[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Fri Oct 12 15:28:33 PDT 2018
And finally, document uploads throws an error but the upload is still
successful.
On Fri, Oct 12, 2018 at 6:23 PM Michael Fedak <mikefedak at gmail.com> wrote:
> And also getting an error (Error updating permissions) when trying to add
> groups to layer permissions; although the permission change is still
> successful.
> On Fri, Oct 12, 2018 at 6:02 PM Michael Fedak <mikefedak at gmail.com> wrote:
>> Also happens when I try sync_geofence:
>> ('Unexpected error:', <type 'exceptions.RuntimeError'>)
>> perm_spec is {u'users': {u'AnonymousUser': [u'view_resourcebase',
>> u'download_resourcebase'], u'lprca': [u'view_resourcebase',
>> u'download_resourcebase', u'change_resourcebase_metadata',
>> u'change_resourcebase', u'delete_resourcebase',
>> u'change_resourcebase_permissions', u'publish_resourcebase',
>> u'change_layer_data', u'change_layer_style']}, u'groups': {u'anonymous':
>> [u'view_resourcebase', u'download_resourcebase']}}
>> Interestingly enough; fix_geofence_rules fails for all of the layers
>> where sync_geofence works.
>> On Fri, Oct 12, 2018 at 3:12 PM Paolo Corti <pcorti at gmail.com> wrote:
>>> I am getting exactly the same error, using master and GeoServer
>>> 2.13-SNAPSHOT
>>> In the stack I also see "Could not retrieve GeoFence Rules count."
>>> best
>>> Paolo
>>> On Fri, Oct 12, 2018 at 1:11 PM Michael Fedak <mikefedak at gmail.com>
>>> wrote:
>>> > I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>>> receiving the following error when attempting to run the updatelayers
>>> command (Below).
>>> > I am also having trouble with users not being sync'd with geoserver. I
>>> have gone through the documentation for security configuration, and checked
>>> that the geonode role/user apis are accessible to geoserver. As far as I
>>> can tell, nothing is blocking either geonode from reaching geofence or
>>> vice-versa.
>>> > Traceback (most recent call last):
>>> > File "manage.py", line 29, in <module>
>>> > execute_from_command_line(sys.argv)
>>> > File
>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 354, in execute_from_command_line
>>> > utility.execute()
>>> > File
>>> line 346, in execute
>>> > self.fetch_command(subcommand).run_from_argv(self.argv)
>>> > File
>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 394, in run_from_argv
>>> > self.execute(*args, **cmd_options)
>>> > File
>>> line 445, in execute
>>> > output = self.handle(*args, **options)
>>> > File
>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>> line 124, in handle
>>> > execute_signals=True)
>>> > File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>>> line 636, in gs_slurp
>>> > layer.set_permissions(perm_spec)
>>> > File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>>> line 216, in set_permissions
>>> > sync_geofence_with_guardian(self.layer, perms, group=group)
>>> > File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line
>>> 44, in wrapper
>>> > return func(*args, **kwargs)
>>> > File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py",
>>> line 393, in sync_geofence_with_guardian
>>> > _update_geofence_rule(layer.name, layer.workspace, service)
>>> line 564, in _update_geofence_rule
>>> > raise RuntimeError(msg)
>>> > Exception: ('Failed to process lprca_ws_boundarywgs84',
>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>> u'lprca_ws_boundarywgs84'",))
>>> > _______________________________________________
>>> > geonode-users mailing list
>>> > geonode-users at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Paolo Corti
>>> Geospatial software developer
>>> web: http://www.paolocorti.net
>>> twitter: @capooti
>>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181012/e4b7069f/attachment.html>
More information about the geonode-users
