[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Alessio Fabiani
alessio.fabiani at gmail.com
Mon Oct 15 08:25:12 PDT 2018
It tries, but the mechanism now is completely different.
If it is able to find the cookie session, it should be able to
automatically log in with the current GeoNode user. If not you will need to
click the "geonode" icon on GeoServer admin gui, and refresh the OAuth2
session.
This is something that could be improved. Currently is an issue open since
a long time on GeoServer. Unfortunately until now no one has found enough
time/resource to work on it.
Since the OAuth2 mechanism is becoming a requirement for the new OGC
test-bed, hopefully we will find some time to improve it in the next months.
Il giorno lun 15 ott 2018 alle ore 17:18 Michael Fedak <mikefedak at gmail.com>
ha scritto:
> So the default behaviour is no longer to be logged in to geoserver via
> geonode as a superuser?
> On Mon, Oct 15, 2018 at 11:08 AM Alessio Fabiani <
> alessio.fabiani at gmail.com> wrote:
>> Yes, I confirm this is just a warning.
>> Lower down the GeoServer logging level if you don't want to be
>> overwhelmed by all those warnings.
>> Il giorno lun 15 ott 2018 alle ore 17:02 Michael Fedak <
>> mikefedak at gmail.com> ha scritto:
>>> Now the only error I have remaining is around superuser logins for
>>> geoserver.
>>> If I try using the link from geonode, I get the following error. But if
>>> I use the 'authorize' link on the geoserver page the login occurs as
>>> intended. Logout seems to work perfectly after being logged in.
>>> 2018-10-15 14:59:46,763 DEBUG [geoserver.security] - Bad credentials
>>> org.springframework.security.authentication.BadCredentialsException: Bad
>>> credentials
>>> at
>>> org.springframework.security.authentication.dao.DaoAuthenticationProvider.additionalAuthenticationChecks(DaoAuthenticationProvider.java:98)
>>> at
>>> org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:165)
>>> at
>>> org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:78)
>>> at
>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:54)
>>> at
>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
>>> at
>>> org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1440)
>>> at
>>> org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:117)
>>> at
>>> org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:44)
>>> at
>>> org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:133)
>>> at
>>> org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
>>> at
>>> org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
>>> at org.apache.wicket.Component.internalBeforeRender(Component.java:950)
>>> at org.apache.wicket.Component.beforeRender(Component.java:1018)
>>> at
>>> org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1836)
>>> at org.apache.wicket.Component.onBeforeRender(Component.java:3916)
>>> at org.apache.wicket.Page.onBeforeRender(Page.java:801)
>>> at
>>> org.apache.wicket.Component.internalPrepareForRender(Component.java:2236)
>>> at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
>>> at org.apache.wicket.Component.render(Component.java:2325)
>>> at org.apache.wicket.Page.renderPage(Page.java:1018)
>>> at
>>> org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
>>> at
>>> org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
>>> at
>>> org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
>>> at
>>> org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
>>> at
>>> org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
>>> at
>>> org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
>>> at
>>> org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
>>> at
>>> org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
>>> at
>>> org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
>>> at
>>> org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
>>> at
>>> org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
>>> at
>>> org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
>>> at
>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
>>> at
>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
>>> at
>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
>>> at
>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
>>> at
>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
>>> at
>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
>>> at
>>> org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
>>> at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
>>> at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
>>> at
>>> at
>>> org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:414)
>>> at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:169)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
>>> at
>>> org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
>>> at
>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
>>> at
>>> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:83)
>>> at
>>> at
>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
>>> at
>>> at
>>> at
>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
>>> at
>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
>>> at
>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
>>> at
>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>> at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
>>> at
>>> at
>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
