[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak
mikefedak at gmail.com
Mon Oct 15 08:26:54 PDT 2018
Ok, great. Thank you!
On Mon, Oct 15, 2018 at 11:25 AM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> It tries, but the mechanism now is completely different.
> If it is able to find the cookie session, it should be able to
> automatically log in with the current GeoNode user. If not you will need to
> click the "geonode" icon on GeoServer admin gui, and refresh the OAuth2
> session.
> This is something that could be improved. Currently is an issue open since
> a long time on GeoServer. Unfortunately until now no one has found enough
> time/resource to work on it.
> Since the OAuth2 mechanism is becoming a requirement for the new OGC
> test-bed, hopefully we will find some time to improve it in the next months.
> Il giorno lun 15 ott 2018 alle ore 17:18 Michael Fedak <
> mikefedak at gmail.com> ha scritto:
>> So the default behaviour is no longer to be logged in to geoserver via
>> geonode as a superuser?
>> On Mon, Oct 15, 2018 at 11:08 AM Alessio Fabiani <
>> alessio.fabiani at gmail.com> wrote:
>>> Yes, I confirm this is just a warning.
>>> Lower down the GeoServer logging level if you don't want to be
>>> overwhelmed by all those warnings.
>>> Il giorno lun 15 ott 2018 alle ore 17:02 Michael Fedak <
>>>> Now the only error I have remaining is around superuser logins for
>>>> geoserver.
>>>> If I try using the link from geonode, I get the following error. But if
>>>> I use the 'authorize' link on the geoserver page the login occurs as
>>>> intended. Logout seems to work perfectly after being logged in.
>>>> 2018-10-15 14:59:46,763 DEBUG [geoserver.security] - Bad credentials
>>>> org.springframework.security.authentication.BadCredentialsException:
>>>> Bad credentials
>>>> at
>>>> org.springframework.security.authentication.dao.DaoAuthenticationProvider.additionalAuthenticationChecks(DaoAuthenticationProvider.java:98)
>>>> at
>>>> org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:165)
>>>> at
>>>> org.geoserver.security.auth.UsernamePasswordAuthenticationProvider.authenticate(UsernamePasswordAuthenticationProvider.java:78)
>>>> at
>>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:54)
>>>> at
>>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
>>>> at
>>>> org.geoserver.security.GeoServerSecurityManager.checkForDefaultAdminPassword(GeoServerSecurityManager.java:1440)
>>>> at
>>>> org.geoserver.security.web.SecurityHomePageContentProvider$SecurityWarningsPanel.<init>(SecurityHomePageContentProvider.java:117)
>>>> at
>>>> org.geoserver.security.web.SecurityHomePageContentProvider.getPageBodyComponent(SecurityHomePageContentProvider.java:44)
>>>> at
>>>> org.geoserver.web.GeoServerHomePage$1.populateItem(GeoServerHomePage.java:133)
>>>> at
>>>> org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:523)
>>>> at
>>>> org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
>>>> at org.apache.wicket.Component.internalBeforeRender(Component.java:950)
>>>> at org.apache.wicket.Component.beforeRender(Component.java:1018)
>>>> at
>>>> org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1836)
>>>> at org.apache.wicket.Component.onBeforeRender(Component.java:3916)
>>>> at org.apache.wicket.Page.onBeforeRender(Page.java:801)
>>>> at
>>>> org.apache.wicket.Component.internalPrepareForRender(Component.java:2236)
>>>> at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
>>>> at org.apache.wicket.Component.render(Component.java:2325)
>>>> at org.apache.wicket.Page.renderPage(Page.java:1018)
>>>> at
>>>> org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
>>>> at
>>>> org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
>>>> at
>>>> org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
>>>> at
>>>> org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
>>>> at
>>>> org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
>>>> at
>>>> org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
>>>> at
>>>> org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
>>>> at
>>>> org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
>>>> at
>>>> org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
>>>> at
>>>> org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
>>>> at
>>>> org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:634)
>>>> at javax.servlet.http.HttpServlet.service(HttpServlet.java:741)
>>>> at
>>>> org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
>>>> at
>>>> org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
>>>> at
>>>> org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
>>>> at
>>>> org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
>>>> at
>>>> org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
>>>> at
>>>> org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
>>>> at
>>>> org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
>>>> at
>>>> org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
>>>> at
>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
>>>> at
>>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
>>>> at
>>>> org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
>>>> at
>>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
