[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Sun Oct 14 07:00:17 PDT 2018
Ok, I can do that. Is there a place to download the build with the
extension since build.geonode.org is down? Or shall I just download vanilla
2.13 and apply the extension myself?
On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's a fix
> to threat void users as * users.
> Any chance to try out updating to Geoserver 2.13.x?
> You won't have to change anything on the data dir.
> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha scritto:
>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>> receiving the following error when attempting to run the updatelayers
>> command (Below).
>> I am also having trouble with users not being sync'd with geoserver. I
>> have gone through the documentation for security configuration, and checked
>> that the geonode role/user apis are accessible to geoserver. As far as I
>> can tell, nothing is blocking either geonode from reaching geofence or
>> vice-versa.
>> Traceback (most recent call last):
>> File "manage.py", line 29, in <module>
>> execute_from_command_line(sys.argv)
>> File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> line 354, in execute_from_command_line
>> utility.execute()
>> File
>> line 346, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File
>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>> line 394, in run_from_argv
>> self.execute(*args, **cmd_options)
>> File
>> line 445, in execute
>> output = self.handle(*args, **options)
>> File
>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>> line 124, in handle
>> execute_signals=True)
>> File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>> line 636, in gs_slurp
>> layer.set_permissions(perm_spec)
>> File "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line
>> 216, in set_permissions
>> sync_geofence_with_guardian(self.layer, perms, group=group)
>> File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44,
>> in wrapper
>> return func(*args, **kwargs)
>> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line
>> 393, in sync_geofence_with_guardian
>> _update_geofence_rule(layer.name, layer.workspace, service)
>> 564, in _update_geofence_rule
>> raise RuntimeError(msg)
>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>> u'lprca_ws_boundarywgs84'",))
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181014/83bb18fe/attachment.html>
More information about the geonode-users
