to try GeoNode, it is recommended to use Ubuntu 14.04 and
install the latest stable release of GeoNode.:
sudo add-apt-repository ppa:geonode/release
sudo apt-get update
sudo apt-get install geonode
Kind regards
Julierme
On Thu, Oct 11, 2018 at 5:59 PM Elton Davis Turin Espinoza <eturine at uni.pe>
wrote:
> Hi all,
> I also want to use Geonode 2.6 again and I can not install from ppa
> apt-get.
> Please, if you can re-enable the installation of Geonode 2.6, I would be
> very grateful.
> King regards
> Elton
> El jue., 11 oct. 2018 a las 12:28, Julierme Pinheiro (<
> juliermeopensourcedeveloper at gmail.com>) escribió:
>> Dear Simon Lee,
>> If you are looking for GeoNode at 2.6.x. I will strongly recommend you to
>> take a look in this project <https://github.com/olivierdalang/SPCgeonode>.
>> Following the Docker Installation procedure, I think you may not face any
>> issue in respect to Ubuntu version.
>> I hope it helps. I will be glad to help, if you need further assistance.
>> Kind Regards
>> Julierme
>> On Thu, Oct 11, 2018 at 1:58 PM Simon Lee <simon.lee at null.net> wrote:
>>> I tried to use the manual install method, cloning the 2.6.x branch from
>>> GitHub, but when I run paver setup it outputs an error. I tried both "paver
>>> setup" and "sudo paver setup" with the same effect.
>>> I guess that's because http://build.geonode.org/geoserver/latest/ is
>>> not reachable. I downloaded the official geoserver.war but it doesn't work
>>> because of auth. Any help? :)
>>> Here's the output:
>>> simon at ubuntu:~/geonode$ sudo paver setup
>>> ---> pavement.setup
>>> ---> pavement.setup_geoserver
>>> Downloading geoserver binary
>>> Captured Task Output:
>>> ---> pavement.setup
>>> Traceback (most recent call last):
>>>   File "/home/simon/.local/lib/python2.7/site-packages/paver/tasks.py",
>>> line 201, in _run_task
>>>     return do_task()
>>> line 197, in do_task
>>>     task()
>>> line 333, in __call__
>>>     retval = environment._run_task(self.name, self.needs, self.func)
>>> line 219, in _run_task
>>>     return do_task()
>>> line 198, in do_task
>>>     return func(**kw)
>>>   File "pavement.py", line 106, in setup_geoserver
>>>     "geoserver binary")
>>>   File "pavement.py", line 74, in grab
>>>     urllib.urlretrieve(str(src), str(dest))
>>>   File "/usr/lib/python2.7/urllib.py", line 98, in urlretrieve
>>>     return opener.retrieve(url, filename, reporthook, data)
>>>   File "/usr/lib/python2.7/urllib.py", line 245, in retrieve
>>>     fp = self.open(url, data)
>>>   File "/usr/lib/python2.7/urllib.py", line 213, in open
>>>     return getattr(self, name)(url)
>>>   File "/usr/lib/python2.7/urllib.py", line 350, in open_http
>>>     h.endheaders(data)
>>>   File "/usr/lib/python2.7/httplib.py", line 1038, in endheaders
>>>     self._send_output(message_body)
>>>   File "/usr/lib/python2.7/httplib.py", line 882, in _send_output
>>>     self.send(msg)
>>>   File "/usr/lib/python2.7/httplib.py", line 844, in send
>>>     self.connect()
>>>   File "/usr/lib/python2.7/httplib.py", line 821, in connect
>>>     self.timeout, self.source_address)
>>>   File "/usr/lib/python2.7/socket.py", line 575, in create_connection
>>>     raise err
>>> IOError: [Errno socket error] [Errno 110] Connection timed out
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
> entidad que se muestra como destinatario/s y pueden contener datos
> personales y/o información confidencial, sometida a secreto profesional o
> cuya divulgación esté prohibida en la legislación vigente. Que
> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación, reproducción
> u otra acción al respecto por parte de personas o entidades  distintas al
> destinatario/s. Si ha recibido este mensaje por error, por favor,
> contáctenos a la siguiente dirección de correo electrónico lpdp at uni.edu.pe
> y proceda a su eliminación.
> En cumplimiento a lo establecido en la Ley de Protección de Datos
> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
> son almacenados bajo la confidencialidad y las medidas de seguridad
> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
> usted podrá ejercitar los derechos de actualización,
> inclusión, rectificación, supresión u oposición, enviando un mensaje al
> correo electrónico anteriormente señalado e indicando en el "Asunto" el
> derecho que desea ejercer"
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181011/33d33371/attachment-0001.html>
More information about the geonode-users mailing list