>>> at
>>> at
>>> at
>>> at
>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
>>> at
>>> at
>>> at
>>> org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:112)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
>>> at
>>> at
>>> at
>>> at
>>> org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:172)
>>> at
>>> at
>>> at
>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>> at
>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>> at
>>> at
>>> at
>>> at
>>> org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
>>> at
>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
>>> at
>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
>>> at
>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>> at
>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
>>> at
>>> at
>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
>>> at
>>> at
>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
>>> at
>>> at
>>> at
>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
>>> at
>>> at
>>> at
>>> org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
>>> at
>>> org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
>>> at
>>> at
>>> at
>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
>>> at
>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
>>> at
>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:475)
>>> at
>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
>>> at
>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
>>> at
>>> org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:651)
>>> at
>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
>>> at
>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
>>> at
>>> org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:500)
>>> at
>>> org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
>>> at
>>> org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:754)
>>> at
>>> org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1376)
>>> at
>>> org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
>>> at
>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
>>> at
>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
>>> at
>>> org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
>>> at java.lang.Thread.run(Thread.java:748)
>>> 2018-10-15 14:59:46,764 DEBUG [auth.GeoFenceAuthenticationProvider] -
>>> Auth request with
>>> org.springframework.security.authentication.UsernamePasswordAuthenticationToken at 58b33e84:
>>> Principal: admin; Credentials: [PROTECTED]; Authenticated: false; Details:
>>> null; Not granted any authorities
>>> 2018-10-15 14:59:46,764 DEBUG [geofence.cache] - Loading user 'admin'
>>> 2018-10-15 14:59:46,765 WARN [geofence.cache] -
>>> org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth
>>> user [admin]
>>> 2018-10-15 14:59:46,765 DEBUG [auth.GeoFenceAuthenticationProvider] -
>>> Default admin credentials NOT authenticated -- probably a frontend check
>>> On Mon, Oct 15, 2018 at 10:54 AM Michael Fedak <mikefedak at gmail.com>
>>> wrote:
>>>> I confirm that this fixes the management commands.
>>>> On Mon, Oct 15, 2018 at 10:41 AM Alessio Fabiani <
>>>>> This should fix the duplicated rules issue when running the management
>>>>> commands
>>>>> https://github.com/GeoNode/geonode/pull/3988/files
>>>>> Il giorno lun 15 ott 2018 alle ore 16:13 Michael Fedak <
>>>>>> Thank Alessio,
>>>>>> This fixes the problem with documents. However I am still
>>>>>> experiencing the same problems with layers, I have commented on the pull
>>>>>> request. I am also having the same issue with superusers not being
>>>>>> automatically logged into geoserver.
>>>>>> On Mon, Oct 15, 2018 at 4:39 AM Alessio Fabiani <
>>>>>>> Hi Michael,
>>>>>>> thanks very much for helping on test.
>>>>>>> I've finally figured out where the problem was. Fix available here
>>>>>>> https://github.com/GeoNode/geonode/pull/3985
>>>>>>> I'll merge it as soon as the Travis checks pass. I'll also try to
>>>>>>> add some specific test cases for this particular issue.
>>>>>>> Il giorno dom 14 ott 2018 alle ore 21:08 Alessio Fabiani <
>>>>>>> alessio.fabiani at gmail.com> ha scritto:
>>>>>>>> Uhm very strange. Tomorrow will do some specific tests on this.
>>>>>>>> Currently I cannot figure out what the problem could be.
>>>>>>>> Il dom 14 ott 2018, 21:03 Michael Fedak <mikefedak at gmail.com> ha
>>>>>>>> scritto:
>>>>>>>>> Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver
>>>>>>>>> starts. However, I am experiencing the same issues as before.
>>>>>>>>> On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <mikefedak at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Traced it back some more, it seems to be an issue with GWC:
>>>>>>>>>> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider'
>>>>>>>>>> while setting constructor argument; nested exception is
>>>>>>>>>> org.springframework.beans.factory.BeanCreationException: Error creating
>>>>>>>>>> bean with name 'gwcXmlConfigResourceProvider' defined in URL
>>>>>>>>>> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
>>>>>>>>>> Bean instantiation via constructor failed; nested exception is
>>>>>>>>>> org.springframework.beans.BeanInstantiationException: Failed to instantiate
>>>>>>>>>> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
>>>>>>>>>> exception; nested exception is java.lang.IllegalStateException: Could not
>>>>>>>>>> create directory.
