[GeoNode-users] How do I install Geonode 2.6.3 on Ubuntu 16.04 or 18.04?
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Oct 12 00:26:37 PDT 2018
I strongly discourage the setup of GeoNode 2.6.3. It is very bugguy and
unstable.
2.10 version is much more stable and reliable. Try out dev or local setup
through docker by following those simple instructions
https://github.com/GeoNode/geonode-project#start-your-server
About the build server, the old one has been dismissed. New one is
available at
https://build.geo-solutions.it/geonode/geoserver/latest/
Patches already available both on GeoNode 2.8.x and 2.10.x
regards,
Alessio.
Il giorno gio 11 ott 2018 alle ore 23:22 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Elton,
> You can get a GeoNode at 2.6.3 instance using Docker Installation. Take a
> look in this project:
> https://github.com/olivierdalang/SPCgeonode
> I do not know why you are facing this issue via apt-get installation.
> Looking at https://github.com/GeoNode/geonode/tree/2.6.x. the site
> recommends Ubuntu at 14.04. Are you following that?
> If you just want to try GeoNode, it is recommended to use Ubuntu 14.04 and
> install the latest stable release of GeoNode.:
> sudo add-apt-repository ppa:geonode/release
> sudo apt-get update
> sudo apt-get install geonode
> Kind regards
> Julierme
> On Thu, Oct 11, 2018 at 5:59 PM Elton Davis Turin Espinoza <eturine at uni.pe>
> wrote:
>> Hi all,
>> I also want to use Geonode 2.6 again and I can not install from ppa
>> apt-get.
>> Please, if you can re-enable the installation of Geonode 2.6, I would be
>> very grateful.
>> King regards
>> Elton
>> El jue., 11 oct. 2018 a las 12:28, Julierme Pinheiro (<
>> juliermeopensourcedeveloper at gmail.com>) escribió:
>>> Dear Simon Lee,
>>> If you are looking for GeoNode at 2.6.x. I will strongly recommend you to
>>> take a look in this project <https://github.com/olivierdalang/SPCgeonode>.
>>> Following the Docker Installation procedure, I think you may not face any
>>> issue in respect to Ubuntu version.
>>> I hope it helps. I will be glad to help, if you need further assistance.
>>> Kind Regards
>>> Julierme
>>> On Thu, Oct 11, 2018 at 1:58 PM Simon Lee <simon.lee at null.net> wrote:
>>>> I tried to use the manual install method, cloning the 2.6.x branch from
>>>> GitHub, but when I run paver setup it outputs an error. I tried both "paver
>>>> setup" and "sudo paver setup" with the same effect.
>>>> I guess that's because http://build.geonode.org/geoserver/latest/ is
>>>> not reachable. I downloaded the official geoserver.war but it doesn't work
>>>> because of auth. Any help? :)
>>>> Here's the output:
>>>> simon at ubuntu:~/geonode$ sudo paver setup
>>>> ---> pavement.setup
>>>> ---> pavement.setup_geoserver
>>>> Downloading geoserver binary
>>>> Captured Task Output:
>>>> ---> pavement.setup
>>>> Traceback (most recent call last):
>>>> File "/home/simon/.local/lib/python2.7/site-packages/paver/tasks.py",
>>>> line 201, in _run_task
>>>> return do_task()
>>>> line 197, in do_task
>>>> task()
>>>> line 333, in __call__
>>>> retval = environment._run_task(self.name, self.needs, self.func)
>>>> line 219, in _run_task
>>>> return do_task()
>>>> line 198, in do_task
>>>> return func(**kw)
>>>> File "pavement.py", line 106, in setup_geoserver
>>>> "geoserver binary")
>>>> File "pavement.py", line 74, in grab
>>>> urllib.urlretrieve(str(src), str(dest))
>>>> File "/usr/lib/python2.7/urllib.py", line 98, in urlretrieve
>>>> return opener.retrieve(url, filename, reporthook, data)
>>>> File "/usr/lib/python2.7/urllib.py", line 245, in retrieve
>>>> fp = self.open(url, data)
>>>> File "/usr/lib/python2.7/urllib.py", line 213, in open
>>>> return getattr(self, name)(url)
>>>> File "/usr/lib/python2.7/urllib.py", line 350, in open_http
>>>> h.endheaders(data)
>>>> File "/usr/lib/python2.7/httplib.py", line 1038, in endheaders
>>>> self._send_output(message_body)
>>>> File "/usr/lib/python2.7/httplib.py", line 882, in _send_output
>>>> self.send(msg)
>>>> File "/usr/lib/python2.7/httplib.py", line 844, in send
>>>> self.connect()
>>>> File "/usr/lib/python2.7/httplib.py", line 821, in connect
>>>> self.timeout, self.source_address)
>>>> File "/usr/lib/python2.7/socket.py", line 575, in create_connection
>>>> raise err
>>>> IOError: [Errno socket error] [Errno 110] Connection timed out
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> "Este mensaje y sus anexos van dirigidos exclusivamente a la persona o
>> entidad que se muestra como destinatario/s y pueden contener datos
>> personales y/o información confidencial, sometida a secreto profesional o
>> cuya divulgación esté prohibida en la legislación vigente. Que
>> <http://www.ctic.uni.edu.pe/>da prohibida, toda divulgación,
>> reproducción u otra acción al respecto por parte de personas o entidades
>> distintas al destinatario/s. Si ha recibido este mensaje por error, por
>> favor, contáctenos a la siguiente dirección de correo electrónico
>> lpdp at uni.edu.pe y proceda a su eliminación.
>> En cumplimiento a lo establecido en la Ley de Protección de Datos
>> Personales - Ley N° 29733, le informamos que sus datos personales obtenidos
>> son almacenados bajo la confidencialidad y las medidas de seguridad
>> legalmente establecidas y no serán cedidos ni compartidos con empresas ni
>> entidades ajenas a la Universidad Nacional de Ingeniería. Si lo desea,
>> usted podrá ejercitar los derechos de actualización,
>> inclusión, rectificación, supresión u oposición, enviando un mensaje al
>> correo electrónico anteriormente señalado e indicando en el "Asunto" el
>> derecho que desea ejercer"
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181012/a4aabd33/attachment-0001.html>
More information about the geonode-users
