[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak mikefedak at gmail.com
Sun Oct 14 11:10:11 PDT 2018
Traced it back some more, it seems to be an issue with GWC:
Cannot resolve reference to bean 'gwcXmlConfigResourceProvider' while
setting constructor argument; nested exception is
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'gwcXmlConfigResourceProvider' defined in URL
[jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
Bean instantiation via constructor failed; nested exception is
org.springframework.beans.BeanInstantiationException: Failed to instantiate
[org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
exception; nested exception is java.lang.IllegalStateException: Could not
create directory.
On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <mikefedak at gmail.com> wrote:
> Ok, got the war and attempted to deploy it. Tomcat is unable to deploy it
> due to an error associated with geotools:
> Geoserver log:
> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
> AbstractEpsgMediator.
> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection cleaner
> stopped
> Catalina log:
> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
> The web application [geoserver-2.13.x] created a ThreadLocal with key of
> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710]) and
> a value of type
> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
> the web application was stopped. Threads are going to be renewed over time
> to try and avoid a probable memory leak.
> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d]) and
> a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
> failed to remove it when the web application was stopped. Threads are going
> to be renewed over time to try and avoid a probable memory leak.
> I will keep trying to troubleshoot this.
> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <mikefedak at gmail.com>
> wrote:
>> Never mind, found your build server:
>> https://build.geo-solutions.it/geonode/geoserver/latest/
>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com>
>> wrote:
>>> Ok, I can do that. Is there a place to download the build with the
>>> extension since build.geonode.org is down? Or shall I just download
>>> vanilla 2.13 and apply the extension myself?
>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>> alessio.fabiani at gmail.com> wrote:
>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's a
>>>> fix to threat void users as * users.
>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>> You won't have to change anything on the data dir.
>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha
>>>> scritto:
>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>>>>> receiving the following error when attempting to run the updatelayers
>>>>> command (Below).
>>>>> I am also having trouble with users not being sync'd with geoserver. I
>>>>> have gone through the documentation for security configuration, and checked
>>>>> that the geonode role/user apis are accessible to geoserver. As far as I
>>>>> can tell, nothing is blocking either geonode from reaching geofence or
>>>>> vice-versa.
>>>>> Traceback (most recent call last):
>>>>>   File "manage.py", line 29, in <module>
>>>>>     execute_from_command_line(sys.argv)
>>>>>   File
>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 354, in execute_from_command_line
>>>>>     utility.execute()
>>>>>   File
>>>>> line 346, in execute
>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>   File
>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>> line 394, in run_from_argv
>>>>>     self.execute(*args, **cmd_options)
>>>>>   File
>>>>> line 445, in execute
>>>>>     output = self.handle(*args, **options)
>>>>>   File
>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>> line 124, in handle
>>>>>     execute_signals=True)
>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py",
>>>>> line 636, in gs_slurp
>>>>>     layer.set_permissions(perm_spec)
>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>>>>> line 216, in set_permissions
>>>>>     sync_geofence_with_guardian(self.layer, perms, group=group)
>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line
>>>>> 44, in wrapper
>>>>>     return func(*args, **kwargs)
>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py",
>>>>> line 393, in sync_geofence_with_guardian
>>>>>     _update_geofence_rule(layer.name, layer.workspace, service)
>>>>> line 564, in _update_geofence_rule
>>>>>     raise RuntimeError(msg)
>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>> u'lprca_ws_boundarywgs84'",))
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181014/fddc68ac/attachment-0001.html>
More information about the geonode-users mailing list
