[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Sun Oct 14 12:03:10 PDT 2018
Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver starts.
However, I am experiencing the same issues as before.
On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <mikefedak at gmail.com> wrote:
> Traced it back some more, it seems to be an issue with GWC:
> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider' while
> setting constructor argument; nested exception is
> org.springframework.beans.factory.BeanCreationException: Error creating
> bean with name 'gwcXmlConfigResourceProvider' defined in URL
> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
> Bean instantiation via constructor failed; nested exception is
> org.springframework.beans.BeanInstantiationException: Failed to instantiate
> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
> exception; nested exception is java.lang.IllegalStateException: Could not
> create directory.
> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <mikefedak at gmail.com> wrote:
>> Ok, got the war and attempted to deploy it. Tomcat is unable to deploy it
>> due to an error associated with geotools:
>> Geoserver log:
>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>> AbstractEpsgMediator.
>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection cleaner
>> stopped
>> Catalina log:
>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>> and a value of type
>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>> the web application was stopped. Threads are going to be renewed over time
>> to try and avoid a probable memory leak.
>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d]) and
>> a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>> failed to remove it when the web application was stopped. Threads are going
>> to be renewed over time to try and avoid a probable memory leak.
>> I will keep trying to troubleshoot this.
>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <mikefedak at gmail.com>
>> wrote:
>>> Never mind, found your build server:
>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com>
>>> wrote:
>>>> Ok, I can do that. Is there a place to download the build with the
>>>> extension since build.geonode.org is down? Or shall I just download
>>>> vanilla 2.13 and apply the extension myself?
>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>> alessio.fabiani at gmail.com> wrote:
>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's a
>>>>> fix to threat void users as * users.
>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>> You won't have to change anything on the data dir.
>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha
>>>>> scritto:
>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>>>>>> receiving the following error when attempting to run the updatelayers
>>>>>> command (Below).
>>>>>> I am also having trouble with users not being sync'd with geoserver.
>>>>>> I have gone through the documentation for security configuration, and
>>>>>> checked that the geonode role/user apis are accessible to geoserver. As far
>>>>>> as I can tell, nothing is blocking either geonode from reaching geofence or
>>>>>> vice-versa.
>>>>>> Traceback (most recent call last):
>>>>>> File "manage.py", line 29, in <module>
>>>>>> execute_from_command_line(sys.argv)
>>>>>> File
>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>> line 354, in execute_from_command_line
>>>>>> utility.execute()
>>>>>> File
>>>>>> line 346, in execute
>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>> File
>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>> line 394, in run_from_argv
>>>>>> self.execute(*args, **cmd_options)
>>>>>> File
>>>>>> line 445, in execute
>>>>>> output = self.handle(*args, **options)
>>>>>> File
>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>> line 124, in handle
>>>>>> execute_signals=True)
>>>>>> File
>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>> in gs_slurp
>>>>>> layer.set_permissions(perm_spec)
>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>>>>>> line 216, in set_permissions
>>>>>> sync_geofence_with_guardian(self.layer, perms, group=group)
>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line
>>>>>> 44, in wrapper
>>>>>> return func(*args, **kwargs)
>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py",
>>>>>> line 393, in sync_geofence_with_guardian
>>>>>> _update_geofence_rule(layer.name, layer.workspace, service)
>>>>>> line 564, in _update_geofence_rule
>>>>>> raise RuntimeError(msg)
>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181014/7138ab03/attachment.html>
More information about the geonode-users
