[GeoNode-users] Ris: Change Geonode admin password on Docker installation
Matteo Conte matteo.conte at abitat.it
Sat Oct 13 14:39:56 PDT 2018
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181013/8b535aac/attachment-0001.html>
Hi Francesco,
Monday I will try.
Thanks
Matteo
Inviato dal mio dispositivo Huawei
-------- Messaggio originale --------
Oggetto: Re: [GeoNode-users] Change Geonode admin password on Docker installation
Da: Francesco Bartoli
A: Alessio Fabiani ,Matteo Conte
CC: geonode-users
Hi Matteo,
Can you please try to reproduce the same issue with the plain docker-compose commands?
Thanks,
Francesco
Il 13 ott 2018, 09:24 +0200, Matteo Conte <matteo.conte at abitat.it>, ha scritto:
> Hi Alessio,
>    the guide on https://github.com/GeoNode/geonode-project#start-your-server is similar to this http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/setup_docker_compose.html#running-geonode-stack-on-localhost. I use portainer.io interface to manage docker and to start/stop container or stack. Another couple of very strange things:
> • If I change the admin password this will be reset after restart geonode stack;
> • If I edit topics category these will be reset after restart geonode stack;
> • BUT If I add layers/maps/users these remain after restart geonode stack.
> Why some settings remain and others do not?
> Kind Regards
> Matteo
> Da: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> A: "matteo.conte" <matteo.conte at abitat.it>
> Cc: "geonode-users" <geonode-users at lists.osgeo.org>
> Inviato: Venerdì, 12 ottobre 2018 12:39:14
> P.S.: for this specific issue, be sure you DO NOT build the image every time
> > Il giorno ven 12 ott 2018 alle ore 12:04 Matteo Conte <matteo.conte at abitat.it> ha scritto:
> > > Hi All,
> > >   I've installed Geonode (2.10_rc4) on docker following this guide http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html.
> > > When I change Geonode admin password and restarted the docker containers the password return to be the default.
> > > Kind regards
> > > Matteo
> > > _______________________________________________
> > > geonode-users mailing list
> > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
More information about the geonode-users mailing list
