[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Alessio Fabiani alessio.fabiani at gmail.com
Fri Oct 12 16:40:28 PDT 2018
Which version of GeoNode you installed and how? Master (aka 2.10) works
only with geoserver 2.14+
2.8.x and below DO NOT WORK with geoserver 2.14+ but only with 2.13 and
below.
Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha scritto:
> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
> receiving the following error when attempting to run the updatelayers
> command (Below).
> I am also having trouble with users not being sync'd with geoserver. I
> have gone through the documentation for security configuration, and checked
> that the geonode role/user apis are accessible to geoserver. As far as I
> can tell, nothing is blocking either geonode from reaching geofence or
> vice-versa.
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
>   File
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
>   File
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
> line 124, in handle
>     execute_signals=True)
>   File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
> line 636, in gs_slurp
>     layer.set_permissions(perm_spec)
>   File "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line
> 216, in set_permissions
>     sync_geofence_with_guardian(self.layer, perms, group=group)
>   File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44,
> in wrapper
>     return func(*args, **kwargs)
>   File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line
> 393, in sync_geofence_with_guardian
>     _update_geofence_rule(layer.name, layer.workspace, service)
> 564, in _update_geofence_rule
>     raise RuntimeError(msg)
> Exception: ('Failed to process lprca_ws_boundarywgs84',
> RuntimeError("Could not ADD GeoServer User None Rule for Layer
> u'lprca_ws_boundarywgs84'",))
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181013/af8309dd/attachment.html>
More information about the geonode-users mailing list
