[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak mikefedak at gmail.com
Fri Oct 12 16:49:15 PDT 2018
Using geonode 2.8.x off the 2.8.x branch current to today. Geoserver is
2.12.2. installed on Ubuntu 16.04 in a virtualenv.
On Fri, Oct 12, 2018, 7:40 PM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Which version of GeoNode you installed and how? Master (aka 2.10) works
> only with geoserver 2.14+
> 2.8.x and below DO NOT WORK with geoserver 2.14+ but only with 2.13 and
> below.
> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha scritto:
>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>> receiving the following error when attempting to run the updatelayers
>> command (Below).
>> I am also having trouble with users not being sync'd with geoserver. I
>> have gone through the documentation for security configuration, and checked
>> that the geonode role/user apis are accessible to geoserver. As far as I
>> can tell, nothing is blocking either geonode from reaching geofence or
>> vice-versa.
>> Traceback (most recent call last):
>>   File "manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 346, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>>     self.execute(*args, **cmd_options)
>>   File
>> line 445, in execute
>>     output = self.handle(*args, **options)
>>   File
>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>> line 124, in handle
>>     execute_signals=True)
>>   File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>> line 636, in gs_slurp
>>     layer.set_permissions(perm_spec)
>>   File "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line
>> 216, in set_permissions
>>     sync_geofence_with_guardian(self.layer, perms, group=group)
>>   File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44,
>> in wrapper
>>     return func(*args, **kwargs)
>>   File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line
>> 393, in sync_geofence_with_guardian
>>     _update_geofence_rule(layer.name, layer.workspace, service)
>> 564, in _update_geofence_rule
>>     raise RuntimeError(msg)
>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>> u'lprca_ws_boundarywgs84'",))
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181012/84faa501/attachment-0001.html>
More information about the geonode-users mailing list