>>>> at
>>>> at
>>>> org.apache.catalina.filters.CorsFilter.handleNonCORS(CorsFilter.java:414)
>>>> at org.apache.catalina.filters.CorsFilter.doFilter(CorsFilter.java:169)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
>>>> at
>>>> org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:89)
>>>> at
>>>> org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
>>>> at
>>>> org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:73)
>>>> at
>>>> at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:83)
>>>> at
>>>> at
>>>> org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
>>>> at
>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
>>>> at
>>>> org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
>>>> at
>>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>>> at
>>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
>>>> at
>>>> at
>>>> org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:112)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:172)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>>>> at
>>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
>>>> at
>>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
>>>> at
>>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:141)
>>>> at
>>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>> at
>>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
>>>> at
>>>> at
>>>> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:90)
>>>> at
>>>> at
>>>> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
>>>> at
>>>> at
>>>> at
>>>> org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
>>>> at
>>>> at
>>>> at
>>>> org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
>>>> at
>>>> org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
>>>> at
>>>> at
>>>> at
>>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
>>>> at
>>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
>>>> at
>>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:475)
>>>> at
>>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
>>>> at
>>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
>>>> at
>>>> org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:651)
>>>> at
>>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
>>>> at
>>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
>>>> at
>>>> org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:500)
>>>> at
>>>> org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
>>>> at
>>>> org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:754)
>>>> at
>>>> org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1376)
>>>> at
>>>> org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
>>>> at
>>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
>>>> at
>>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
>>>> at
>>>> org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
>>>> at java.lang.Thread.run(Thread.java:748)
>>>> 2018-10-15 14:59:46,764 DEBUG [auth.GeoFenceAuthenticationProvider] -
>>>> Auth request with
>>>> org.springframework.security.authentication.UsernamePasswordAuthenticationToken at 58b33e84:
>>>> Principal: admin; Credentials: [PROTECTED]; Authenticated: false; Details:
>>>> null; Not granted any authorities
>>>> 2018-10-15 14:59:46,764 DEBUG [geofence.cache] - Loading user 'admin'
>>>> 2018-10-15 14:59:46,765 WARN [geofence.cache] -
>>>> org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth
>>>> user [admin]
>>>> 2018-10-15 14:59:46,765 DEBUG [auth.GeoFenceAuthenticationProvider] -
>>>> Default admin credentials NOT authenticated -- probably a frontend check
>>>> On Mon, Oct 15, 2018 at 10:54 AM Michael Fedak <mikefedak at gmail.com>
>>>> wrote:
>>>>> I confirm that this fixes the management commands.
>>>>> On Mon, Oct 15, 2018 at 10:41 AM Alessio Fabiani <
>>>>>> This should fix the duplicated rules issue when running the
>>>>>> management commands
>>>>>> https://github.com/GeoNode/geonode/pull/3988/files
>>>>>> Il giorno lun 15 ott 2018 alle ore 16:13 Michael Fedak <
>>>>>>> Thank Alessio,
>>>>>>> This fixes the problem with documents. However I am still
>>>>>>> experiencing the same problems with layers, I have commented on the pull
>>>>>>> request. I am also having the same issue with superusers not being
>>>>>>> automatically logged into geoserver.
>>>>>>> On Mon, Oct 15, 2018 at 4:39 AM Alessio Fabiani <
>>>>>>>> Hi Michael,
>>>>>>>> thanks very much for helping on test.
>>>>>>>> I've finally figured out where the problem was. Fix available here
>>>>>>>> https://github.com/GeoNode/geonode/pull/3985
>>>>>>>> I'll merge it as soon as the Travis checks pass. I'll also try to
>>>>>>>> add some specific test cases for this particular issue.
>>>>>>>> Il giorno dom 14 ott 2018 alle ore 21:08 Alessio Fabiani <
>>>>>>>> alessio.fabiani at gmail.com> ha scritto:
>>>>>>>>> Uhm very strange. Tomorrow will do some specific tests on this.
>>>>>>>>> Currently I cannot figure out what the problem could be.
>>>>>>>>> Il dom 14 ott 2018, 21:03 Michael Fedak <mikefedak at gmail.com> ha
>>>>>>>>> scritto:
>>>>>>>>>> Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver
>>>>>>>>>> starts. However, I am experiencing the same issues as before.
