[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Fri Oct 12 15:23:05 PDT 2018
And also getting an error (Error updating permissions) when trying to add
groups to layer permissions; although the permission change is still
successful.
On Fri, Oct 12, 2018 at 6:02 PM Michael Fedak <mikefedak at gmail.com> wrote:
> Also happens when I try sync_geofence:
> ('Unexpected error:', <type 'exceptions.RuntimeError'>)
> perm_spec is {u'users': {u'AnonymousUser': [u'view_resourcebase',
> u'download_resourcebase'], u'lprca': [u'view_resourcebase',
> u'download_resourcebase', u'change_resourcebase_metadata',
> u'change_resourcebase', u'delete_resourcebase',
> u'change_resourcebase_permissions', u'publish_resourcebase',
> u'change_layer_data', u'change_layer_style']}, u'groups': {u'anonymous':
> [u'view_resourcebase', u'download_resourcebase']}}
> Interestingly enough; fix_geofence_rules fails for all of the layers where
> sync_geofence works.
> On Fri, Oct 12, 2018 at 3:12 PM Paolo Corti <pcorti at gmail.com> wrote:
>> I am getting exactly the same error, using master and GeoServer
>> 2.13-SNAPSHOT
>> In the stack I also see "Could not retrieve GeoFence Rules count."
>> best
>> Paolo
>> On Fri, Oct 12, 2018 at 1:11 PM Michael Fedak <mikefedak at gmail.com>
>> wrote:
>> > I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>> receiving the following error when attempting to run the updatelayers
>> command (Below).
>> > I am also having trouble with users not being sync'd with geoserver. I
>> have gone through the documentation for security configuration, and checked
>> that the geonode role/user apis are accessible to geoserver. As far as I
>> can tell, nothing is blocking either geonode from reaching geofence or
>> vice-versa.
>> > Traceback (most recent call last):
>> > File "manage.py", line 29, in <module>
>> > execute_from_command_line(sys.argv)
>> > File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>> > utility.execute()
>> > File
>> line 346, in execute
>> > self.fetch_command(subcommand).run_from_argv(self.argv)
>> > File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>> > self.execute(*args, **cmd_options)
>> > File
>> line 445, in execute
>> > output = self.handle(*args, **options)
>> > File
>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>> line 124, in handle
>> > execute_signals=True)
>> > File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>> line 636, in gs_slurp
>> > layer.set_permissions(perm_spec)
>> > File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>> line 216, in set_permissions
>> > sync_geofence_with_guardian(self.layer, perms, group=group)
>> > File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line
>> 44, in wrapper
>> > return func(*args, **kwargs)
>> > File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py",
>> line 393, in sync_geofence_with_guardian
>> > _update_geofence_rule(layer.name, layer.workspace, service)
>> line 564, in _update_geofence_rule
>> > raise RuntimeError(msg)
>> > Exception: ('Failed to process lprca_ws_boundarywgs84',
>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>> u'lprca_ws_boundarywgs84'",))
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181012/2f16a2e7/attachment-0001.html>
More information about the geonode-users