>>>>>>>>>> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <
>>>>>>>>>> mikefedak at gmail.com> wrote:
>>>>>>>>>>> Ok, got the war and attempted to deploy it. Tomcat is unable to
>>>>>>>>>>> deploy it due to an error associated with geotools:
>>>>>>>>>>> Geoserver log:
>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>>>>>>>>>>> AbstractEpsgMediator.
>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>>>>>>>>>>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection
>>>>>>>>>>> cleaner stopped
>>>>>>>>>>> Catalina log:
>>>>>>>>>>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>>>>>>>>>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>>>>>>>>>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>>>>>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>>>>>>>>>>> and a value of type
>>>>>>>>>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>>>>>>>>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>>>>>>>>>> the web application was stopped. Threads are going to be renewed over time
>>>>>>>>>>> to try and avoid a probable memory leak.
>>>>>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d])
>>>>>>>>>>> and a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>>>>>>>>>>> failed to remove it when the web application was stopped. Threads are going
>>>>>>>>>>> to be renewed over time to try and avoid a probable memory leak.
>>>>>>>>>>> I will keep trying to troubleshoot this.
>>>>>>>>>>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <
>>>>>>>>>>>> Never mind, found your build server:
>>>>>>>>>>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>>>>>>>>>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <
>>>>>>>>>>>>> Ok, I can do that. Is there a place to download the build with
>>>>>>>>>>>>> the extension since build.geonode.org is down? Or shall I
>>>>>>>>>>>>> just download vanilla 2.13 and apply the extension myself?
>>>>>>>>>>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>>>>>>>>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+
>>>>>>>>>>>>>> there's a fix to threat void users as * users.
>>>>>>>>>>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>>>>>>>>>>> You won't have to change anything on the data dir.
>>>>>>>>>>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com>
>>>>>>>>>>>>>> ha scritto:
>>>>>>>>>>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and
>>>>>>>>>>>>>>> I keep receiving the following error when attempting to run the
>>>>>>>>>>>>>>> updatelayers command (Below).
>>>>>>>>>>>>>>> I am also having trouble with users not being sync'd with
>>>>>>>>>>>>>>> geoserver. I have gone through the documentation for security
>>>>>>>>>>>>>>> configuration, and checked that the geonode role/user apis are accessible
>>>>>>>>>>>>>>> to geoserver. As far as I can tell, nothing is blocking either geonode from
>>>>>>>>>>>>>>> reaching geofence or vice-versa.
>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>> File "manage.py", line 29, in <module>
>>>>>>>>>>>>>>> execute_from_command_line(sys.argv)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>>>>>>>>>> line 354, in execute_from_command_line
>>>>>>>>>>>>>>> utility.execute()
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> line 346, in execute
>>>>>>>>>>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>>>>>>>>>> line 394, in run_from_argv
>>>>>>>>>>>>>>> self.execute(*args, **cmd_options)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> line 445, in execute
>>>>>>>>>>>>>>> output = self.handle(*args, **options)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>>>>>>>>>> line 124, in handle
>>>>>>>>>>>>>>> execute_signals=True)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>>>>>>>>>>> in gs_slurp
>>>>>>>>>>>>>>> layer.set_permissions(perm_spec)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line 216, in
>>>>>>>>>>>>>>> set_permissions
>>>>>>>>>>>>>>> sync_geofence_with_guardian(self.layer, perms,
>>>>>>>>>>>>>>> group=group)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44, in wrapper
>>>>>>>>>>>>>>> return func(*args, **kwargs)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 393, in
>>>>>>>>>>>>>>> _update_geofence_rule(layer.name, layer.workspace,
>>>>>>>>>>>>>>> service)
>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 564, in
>>>>>>>>>>>>>>> raise RuntimeError(msg)
>>>>>>>>>>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>>>>>>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>>>>>>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181015/fa4fa2a9/attachment-0001.html>
More information about the geonode-users