>>>>>>>>>> On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <
>>>>>>>>>> mikefedak at gmail.com> wrote:
>>>>>>>>>>> Traced it back some more, it seems to be an issue with GWC:
>>>>>>>>>>> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider'
>>>>>>>>>>> while setting constructor argument; nested exception is
>>>>>>>>>>> org.springframework.beans.factory.BeanCreationException: Error creating
>>>>>>>>>>> bean with name 'gwcXmlConfigResourceProvider' defined in URL
>>>>>>>>>>> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
>>>>>>>>>>> Bean instantiation via constructor failed; nested exception is
>>>>>>>>>>> org.springframework.beans.BeanInstantiationException: Failed to instantiate
>>>>>>>>>>> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
>>>>>>>>>>> exception; nested exception is java.lang.IllegalStateException: Could not
>>>>>>>>>>> create directory.
>>>>>>>>>>> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <
>>>>>>>>>>>> Ok, got the war and attempted to deploy it. Tomcat is unable to
>>>>>>>>>>>> deploy it due to an error associated with geotools:
>>>>>>>>>>>> Geoserver log:
>>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>>>>>>>>>>>> AbstractEpsgMediator.
>>>>>>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>>>>>>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>>>>>>>>>>>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection
>>>>>>>>>>>> cleaner stopped
>>>>>>>>>>>> Catalina log:
>>>>>>>>>>>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>>>>>>>>>>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>>>>>>>>>>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>>>>>>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>>>>>>>>>>>> and a value of type
>>>>>>>>>>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>>>>>>>>>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>>>>>>>>>>> the web application was stopped. Threads are going to be renewed over time
>>>>>>>>>>>> to try and avoid a probable memory leak.
>>>>>>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d])
>>>>>>>>>>>> and a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>>>>>>>>>>>> failed to remove it when the web application was stopped. Threads are going
>>>>>>>>>>>> to be renewed over time to try and avoid a probable memory leak.
>>>>>>>>>>>> I will keep trying to troubleshoot this.
>>>>>>>>>>>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <
>>>>>>>>>>>>> Never mind, found your build server:
>>>>>>>>>>>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>>>>>>>>>>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <
>>>>>>>>>>>>>> Ok, I can do that. Is there a place to download the build
>>>>>>>>>>>>>> with the extension since build.geonode.org is down? Or shall
>>>>>>>>>>>>>> I just download vanilla 2.13 and apply the extension myself?
>>>>>>>>>>>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>>>>>>>>>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+
>>>>>>>>>>>>>>> there's a fix to threat void users as * users.
>>>>>>>>>>>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>>>>>>>>>>>> You won't have to change anything on the data dir.
>>>>>>>>>>>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com>
>>>>>>>>>>>>>>> ha scritto:
>>>>>>>>>>>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2
>>>>>>>>>>>>>>>> and I keep receiving the following error when attempting to run the
>>>>>>>>>>>>>>>> updatelayers command (Below).
>>>>>>>>>>>>>>>> I am also having trouble with users not being sync'd with
>>>>>>>>>>>>>>>> geoserver. I have gone through the documentation for security
>>>>>>>>>>>>>>>> configuration, and checked that the geonode role/user apis are accessible
>>>>>>>>>>>>>>>> to geoserver. As far as I can tell, nothing is blocking either geonode from
>>>>>>>>>>>>>>>> reaching geofence or vice-versa.
>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>> File "manage.py", line 29, in <module>
>>>>>>>>>>>>>>>> execute_from_command_line(sys.argv)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>>>>>>>>>>> line 354, in execute_from_command_line
>>>>>>>>>>>>>>>> utility.execute()
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> line 346, in execute
>>>>>>>>>>>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>>>>>>>>>>> line 394, in run_from_argv
>>>>>>>>>>>>>>>> self.execute(*args, **cmd_options)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> line 445, in execute
>>>>>>>>>>>>>>>> output = self.handle(*args, **options)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>>>>>>>>>>> line 124, in handle
>>>>>>>>>>>>>>>> execute_signals=True)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>>>>>>>>>>>> in gs_slurp
>>>>>>>>>>>>>>>> layer.set_permissions(perm_spec)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line 216, in
>>>>>>>>>>>>>>>> set_permissions
>>>>>>>>>>>>>>>> sync_geofence_with_guardian(self.layer, perms,
>>>>>>>>>>>>>>>> group=group)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44, in wrapper
>>>>>>>>>>>>>>>> return func(*args, **kwargs)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 393, in
>>>>>>>>>>>>>>>> _update_geofence_rule(layer.name, layer.workspace,
>>>>>>>>>>>>>>>> service)
>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 564, in
>>>>>>>>>>>>>>>> raise RuntimeError(msg)
>>>>>>>>>>>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>>>>>>>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>>>>>>>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181015/27a790a4/attachment-0001.html>
More information about the geonode-users
