[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Alessio Fabiani
alessio.fabiani at gmail.com
Sun Oct 14 12:08:14 PDT 2018
Uhm very strange. Tomorrow will do some specific tests on this. Currently I
cannot figure out what the problem could be.
Il dom 14 ott 2018, 21:03 Michael Fedak <mikefedak at gmail.com> ha scritto:
> Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver starts.
> However, I am experiencing the same issues as before.
> On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <mikefedak at gmail.com> wrote:
>> Traced it back some more, it seems to be an issue with GWC:
>> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider' while
>> setting constructor argument; nested exception is
>> org.springframework.beans.factory.BeanCreationException: Error creating
>> bean with name 'gwcXmlConfigResourceProvider' defined in URL
>> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
>> Bean instantiation via constructor failed; nested exception is
>> org.springframework.beans.BeanInstantiationException: Failed to instantiate
>> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
>> exception; nested exception is java.lang.IllegalStateException: Could not
>> create directory.
>> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <mikefedak at gmail.com>
>> wrote:
>>> Ok, got the war and attempted to deploy it. Tomcat is unable to deploy
>>> it due to an error associated with geotools:
>>> Geoserver log:
>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>>> AbstractEpsgMediator.
>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection cleaner
>>> stopped
>>> Catalina log:
>>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>>> and a value of type
>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>> the web application was stopped. Threads are going to be renewed over time
>>> to try and avoid a probable memory leak.
>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d])
>>> and a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>>> failed to remove it when the web application was stopped. Threads are going
>>> to be renewed over time to try and avoid a probable memory leak.
>>> I will keep trying to troubleshoot this.
>>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <mikefedak at gmail.com>
>>> wrote:
>>>> Never mind, found your build server:
>>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com>
>>>> wrote:
>>>>> Ok, I can do that. Is there a place to download the build with the
>>>>> extension since build.geonode.org is down? Or shall I just download
>>>>> vanilla 2.13 and apply the extension myself?
>>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>>> alessio.fabiani at gmail.com> wrote:
>>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's a
>>>>>> fix to threat void users as * users.
>>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>>> You won't have to change anything on the data dir.
>>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha
>>>>>> scritto:
>>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep
>>>>>>> receiving the following error when attempting to run the updatelayers
>>>>>>> command (Below).
>>>>>>> I am also having trouble with users not being sync'd with geoserver.
>>>>>>> I have gone through the documentation for security configuration, and
>>>>>>> checked that the geonode role/user apis are accessible to geoserver. As far
>>>>>>> as I can tell, nothing is blocking either geonode from reaching geofence or
>>>>>>> vice-versa.
>>>>>>> Traceback (most recent call last):
>>>>>>> File "manage.py", line 29, in <module>
>>>>>>> execute_from_command_line(sys.argv)
>>>>>>> File
>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>> line 354, in execute_from_command_line
>>>>>>> utility.execute()
>>>>>>> File
>>>>>>> line 346, in execute
>>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>> File
>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>> line 394, in run_from_argv
>>>>>>> self.execute(*args, **cmd_options)
>>>>>>> File
>>>>>>> line 445, in execute
>>>>>>> output = self.handle(*args, **options)
>>>>>>> File
>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>> line 124, in handle
>>>>>>> execute_signals=True)
>>>>>>> File
>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>>> in gs_slurp
>>>>>>> layer.set_permissions(perm_spec)
>>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/security/models.py",
>>>>>>> line 216, in set_permissions
>>>>>>> sync_geofence_with_guardian(self.layer, perms, group=group)
>>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line
>>>>>>> 44, in wrapper
>>>>>>> return func(*args, **kwargs)
>>>>>>> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py",
>>>>>>> line 393, in sync_geofence_with_guardian
>>>>>>> _update_geofence_rule(layer.name, layer.workspace, service)
>>>>>>> line 564, in _update_geofence_rule
>>>>>>> raise RuntimeError(msg)
>>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181014/072eca7f/attachment-0001.html>
More information about the geonode-users
