[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Sun Oct 14 07:02:41 PDT 2018
Never mind, found your build server:
https://build.geo-solutions.it/geonode/geoserver/latest/
On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com> wrote:
> Ok, I can do that. Is there a place to download the build with the
> extension since build.geonode.org is down? Or shall I just download
> vanilla 2.13 and apply the extension myself?
> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <alessio.fabiani at gmail.com>
> wrote:
>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's a fix
>> to threat void users as * users.
>> Any chance to try out updating to Geoserver 2.13.x?
>> You won't have to change anything on the data dir.
>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha scritto:
>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>>> receiving the following error when attempting to run the updatelayers
>>> command (Below).
>>> I am also having trouble with users not being sync'd with geoserver. I
>>> have gone through the documentation for security configuration, and checked
>>> that the geonode role/user apis are accessible to geoserver. As far as I
>>> can tell, nothing is blocking either geonode from reaching geofence or
>>> vice-versa.
>>> Traceback (most recent call last):
>>> File "manage.py", line 29, in <module>
>>> execute_from_command_line(sys.argv)
>>> File
>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>> line 354, in execute_from_command_line
>>> utility.execute()
>>> File
>>> line 346, in execute
>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>> File
>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>> line 394, in run_from_argv
>>> self.execute(*args, **cmd_options)
>>> File
>>> line 445, in execute
>>> output = self.handle(*args, **options)
>>> File
>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>> line 124, in handle
>>> execute_signals=True)
>>> File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>>> line 636, in gs_slurp
>>> layer.set_permissions(perm_spec)
>>> File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>>> line 216, in set_permissions
>>> sync_geofence_with_guardian(self.layer, perms, group=group)
>>> File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44,
>>> in wrapper
>>> return func(*args, **kwargs)
>>> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line
>>> 393, in sync_geofence_with_guardian
>>> _update_geofence_rule(layer.name, layer.workspace, service)
>>> 564, in _update_geofence_rule
>>> raise RuntimeError(msg)
>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>> u'lprca_ws_boundarywgs84'",))
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181014/e88c1b7b/attachment-0001.html>
More information about the geonode-users
