[GeoNode-users] Change Geonode admin password on Docker installation
Matteo Conte
matteo.conte at abitat.it
Sun Oct 14 23:56:17 PDT 2018
Hi Francesco,
I tried with docker-compose commands. I stopped all geonode containers with docker-compose stop commands and then I start the containers with docker-compose start but I get the same result.
Kind regards
Matteo
Da: "Francesco Bartoli" <xbartolone at gmail.com>
A: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>, "matteo.conte" <matteo.conte at abitat.it>
Cc: "geonode-users" <geonode-users at lists.osgeo.org>
Inviato: Sabato, 13 ottobre 2018 18:34:17
Oggetto: Re: [GeoNode-users] Change Geonode admin password on Docker installation
Hi Matteo,
Can you please try to reproduce the same issue with the plain docker-compose commands?
Thanks,
Francesco
Il 13 ott 2018, 09:24 +0200, Matteo Conte <matteo.conte at abitat.it>, ha scritto:
Hi Alessio,
the guide on https://github.com/GeoNode/geonode-project#start-your-server is similar to this http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/setup_docker_compose.html#running-geonode-stack-on-localhost. I use portainer.io interface to manage docker and to start/stop container or stack. Another couple of very strange things:
* If I change the admin password this will be reset after restart geonode stack ;
* If I edit topics category these will be reset after restart geonode stack ;
* BUT If I add layers/maps/users these remain after restart geonode stack.
Why some settings remain and others do not?
Kind Regards
Matteo
Da: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
A: "matteo.conte" <matteo.conte at abitat.it>
Inviato: Venerdì, 12 ottobre 2018 12:39:14
P.S.: for this specific issue, be sure you DO NOT build the image every time
Il giorno ven 12 ott 2018 alle ore 12:04 Matteo Conte < [ mailto:matteo.conte at abitat.it | matteo.conte at abitat.it ] > ha scritto:
BQ_BEGIN
Hi All,
I've installed Geonode (2.10_rc4) on docker following this guide [ http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html | http://docs.geonode.org/en/master/tutorials/install_and_admin/running_docker/index.html ] .
When I change Geonode admin password and restarted the docker containers the password return to be the default.
Kind regards
Matteo
geonode-users mailing list
[ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ]
[ https://lists.osgeo.org/mailman/listinfo/geonode-users | https://lists.osgeo.org/mailman/listinfo/geonode-users ]
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: [ tel:+39%200584%20962313 | +39 0584 962313 ]
fax: [ tel:+39%200584%201660272 | +39 0584 1660272 ]
mob: [ tel:+39%20331%206233686 | +39 331 6233686 ]
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
BQ_END
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181015/d197387a/attachment-0001.html>
More information about the geonode-users
